3 Replies Latest reply on Feb 11, 2016 10:36 AM by yogastrech
    How to get rid of lens info on top LR pictures.
    yogastrech
      After formatting my HD I activated a something that show a huge pic of the lens across the top of my pictures. Now lightroom crashes all the time. How do I get rid of it. Thanks.
        • 1. Re: How to get rid of lens info on top LR pictures.
          Akash Sharma Adobe Employee
          Hi yogastrech,
          Which version of Lightroom are you using?
          Are you referring to Lens info in Loupe view?
          You could disable it by pressing  CTRL/Command +I
          Please disable use of Graphics Processor in Lightroom(version 6/cc) from Preferences>>Performance.Uncheck "Use graphics Processor" and restart Lightroom
          Let us know if that helps
          Regards,
          Akash
          • 2. Re: How to get rid of lens info on top LR pictures.
            Hal P Anderson Level 6
            Probably you just need to type 'i' once or twice. I doubt if that will help with crashes, though. What version of LR are you running? Please specify the number.
            Hal
            • 3. Re: How to get rid of lens info on top LR pictures.
              yogastrech Level 1
              My computer when using Lightroom CC and switching between Library and Develop mode stops working. Even when I tried unchecking the graphics card as per your instructions   it locked up. I recently had DELL format my hard drive. They had a lot of problems getting the Device drivers to install. I'm using a AMD Radeon 6600. Lightroom is basically unusable, but worked before the format. I would occasionally hang as did other applications .It's a windows 7, 12mb of ram, Intel R Core TM i7-2600 CPU @3.40GHZ, 64 bit operating system and is 4 years old I decided to format it to see if that would fix the problem. I've been working on this with DELL for a month now. Maybe I should format it again. . Also when I was using Photoshop CC, Error message came up that "Photoshop has encountered a problem with the display driver, and has temporarily disabled enhancements which use the graphics hardware." Will the Display drive still be disabled? Any suggestions would be helpful. Thanks.
              Yogastrech
