3 Replies Latest reply on Feb 10, 2016 1:45 PM by Szalam
    After Effects RAM Render Sluggish
    Caleb Bourgeois
      I'm working on a brand new 27" iMac 5K. Almost fully upgraded. Here are the specs.
      I'm working on the latest update of Creative Cloud: Version, released on Dec 21, 2015.
      The RAM preview on the simplest (ugly) graphics is running sluggish. Check it out.
      It should look like this when fully rendered.
      I began by blaming my Mac. But when using PremierePro, it renders 4K video at full resolution with ease. I don't think it's the machine.
      Are there settings that's the problem here? What's the issue with AE not being able to handle simple text. I dread having to deal with effects and video.
      One thing that may help. I'm running the screen resolution at the default 2560x1440. If I bring it down to 2048x1152, then the RAM rendering isn't as slow. Of course this is an unacceptable way to work. Plus, more graphics and effects would likely slow that down too.
      I need this fixed. If it's a Mac problem, I'll confront them. Return the hunk of metal if I need to. If it's a software issue, I'll use Motion, which makes me cringe to have to learn it. But if AE doesn't work, I have no choice.
        • 1. Re: After Effects RAM Render Sluggish
          Well, it's kind of a Mac problem and a software problem.
          Apple changed an API in El Capitan that caused an issue with the brand-new preview architecture in CC 2015. This is explained in Todd's post here: Re: After Effects 2015 won't preview in real time after El Capitan update.
          As he says, the next update to AE should fix it, but there are two decent workarounds in the meantime.
          The first is to hide the preview time indicator while a preview is running as is mentioned in that thread. It's really simple to do. Just press the ` (grave) button when your mouse is in the composition panel to make it full screen - thus covering the timeline panel. (It's the same key as the ~ [tilde] key on US English keyboards.)
          The second is to use CC 2014. There are a few things missing in CC 2015 that you might want in CC 2014 anyway (see this page: features not available in After Effects CC 2015 ).
          AE CC 2015 is the first step in a major re-architecture, separating the renderer from the UI for the first time in AE's 20+ year history. This is a big job and it's clearly still in progress. It's a necessary
          step for improving After Effects performance, but it's taking a while (and multiple versions) for them to get through it. So, during this time of transition as they're introducing elements of the new
          architecture, sometimes it may be easier to use the older version to get a job done.
          Also, double-check that your AE is updated to verson 13.7.x
          • 2. Re: After Effects RAM Render Sluggish
            Caleb Bourgeois Level 1
            Thanks a bunch, Szalam! I guess I wasn't asking the right question when searching the forum. It looks like using CC 2014 would work best for me now.
            • 3. Re: After Effects RAM Render Sluggish
              You've got to use what works for you!
              For me, I like working with the snappier interface in CC 2015, so I'd deal with having to do the workaround to make previews realtime and then I'd open my project in CC 2014 to render with multiprocessing.
