• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to log the rendered cfhttp URL?
Enthusiast ,
Feb 10, 2016 Feb 10, 2016
I have this cfhttp tag.I want to log the URL to see if it's actually having all the correct parameters because it's not working.
<cfhttp result="objRequest" url="#UrlDecode( strTargetURL )#" method="#CGI.request_method#" useragent="#CGI.http_user_agent#" timeout="15">
Views
795
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
<cflog file="_TESTING" text="URL is: #UrlDecode( strTargetURL )#" application="yes" type="information" />
After the code runs, open CFAdmin and go to your LOGS.  Look for the log called _TESTING.
Although, I think that the URL should be UrlENcode() (encoding it for safe browser use.)
V/r,
^_^
PS:  This will get only the value of the FQDN URL, not a URI or any url parameters (unless you're manually setting parameters for the "strTargetURL" variable).  If you want those, you'll have to add:
"?" & cgi.query_string
after the URL.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Feb 11, 2016 Feb 11, 2016
Thanks but that does not show me the URL with all the parameters attached to it. Here's the whole cfhttp tag.
    <!--- Add the referer that was passed-in. --->
    <cfhttpparam type="header" name="referer" value="#CGI.http_referer#" />
    <cfhttpparam type="url" name="apiKey" value="56a7d8c123131c4058389107">
    <cfhttpparam type="url" name="projectid" value="55c4ffd123131c527e456fe6">
    <cfhttpparam type="url" name="status[$in][]" value="published">
    <cfhttpparam type="url" name="status[$in][]" value="draft">
     <!--- Pass along any URL values. --->
    <cfloop item="strKey" collection="#URL#">
        <cfhttpparam type="url" name="phrase" value="#URL[strKey]#" />
    </cfloop>
</cfhttp>
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
You can easily dump out the request results with CFDUMP, but I have not found an easy way to dump out the request -- you'll have to log each parameter you want to view:
<cflog file="#expandPath('..')#/_TESTING-REQUEST" text="URL: #UrlDecode( strTargetURL )#" application="yes" type="information" />
<cflog file="#expandPath('..')#/_TESTING-REQUEST" text="apiKey: 56a7d8c123131c4058389107application="yes" type="information" />
<cfdump var=#objRequest#" output="#expandPath('..')#/_TESTING-RESPONSE" />
(you can combine entries as well)
Votes
Translate
Translate
Report
Report
Resources
Documentation
