I'm sure there must be updates for this. On Windows 10. All was working fine prior to hard drive crash.
Thanks so much for your answer but I was unable to find downloads available for Acrobat 8 Standard (only pro) but I did find a solution. It was to change the date on my computer to August 1, 2011 to get past the certificate issue that was causing the problem and not resolved until 8.1.7 as stated here: http://superuser.com/questions/752286/how-can-i-update-a-clean-install-of-acrobat-professional-8-0-0-to-the-latest-ver‌
Worked like a charm!
update by downloading the files directly and then applying them:
Thanks so much for your answer but I was unable to find downloads available for Acrobat 8 Standard (only pro) but I did find a solution. It was to change the date on my computer to August 1, 2011 to get past the certificate issue that was causing the problem and not resolved until 8.1.7 as stated here: http://superuser.com/questions/752286/how-can-i-update-a-clean-install-of-acrobat-professional-8-0-0...‌
