1. Re: Apple Pencil Support.
MobileDeveloperCKFeb 17, 2016 10:33 AM (in response to anthonyr41316627)
1 person found this helpfulHi,
We just released the new update (16.02.23) to the App Store on February 17, 2016.
The update includes improved support for Apple Pencil. (However, no changes had been made specifically for palm rejection.)
Would you please give it a try and let us know what you think?
Thank you!
2. Re: Apple Pencil Support.
WishesOnMainSt Feb 27, 2016 12:30 AM (in response to MobileDeveloperCK)the support has improved, but you need to introduce a way of changing thickness/colour of the writing.
3. Re: Apple Pencil Support.
MobileDeveloperCKFeb 27, 2016 8:59 AM (in response to WishesOnMainSt)
Hi WishesOnMainSt,
"writing"...Are you referring to drawing using Apple Pencil in Acrobat Reader for iOS?
There is a way to change thickness/color/opacity of pencil drawing in Acrobat Reader for iOS.
- Tap the existing drawing.
- Select Thickness, Color, Opacity from the menu that pops up.
- Change the value of the property.
Once you change a property, Acrobat Reader will remember the new value of the particular comment type.
Please let us know if it works for you.
Thank you.
4. Re: Apple Pencil Support [iOS]
MobileDeveloperCKMar 31, 2016 6:46 AM (in response to anthonyr41316627)
Hi anthonyr41316627,
The latest version 16.04.05 includes improved palm rejection when using Apple Pencil with iPad Pro.
Please let us know if it works better for you now.
Thank you!
5. Re: Apple Pencil Support [iOS]
WishesOnMainSt Jul 6, 2016 8:53 AM (in response to anthonyr41316627)all works well, it's just that the way you change the thickness and colour of the comment is quite cumbersome. Would be much better if there was a simple drop down menu before you start to write.
Regards
Paul
6. Re: Apple Pencil Support [iOS]
gwendolynr47122760 Jul 14, 2017 6:46 PM (in response to MobileDeveloperCK)Its great the Apple Pencil will work with Adobe reader but can the Apple Pencil work on Adobe Acrobat? Been trying for a bit and it doesn't show me the pencils' ability to change to a fine point. Is it possible? Any help is greatly appreciated.
Thanks in advance for your response.
7. Re: Apple Pencil Support [iOS]
MacBookPro_d_1 Aug 16, 2017 1:36 AM (in response to anthonyr41316627)Furthermore, is it somehow possible to scroll while using the pencil? In other Apps there is recognition if the pencil is used or a finger tip. So i scroll with my fingers and i write/draw with my pencil. Not so in Acrobat. The pencil is exactly the same as a finger. No difference, no pressure sensitivity.
I try using the iPad Version once every two or three month, but it stays the same. It’s not possible to have a smooth workflow. Drawing, saving, change color and thickness after that, scroll to next position, draw etc.
It would be really great to see a better pencil support on your roadmap.
8. Re: Apple Pencil Support [iOS]
cindyd93461660 Jan 11, 2018 2:35 PM (in response to MobileDeveloperCK)Yes, that IS very cumbersome. To not be able to pick the thickness of the line first, makes no sense at all. I don't know of any other program that works that way. And the thickness or thinness of the line might affect where the lines are supposed to go.
Very frustrating
