10 Replies Latest reply on Feb 23, 2016 2:36 AM by natrev
    Is this possible via Script...!
    natrev Level 3
      Hi Everyone!,
      Transform(Professional) the channel mask based on the two guides(Top and Bottom) and center to product.
      I have one channel named as "Alpha 1" and I need to transform the channel based the guides.
      Please help out this problem or give suggestion to proceed further.
      -yajiv
        • 1. Re: Is this possible via Script...!
          c.pfaffenbichler Level 9
          Could you please post step-by-step screenshots (with the pertinent Panels visible) to illustrate the process you wish to automate?
          • 2. Re: Is this possible via Script...!
            natrev Level 3
            Hi Chris,
            Thanks for the reply. Please find the screen shot for the quick reference.
            I have to transform (Professionate) the channel "Alpha 1" based(between) on the two guides.
            Thanks in advance.
            • 3. Re: Is this possible via Script...!
              I would think you can do what you want. if the alpha channel is a rectangle area as you show here. If the Alpha channel has a shape other than a rectangle that is squared up with the document canvas sides.  Transforming the selection height would distort the selection shape.  You will need to use the bounds of the alpha channel to get the alpha channels width and position
              Here is a script I wrote to position and size and mask an image layer to four guides.  The Mask I create would be the Alpha channel you want. You only have two guides you need four top, bottom, left and right. There is also a bug in photoshop scripting you may run in this area.
              // 2014  John J. McAssey (JJMack)
              // This script is supplied as is. It is provided as freeware.
              // The author accepts no liability for any problems arising from its use.
              /* Help Category note tag menu can be used to place script in automate menu
              <javascriptresource>
              <about>$$$/JavaScripts/FitImageToGuides/About=JJMack's FitImageToGuides .^r^rCopyright 2014 Mouseprints.^r^rFour and only four guides are required</about>
              <category>JJMack's Script</category>
              </javascriptresource>
              // enable double-clicking from Mac Finder or Windows Explorer
              #target photoshop // this command only works in Photoshop CS2 and higher
              // bring application forward for double-click events
              app.bringToFront();
              // ensure at least one document open
              if (!documents.length) alert('There are no documents open.', 'No Document');
              else {
                // declare Global variables
                //main(); // at least one document exists proceed
                app.activeDocument.suspendHistory('Fix Image to Guides','main()');  //problem if there is a selection a layer resize Photoshop back up a history step ?
              //                            main function
              function main() {
                // declare local variables
                var orig_ruler_units = app.preferences.rulerUnits;
                var orig_type_units = app.preferences.typeUnits;
                var orig_display_dialogs = app.displayDialogs;
                app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
                app.preferences.typeUnits = TypeUnits.POINTS;   // Set Type units to POINTS
                app.displayDialogs = DialogModes.NO; // Set Dialogs off
                try { code(); }
                // display error message if something goes wrong
                catch(e) { alert(e + ': on line ' + e.line, 'Script Error', true); }
                app.displayDialogs = orig_display_dialogs; // Reset display dialogs
                app.preferences.typeUnits  = orig_type_units; // Reset ruler units to original settings
                app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
              //                           main function end
              // The real code is embedded into this function so that at any point it can return
              // to the main line function to let it restore users edit environment and end
              function code() {
                if (app.activeDocument.guides.length != 4) { alert("Four and only four Guides are required"); return; } // quit
                // get guides;
                var theVert = new Array;
                var theHor = new Array;
                for (var m = 0; m < app.activeDocument.guides.length; m++) {
                if (app.activeDocument.guides[m].direction == Direction.HORIZONTAL) {theVert.push(app.activeDocument.guides[m].coordinate)}
                else {theHor.push(app.activeDocument.guides[m].coordinate)}
                if (theHor.length != 2 || theVert.length != 2) { alert("Four Guides two vertical and two horizontal are required"); return; } // quit
                getTarget=getSelectedLayersIdx();
                if (getTarget.length!=1){ alert("The number of layers targeted is " + getTarget.length ); return; } // quit
                if (app.activeDocument.activeLayer.isBackgroundLayer ) { alert("Can not resize the background layer"); return; } // quit
                if (!app.activeDocument.activeLayer.visible ) { alert("Active layer is  not visible"); return; } // quit
                //if (hasLayerMask()) { alert("Active layer is  Masked"); return; } // quit
                if (app.activeDocument.activeLayer.kind == LayerKind.NORMAL  || app.activeDocument.activeLayer.kind == LayerKind.SMARTOBJECT && hasLayerMask()) { deleteLayerMask ();}
                if (app.activeDocument.activeLayer.kind != LayerKind.NORMAL  && app.activeDocument.activeLayer.kind != LayerKind.SMARTOBJECT )  {
                alert("Active layer is " + app.activeDocument.activeLayer.kind); return; } // quit
                // set selection to the area defined but the guide lines the selection may get undone by the bug in .resize() backing up a step in histoty ???
                app.activeDocument.selection.select([[theHor[0], theVert[0]], [theHor[1], theVert[0]], [theHor[1], theVert[1]], [theHor[0], theVert[1]]]);
                // resize current normal layer or smart object layer to just cover selection canvas area aspect ratio and size and mask off any overflow
                var SB = app.activeDocument.selection.bounds; // Get selection bounds
                var SWidth = (SB[2].value) - (SB[0].value); // Area width
                var SHeight = (SB[3].value) - (SB[1].value); // Area height
                var LB = app.activeDocument.activeLayer.bounds; // Get Active layers bounds
                var LWidth = (LB[2].value) - (LB[0].value); // Area width
                var LHeight = (LB[3].value) - (LB[1].value); // Area height
                var userResampleMethod = app.preferences.interpolation; // Save interpolation settings
                app.preferences.interpolation = ResampleMethod.BICUBIC; // resample interpolation bicubic
                app.activeDocument.selection.deselect(); // This deselect work around Adobe Bug in CS5, CS6, CC and CC 2014
                // Since Adobe does not fix old releases of Photoshop this is a necessary work around for many releases of Photoshop
                //alert("Before re-size history");  // Added to debug Adobe Resize Bug
                try {
                if (LWidth/LHeight<SWidth/SHeight) { // layer's Aspect Ratio less the Canvas area Aspect Ratio
                var percentageChange = ((SWidth/LWidth)*100); // Resize to canvas area width
                app.activeDocument.activeLayer.resize(percentageChange,percentageChange,AnchorPosition.MI DDLECENTER);
                else {
                var percentageChange = ((SHeight/LHeight)*100); // resize to canvas area height
                catch(e) {
                app.preferences.interpolation = userResampleMethod; // Reset interpolation setting
                selectFront(); // Photoshop make top layer current when none are targeted
                code(); // Retry  with top visible layer selected targeted
                return; // rest would have been done during the retry
                //alert("After re-size history");    // Added to debug Adobe Resize Bug
                // Seems to be a bug in  resize() the document seems to first be backed up a step in history
                app.activeDocument.selection.select([[theHor[0], theVert[0]], [theHor[1], theVert[0]], [theHor[1], theVert[1]], [theHor[0], theVert[1]]]); // redo the selection
                align('AdCH'); // align to horizontal centers
                align('AdCV'); // align to vertical centers
                addLayermask(); // add layer mask to mask off excess
              // Helper Functions
              function align(method) {
                var desc = new ActionDescriptor();
                var ref = new ActionReference();
                ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                desc.putReference( charIDToTypeID( "null" ), ref );
                desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
                try{executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );}
                catch(e){}
              // Function: hasLayerMask
              // Usage: see if there is a raster layer mask
              // Input: <none> Must have an open document
              // Return: true if there is a vector mask
              function hasLayerMask() {
                var hasLayerMask = false;
                try {
                var keyUserMaskEnabled = app.charIDToTypeID( 'UsrM' );
                ref.putProperty( app.charIDToTypeID( 'Prpr' ), keyUserMaskEnabled );
                ref.putEnumerated( app.charIDToTypeID( 'Lyr ' ), app.charIDToTypeID( 'Ordn' ), app.charIDToTypeID( 'Trgt' ) );
                var desc = executeActionGet( ref );
                if ( desc.hasKey( keyUserMaskEnabled ) ) { hasLayerMask = true; }
                catch(e) { hasLayerMask = false; }
                return hasLayerMask;
              function getSelectedLayersIdx(){
                    var selectedLayers = new Array;
                    ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    var desc = executeActionGet(ref);
                    if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                       desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                        var c = desc.count
                        var selectedLayers = new Array();
                        for(var i=0;i<c;i++){
                          try{
                             activeDocument.backgroundLayer;
                             selectedLayers.push(  desc.getReference( i ).getIndex() );
                          }catch(e){
                             selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                     }else{
                       ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                       ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                       try{
                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                       }catch(e){
                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                    return selectedLayers;
              function selectFront() {
              // Alt+. shortcut select ftont visible layer
              var idslct = charIDToTypeID( "slct" );
                  var desc250 = new ActionDescriptor();
                  var idnull = charIDToTypeID( "null" );
                      var ref207 = new ActionReference();
                      var idLyr = charIDToTypeID( "Lyr " );
                      var idOrdn = charIDToTypeID( "Ordn" );
                      var idFrnt = charIDToTypeID( "Frnt" );
                      ref207.putEnumerated( idLyr, idOrdn, idFrnt );
                  desc250.putReference( idnull, ref207 );
                  var idMkVs = charIDToTypeID( "MkVs" );
                  desc250.putBoolean( idMkVs, false );
              executeAction( idslct, desc250, DialogModes.NO );
              function deleteLayerMask (apply) {
              // Delet Layer mask default to not apply first
              if (apply == undefined) {var apply = false};
              try {
              var idDlt = charIDToTypeID( "Dlt " );
                  var desc9 = new ActionDescriptor();
                      var ref5 = new ActionReference();
                      var idChnl = charIDToTypeID( "Chnl" );
                      var idMsk = charIDToTypeID( "Msk " );
                      ref5.putEnumerated( idChnl, idChnl, idMsk );
                  desc9.putReference( idnull, ref5 );
                  var idAply = charIDToTypeID( "Aply" );
                  desc9.putBoolean( idAply, apply );
              executeAction( idDlt, desc9, DialogModes.NO );
              catch (e) {}
              function addLayermask(){
              // Add layer Mask
              var idMk = charIDToTypeID( "Mk  " );
                  var desc52 = new ActionDescriptor();
                  var idNw = charIDToTypeID( "Nw  " );
                  desc52.putClass( idNw, idChnl );
                  var idAt = charIDToTypeID( "At  " );
                      var ref19 = new ActionReference();
                      ref19.putEnumerated( idChnl, idChnl, idMsk );
                  desc52.putReference( idAt, ref19 );
                  var idUsng = charIDToTypeID( "Usng" );
                  var idUsrM = charIDToTypeID( "UsrM" );
                  var idRvlS = charIDToTypeID( "RvlS" );
                  desc52.putEnumerated( idUsng, idUsrM, idRvlS );
              executeAction( idMk, desc52, DialogModes.NO );
              // Un link layer mask just added fron the layers content
              var idsetd = charIDToTypeID( "setd" );
                  var desc2 = new ActionDescriptor();
                      var ref1 = new ActionReference();
                      var idTrgt = charIDToTypeID( "Trgt" );
                      ref1.putEnumerated( idLyr, idOrdn, idTrgt );
                  desc2.putReference( idnull, ref1 );
                  var idT = charIDToTypeID( "T   " );
                      var desc3 = new ActionDescriptor();
                      var idUsrs = charIDToTypeID( "Usrs" );
                      desc3.putBoolean( idUsrs, false );
                  desc2.putObject( idT, idLyr, desc3 );
              executeAction( idsetd, desc2, DialogModes.NO );
              • 4. Re: Is this possible via Script...!
                natrev Level 3
                Hi JJMack,
                Sorry for the late reply and Thanks for your valuable reply.
                Actually I am looking for transform the active channel mask not a active layer.
                Please help me out this problem.
                Thanks in advance.
                -yajiv
                • 5. Re: Is this possible via Script...!
                  natrev Level 3
                  Hi Chris,
                  Any update/suggestion on the above mentioned scripts?
                  -yajiv
                  • 6. Re: Is this possible via Script...!
                    I am experiencing stress at work and do unfortunately not have time to look into this at current.
                    • 7. Re: Is this possible via Script...!
                      The mask channel is a selection. For your resized mask you need the four side as I wrote.  Top, Bottom, Left and Right.  once you have that information you delete the layer mask. Make a selection Top Left, Top Right, Bottom Right, Bottom left.  Then you Add Layer mask.  Like the script I poster added the layer mask on the image layer it resized to fill the selection. Only you do not resize you just replace the layer mask.
                      • 8. Re: Is this possible via Script...!
                        I see no option to align alpha channels so storing them as Layer Masks as JJMack apparently did would seem a prudent work-around.
                        Another option would be to load it as a Selection to determine the bounds and then calculate the necessary offset from that – not sure if this would be quicker.
                        • 9. Re: Is this possible via Script...!
                          Have you managed to achieve your goal yet?
                          What is the background anyway, why move a Channel?
                          • 10. Re: Is this possible via Script...!
                            natrev Level 3
                            Thanks reply Chris,
                            Finally I get the solution and its working fine. Once again thanks for your follow up.
                            -yajiv
