3 Replies Latest reply on Mar 11, 2009 10:41 AM by JeffreyGong
    "result" is never called on mx:RemoteObject
    univold Level 1
      Hello, All.
      I faced with the strange problem regarding getting result of Method invocation on the RemoteObject.
      I have BlazeDS on server side configured and everything was working fine when server returns a Collection of Objects.
      But now I'm trying to receive one Object, defined on server side as:
      @ActionScript( bindable = true)
      public class PageHolder<T,U> {
      private List<T> valueList;
      private U firstRowId;
      private U lastRowId;
      // ...... getters setters
      On client I have the mapped object:
      [Bindable]
      [RemoteClass(alias="com.dummy.PageHolder")]
      public class PageHolder extends PageHolderBase
      private var _firstRowId : Object;
      private var _lastRowId : Object;
      private var _valueList : ArrayCollection;
      The remote object defenition is:
      <mx:RemoteObject id="searchService" destination="searchService" fault="faultHandler(event);">
      <mx:method name="findCustomers" result="findCustomersResult(event)" fault="faultHandler(event);"/>
      </mx:RemoteObject>
      and methods are:
      public function findCustomers():void {
      try {
      searchService.searchCustomerData();
      } catch (e:Error) {
      Alert.show("after: " + e.message );
      public function findCustomersResult(event:ResultEvent):void {
      Alert.show("result!");
      page = event.result as PageHolder;
      So, the problem is that findCustomersResult function is never called.
      At the same time I have no errors in any logs, and I see debug messages from BlazeDS, that everything is fine:
      [BlazeDS]03/11/2009 09:51:56.505 [DEBUG] [Endpoint.AMF] Serializing AMF/HTTP response
      Version: 3
      (Message #0 targetURI=/2/onResult, responseURI=)
      (Externalizable Object #0 'DSK')
      (Typed Object #1 'com.dummy.PageHolder')
      firstRowId = "frid"
      valueList = (Externalizable Object #2 'flex.messaging.io.ArrayCollection')
      (Array #3)
      [0] = (Typed Object #4 'com.dummy.CustomerTransfer')
      firstRowId = null
      zip = null
      lastName = "lastboo"
      username = null
      userNo = null
      name = null
      firstName = "boo"
      lastRowId = null
      lastRowId = "lid"
      I would very appreciate if someone could help me.
      Thanks in advance.
        • 1. Re: &quot;result&quot; is never called on mx:RemoteObject
          Level 7
          "univold" <webforumsuser@macromedia.com> wrote in message
          news:gp8447$t6b$1@forums.macromedia.com...
          > Hello, All.
          > invocation
          > when
          > [Bindable]
          > </mx:RemoteObject>
          > and methods are:
          > try {
          > } catch (e:Error) {
          > public function
          > from
          Is your faultHandler code called?
          • 2. Re: &quot;result&quot; is never called on mx:RemoteObject
            univold Level 1
            No,
            I have no faults (fault handler is not called). Everything looks fine, but does not work :(
            • 3. Re: &quot;result&quot; is never called on mx:RemoteObject
              JeffreyGong Level 1
              Hi univold,
              You may need to change all three "private" to "public" in your AS PageHolder like
              public var _firstRowId : Object;
              public var _lastRowId : Object;
              public var _valueList : ArrayCollection;
              Lucky!
              Jeffrey
