Quiz Results is the last slide in my video, so Continue doesn't go anywhere and is confusing to the viewer. How do I remove it?
Please do not have score slide as last slide. The Continue button is
important, triggers the actions for Pass/Failure defined in Quiz
Preferences. To be sure score is reported, have a last slide after Score
slide.
The scores are showing up fine in the LMS and allowing the user to move to the next module if they pass, which is what I need.
I insist, do not remove the Continue button, it is more than a normal button, has part of the functionality of the score slide. You can ignore that advice of course, but I have warned you.
Sent from my iPad
I took your advice and added a slide after so that the continue button goes somewhere. However, it is requiring two clicks to move to the next slide.
Can you confirm whether just using a single click on the Continue button and just waiting for a number of seconds still causes the slide to continue, or does it just sit there forever if you don't click a second time?
Also, please test the same content OUTSIDE the LMS and see if the Continue button works with a single click then. If so, I would say your double click issue is due to the way the LMS SCORM Player frameset is causing the issue. The first click is to put the focus on the content, and the second click then activates the button (which would not normally be necessary outside the SCO API frameset).
Can you show a screenshot of the timeline, and of the actions in Quiz, Preferences, Pass and Fail? If those actions are left to the default 'Continue' and you changed the slide duration of the score slide without moving the pausing point (which is at 1.5secs), you will have to wait until the Playhead reaches the end of the slide. You can change the actions to 'Go to Next Slide'.
You'll find some tweaking possibilities in those blog posts:
