6 Replies Latest reply on Feb 17, 2016 2:21 AM by LeoMari
    Find text change to Glyph
    patrickbcm Level 1
      Hello
      I 'am looking for a script that find text and change it to a glyph with a color for example red.
      Something like this:
      Find #H and change it to glyph unicode 2665 with font ITC Zapf Dingbats Std and color name Red.
      Find #R and change it to glyph unicode 2666 with font ITC Zapf Dingbats Std and color name Red.
      Find #K and change it to glyph unicode 2663 with font ITC Zapf Dingbats Std and color name Black.
      Find #S and change it to glyph unicode 2660 with font ITC Zapf Dingbats Std and color name Black.
      I use Indesign CS6 on mac.
      Kind regards
      Patrick
        • 1. Re: Find text change to Glyph
          LeoMari Level 2
          You can try something like:
          var myDoc = app.documents[0]
              if (myDoc.paragraphStyles.itemByName("Paragraph Style Name").isValid){
                  app.findGrepPreferences = NothingEnum.nothing;
                  app.changeGrepPreferences = NothingEnum.nothing;
                  app.findChangeGrepOptions.includeFootnotes = true;
                  app.findChangeGrepOptions.includeHiddenLayers = true;
                  app.findChangeGrepOptions.includeLockedLayersForFind = true
                  app.findChangeGrepOptions.includeLockedStoriesForFind = true;
                  app.findChangeGrepOptions.includeMasterPages = true;
                  app.findGrepPreferences.findWhat = "a";  //character
                  app.findGrepPreferences.appliedColor = "NameColor";
                  app.findGrepPreferences.appliedParagraphStyle = "Paragraph Style Name";
                  app.findGrepPreferences.appliedFont = "Name Font";
                  app.findGrepPreferences.underline  = true;
                  app.findGrepPreferences.position = Position.SUPERSCRIPT;
                  app.changeGrepPreferences.changeTo = "ª";  //character substitute
                  app.changeGrepPreferences.appliedColor = "NameColor";
                  app.changeGrepPreferences.appliedCharacterStyle = "Paragraph Style Name";
                  app.activeDocument.changeGrep();
          Hug!
          • 2. Re: Find text change to Glyph
            patrickbcm Level 1
            Hello LeoMari
            When i fill in the script i get a error of a color.
                if (myDoc.paragraphStyles.itemByName("plt").isValid){
                    app.findGrepPreferences.findWhat = "#H";  //character
                    app.findGrepPreferences.appliedColor = "Zwart";
                    app.findGrepPreferences.appliedParagraphStyle = "plt";
                    app.findGrepPreferences.appliedFont = "ITC Zapf Dingbats";
                    app.changeGrepPreferences.changeTo = "2660";  //character substitute
                    app.changeGrepPreferences.appliedColor = "kaartkleur";
                    app.changeGrepPreferences.appliedCharacterStyle = "harten";
            it must be like this
            • 3. Re: Find text change to Glyph
              Hi Patrick,
              instead of appliedColor—there is no property with this name—try fillColor .
              Did not test, if fillColor will work in this case, if a String, the name of the color, is assigned.
              Uwe
              • 4. Re: Find text change to Glyph
                patrickbcm Level 1
                I get the same problem. And when i put that line out. I get no error but nothing is changed.
                I use now standard findChangeByList with this in the txt
                text{findWhat:"#H"}{appliedCharacterStyle:"harten"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all dash-dash and replace with an em dash.
                text{findWhat:"#H"}{changeTo:"<2665>"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all space-dash-space and replace with an en dash.
                text{findWhat:"#K"}{appliedCharacterStyle:"klaver"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all dash-dash and replace with an em dash.
                text{findWhat:"#K"}{changeTo:"<2663>"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all space-dash-space and replace with an en dash.
                text{findWhat:"#S"}{appliedCharacterStyle:"schoppen"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all dash-dash and replace with an em dash.
                text{findWhat:"#S"}{changeTo:"<2660>"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all space-dash-space and replace with an en dash.
                text{findWhat:"#R"}{appliedCharacterStyle:"ruiten"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}Find all dash-dash and replace with an em dash.
                text{findWhat:"#R"}{changeTo:"<2666>"}{includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}
                But when i use this indesign is quitting when i use the script in document en when i select all.
                When i do it for example in 20 rows it will work fine.
                • 5. Re: Find text change to Glyph
                  Peter Kahrel Adobe Community Professional & MVP
                  Patrick,
                  <2600> etc. are the Unicode values of the suit symbols, not the glyph IDs. And you confused the text and the Grep notations for Unicode characters: <2600> is used in text searches and replacements, \x{2600} in Grep. To change the symbols and apply the character styles, you can use a script like this:
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                  function kleur (afkorting, unicode, stijl) {
                    app.findGrepPreferences.findWhat = afkorting;
                    app.changeGrepPreferences.changeTo = unicode;
                    app.changeGrepPreferences.appliedCharacterStyle = stijl;
                  kleur ('#S', '\\x{2660}', 'schoppen');
                  kleur ('#H', '\\x{2665}', 'harten');
                  kleur ('#R', '\\x{2666}', 'ruiten');
                  kleur ('#K', '\\x{2663}', 'klaveren');
                  Since there's nothing GREPpy what you're looking for you could use find/changeText too, but grep replacements tend to be quicker than text replacements.
                  Peter
                  • 6. Re: Find text change to Glyph
                    LeoMari Level 2
                    app.findGrepPreferences.fillColor = "kaartkleur";
                    Invalid value for set property 'fillcolor'. Expected String, swatch or nothingEnum enumerator, but received "kaartkleur".
                    while i am give like this:
                    app.findGrepPreferences.fillColor =app.activeDocument.colors.item( "kaartkleur");
                    (or)
                    app.findGrepPreferences.fillColor =app.activeDocument.swatches.item( "kaartkleur");
