2 Replies Latest reply on Mar 12, 2009 3:13 PM by blst02
    cfexecute and ln on Linux
    blst02
      i am having a little trouble trying to get cfexecute to create a symbolic link on linux.
      i am using the below cfexecute tag to try and mimic what i am doing from the command line, but no link is made and no output is received from the cfexecute tag.
      i have also tried /bin/ln
      am i missing something?
      <cfexecute name="ln" arguments="-s /home/.../filename.txt /home/.../files/test.txt"></cfexecute>
      thanks.
        • 1. Re: cfexecute and ln on Linux
          Level 7
          > on linux.
          > tag.
          Make sure that the user CF is running as has enough rights on the
          destination directory (su to that user and try ln from that account).
          Mack
          • 2. Re: cfexecute and ln on Linux
            blst02 Level 1
            you are correct, it's a permission issue.
            i am just starting out with CF on linux and need a little advice.
            what is the best user for CF to run under and how would i go about changing that user?
            i don't see a lot on the web about CF and linux so any help is appreciated.
            thanks much.
