8 Replies Latest reply on Feb 28, 2016 9:32 PM by Akshay Raj
    Issue using Fill & Sign in Acrobat Pro DC
    Akshay Raj
      I am having issues using "Fill & Sign" feature. Whenever I click on it, Acrobat goes blank.
      Any Idea on how to deal with this problem?
      Thanks.
        • 1. Re: Issue using Fill & Sign in Acrobat Pro DC
          YatharthS Adobe Employee
          Please provide the exact dot version of the software & OS installed at your system .Also check whether is there any update available for the software after going through "help > check for updates "
          Follow this thread to reset the preferences for the Acrobat software:- https://forums.adobe.com/thread/1595848
          Also check whether its happening with all files on using this tool.
          Also check with different user account.
          Regards,
          Yatharth
          • 2. Re: Issue using Fill & Sign in Acrobat Pro DC
            Akshay Raj Level 1
            I am using
            OS: OS X 10.11.3
            Architecture: x86_64
            Build: 15.10.20056.167417
            AGM: 4.30.61
            CoolType: 5.14.5
            JP2K: 1.2.2.35592
            • 3. Re: Issue using Fill & Sign in Acrobat Pro DC
              Would like to know issue still persist after resetting the preferences.
              Have you checked with different user account as well .
              Regards,
              Yatharth
              • 4. Re: Issue using Fill & Sign in Acrobat Pro DC
                Akshay Raj Level 1
                I still have the issue. I tried doing that. I have also reinstalled the application but still the same issue.
                Thanks.
                • 5. Re: Issue using Fill & Sign in Acrobat Pro DC
                  sangrover Adobe Employee
                  Hi Akshay Raj,
                  Sorry for the inconvenience caused to you. In order to help us find the root cause of the issue, kindly provide us the following details :
                  1. Does this also happen with other applications like Send and Track, Send for Signature etc.?
                  2. When the blank screen appears while opening Fill and Sign, go to Activity Monitor and check whether a process named "RdrCEF"/"AcroCEF" is running or not?
                  3. Also go to Console application and verify if any crash logs have been generated under "User Diagnostic Reports"/"System Diagnostic Reports". If yes, please share them with us.
                  3. Go to /Library/Application Support/Adobe/<Reader/Acrobat>/DC/WebResources/Resource0 and capture the snapshot of the contents. Please share the snapshot.
                  Thanks and Regards,
                  Sandeep
                  • 6. Re: Issue using Fill & Sign in Acrobat Pro DC
                    Akshay Raj Level 1
                    Hi Sandeep,
                    1. Yes, it happens to others as well.
                    2. I have three AcroCEF running and one of which is Not responding
                    3. Crash report for Acrobat
                    Process:               AdobeAcrobat [6251]
                    Path:                  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                    Identifier:            com.adobe.Acrobat.Pro
                    Version:               15.010.20056 (15.010.20056)
                    Code Type:             X86-64 (Native)
                    Parent Process:        ??? [1]
                    Responsible:           AdobeAcrobat [6251]
                    User ID:               501
                    Date/Time:             2016-02-14 10:00:50.057 +1300
                    OS Version:            Mac OS X 10.11.3 (15D21)
                    Report Version:        11
                    Anonymous UUID:        01ECA070-B3D1-6349-E610-05A34F609B7B
                    Time Awake Since Boot: 49000 seconds
                    System Integrity Protection: enabled
                    Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                    Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
                    Exception Codes:       EXC_I386_GPFLT
                    Exception Note:        EXC_CORPSE_NOTIFY
                    Global Trace Buffer (reverse chronological seconds):
                    30446.392366 CFNetwork                 0x00007fff9d758a5b TCP Conn 0x7f86ede0b820 SSL Handshake DONE
                    30447.321026 CFNetwork                 0x00007fff9d758a5b TCP Conn 0x7f86efa1bb60 SSL Handshake DONE
                    30447.476039 CFNetwork                 0x00007fff9d757303 TCP Conn 0x7f86ef988650 complete. fd: 58, err: 0
                    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                    0   com.adobe.Acrobat.framework   0x0000000110cad3c7 0x10f49c000 + 25236423
                    1   com.adobe.Acrobat.framework   0x000000010f4fbd75 0x10f49c000 + 392565
                    2   com.adobe.Acrobat.framework   0x00000001104b185b 0x10f49c000 + 16865371
                    3   com.adobe.Acrobat.framework   0x00000001104b3d09 0x10f49c000 + 16874761
                    4   com.adobe.Acrobat.framework   0x000000011049b9d5 0x10f49c000 + 16775637
                    5   com.adobe.Acrobat.framework   0x00000001104b3d09 0x10f49c000 + 16874761
                    6   com.adobe.Acrobat.framework   0x000000011048b88a 0x10f49c000 + 16709770
                    7   com.adobe.Acrobat.framework   0x000000011048b54f 0x10f49c000 + 16708943
                    8   libsystem_c.dylib             0x00007fff9840646b __cxa_finalize_ranges + 345
                    9   libsystem_c.dylib             0x00007fff9840676f exit + 55
                    10  com.adobe.Acrobat.framework   0x000000010f799d40 0x10f49c000 + 3136832
                    11  com.adobe.Acrobat.framework   0x000000010f4a3cb1 RunAcrobat + 253
                    12  com.adobe.Acrobat.Pro         0x000000010f493cb2 main + 86
                    13  com.adobe.Acrobat.Pro         0x000000010f493c54 start + 52
                    Thread 1:
                    0   libsystem_kernel.dylib         0x00007fff8c25a6de __workq_kernreturn + 10
                    1   libsystem_pthread.dylib       0x00007fff99bf9729 _pthread_wqthread + 1283
                    2   libsystem_pthread.dylib       0x00007fff99bf7365 start_wqthread + 13
                    Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                    0   libsystem_kernel.dylib         0x00007fff8c25aff6 kevent_qos + 10
                    1   libdispatch.dylib             0x00007fff8edf8099 _dispatch_mgr_invoke + 216
                    2   libdispatch.dylib             0x00007fff8edf7d01 _dispatch_mgr_thread + 52
                    Thread 3:
                    0   libsystem_kernel.dylib         0x00007fff8c259eb2 __psynch_cvwait + 10
                    1   libsystem_pthread.dylib       0x00007fff99bfa150 _pthread_cond_wait + 767
                    2   com.adobe.Acrobat.framework   0x000000010f90f34f 0x10f49c000 + 4666191
                    3   com.adobe.Acrobat.framework   0x000000010f9003c7 0x10f49c000 + 4604871
                    4   com.adobe.Acrobat.framework   0x000000011050625f 0x10f49c000 + 17211999
                    5   com.adobe.Acrobat.framework   0x000000010f8fb923 0x10f49c000 + 4585763
                    6   com.adobe.Acrobat.framework   0x000000010f90a464 0x10f49c000 + 4645988
                    7   libsystem_pthread.dylib       0x00007fff99bf9c13 _pthread_body + 131
                    8   libsystem_pthread.dylib       0x00007fff99bf9b90 _pthread_start + 168
                    9   libsystem_pthread.dylib       0x00007fff99bf7375 thread_start + 13
                    Thread 4:: com.apple.NSEventThread
                    0   libsystem_kernel.dylib         0x00007fff8c254386 mach_msg_trap + 10
                    1   libsystem_kernel.dylib         0x00007fff8c2537c7 mach_msg + 55
                    2   com.apple.CoreFoundation       0x00007fff8972a624 __CFRunLoopServiceMachPort + 212
                    3   com.apple.CoreFoundation       0x00007fff89729aec __CFRunLoopRun + 1356
                    4   com.apple.CoreFoundation       0x00007fff89729338 CFRunLoopRunSpecific + 296
                    5   com.apple.AppKit               0x00007fff98eaf065 _NSEventThread + 149
                    6   libsystem_pthread.dylib       0x00007fff99bf9c13 _pthread_body + 131
                    7   libsystem_pthread.dylib       0x00007fff99bf9b90 _pthread_start + 168
                    8   libsystem_pthread.dylib       0x00007fff99bf7375 thread_start + 13
                    Thread 5:
                    0   libsystem_kernel.dylib         0x00007fff8c25b45e read + 10
                    1   com.adobe.Acrobat.framework   0x000000010f8fe6b3 0x10f49c000 + 4597427
                    2   com.adobe.Acrobat.framework   0x000000010f8fc8e6 0x10f49c000 + 4589798
                    3   com.adobe.Acrobat.framework   0x000000010f906cb4 0x10f49c000 + 4631732
                    4   com.adobe.Acrobat.framework   0x000000010f8fb923 0x10f49c000 + 4585763
                    5   com.adobe.Acrobat.framework   0x000000010f90a464 0x10f49c000 + 4645988
                    Thread 6:: com.apple.NSURLConnectionLoader
                    5   com.apple.CFNetwork           0x00007fff9d71d6e9 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
                    6   com.apple.Foundation           0x00007fff8e42ec6f __NSThread__start__ + 1351
                    Thread 7:: com.apple.CFSocket.private
                    0   libsystem_kernel.dylib         0x00007fff8c25a176 __select + 10
                    1   com.apple.CoreFoundation       0x00007fff8977616a __CFSocketManager + 762
                    2   libsystem_pthread.dylib       0x00007fff99bf9c13 _pthread_body + 131
                    3   libsystem_pthread.dylib       0x00007fff99bf9b90 _pthread_start + 168
                    4   libsystem_pthread.dylib       0x00007fff99bf7375 thread_start + 13
                    Thread 8:
                    Thread 9:
                    Thread 10:
                    Thread 11:
                    Thread 12:
                    Thread 0 crashed with X86 Thread State (64-bit):
                      rax: 0x0000000000000000  rbx: 0x00007f86eadc4f20  rcx: 0x62614c776f68530a  rdx: 0x00007fff5076d820
                      rdi: 0x0000000000000105  rsi: 0x000000010fce0016  rbp: 0x00007fff5076d810  rsp: 0x00007fff5076d7b0
                       r8: 0x00007fff7bdf1070   r9: 0x00007fff7bdf10c8  r10: 0x00000000ffffffff  r11: 0xffffffff00000000
                      r12: 0x00007fff7bdf1070  r13: 0x0000000000000002  r14: 0x00007fff5076d820  r15: 0x000000010fce0016
                      rip: 0x0000000110cad3c7  rfl: 0x0000000000010202  cr2: 0x000000012480d000
                    Logical CPU:     6
                    Error Code:      0x00000000
                    Trap Number:     13
                    Binary Images:
                           0x10f492000 -        0x10f494fff +com.adobe.Acrobat.Pro (15.010.20056 - 15.010.20056) <8CE449E9-590A-3F75-9205-E72C6F80E241> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                           0x10f49c000 -        0x111ab5fff +com.adobe.Acrobat.framework (15.010.20056 - 15.010.20056) <A7EB73CD-1B3B-32A9-AF52-BF803D4C252F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
                           0x111e13000 -        0x111f60ff7 +com.adobe.ACE (AdobeACE 2.20.02.35095 - 2.20.02.35095) <B9B59D33-62BD-341A-8D88-D6CCF27F00B0> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                           0x111f79000 -        0x11256fff7 +com.adobe.AGM (AdobeAGM 4.30.61.1 - 4.30.61.1) <1512B81D-4179-35F8-9419-E06079B2B531> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                           0x112a53000 -        0x112a72fff +com.adobe.BIB (AdobeBIB 1.2.03.35525 - 1.2.03.35525) <3E70D9BA-39DF-3D62-8004-98B3ED2A4405> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                           0x112a7a000 -        0x112d9fff7 +com.adobe.CoolType (AdobeCoolType 5.14.05.35525 - 5.14.05.35525) <9F7A53EC-732B-30B3-A4BA-FD2C06A4B280> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                           0x112de7000 -        0x112deafff +com.adobe.AdobeCrashReporter (7.2 - 7.2.3) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporte r
                           0x115f50000 -        0x115fdeff7 +com.adobe.headlights.LogSessionFramework (7.2.1.3620) <A783347F-B831-3FA6-86B0-C00B5EEFBA6B> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/LogSession.framework/LogSession
                           0x116021000 -        0x11605bff7 +com.adobe.pip (7.2.1.3620) <3C839A80-AE44-3E17-88B5-AB995F278981> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                           0x11648a000 -        0x11648afe7 +cl_kernels (???) <C6236D2B-AA3C-4C39-9FEF-A42CC04F75B4> cl_kernels
                           0x1175c2000 -        0x1175d4fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                           0x117681000 -        0x117690ff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                           0x117714000 -        0x117730ff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                           0x117f99000 -        0x117f9bff7  com.apple.textencoding.unicode (3.0 - 3.0) <78B2E03E-3AE3-34E0-AA72-22F1D696170B> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                           0x11818b000 -        0x1181adff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                           0x118d04000 -        0x118d0bfff  com.apple.URLMount.AFPPlugin (6.0 - 6.0) <64639D37-B6EA-3AA3-9F81-B53A24F25AF7> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
                           0x118d13000 -        0x118d53fff  com.apple.AppleShareClientCore (4.0 - 3.0) <81854BD1-1190-3F8D-94B2-4C6FBD8617D1> /System/Library/PrivateFrameworks/AppleShareClientCore.framework/Versions/A/AppleShareCli entCore
                           0x118dd1000 -        0x118deefff +com.adobe.PDFSettings (AdobePDFSettings 1.03.0 - 1.3) <7FDF9E77-A5D3-36B1-8372-9B3E3156C138> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/FrameWorks/AdobePDFSettings.framework/AdobePDFSettings
                           0x118e4d000 -        0x118ec2ff7  com.apple.GeForceMTLDriver (10.8.14 - 10.0.8) <081610F2-EEEF-346A-AF10-5214BAEF1D49> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
                           0x11917d000 -        0x1191a1ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.33931 - 3.9.0.33931) <FC64B09E-8B23-3E05-B03A-5CB9BFB60586> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Shared Expat
                           0x11bbee000 -        0x11bc67fff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <FC4749BE-E5E9-3A98-8B0D-AE11EAC3FC8B> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
                           0x11da3a000 -        0x11dadffff  ColorSyncDeprecated.dylib (470.2) <9D376A26-4D17-37CB-9D02-2E0D6E92EC93> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                           0x12336c000 -        0x123473ff7 +com.adobe.amtlib (9.0.0.301 - 9.0.0.301) <D6B0C5C6-D691-30FC-BFC1-5FAEA2700B4A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
                           0x123486000 -        0x1234a1ffb  com.apple.security.csparser (3.0 - 57337.20.44) <EB34BC6C-1790-3E13-A0CA-D044A290E069> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
                           0x123b37000 -        0x123c74fef +IMSLib.dylib (9.0.1.28 - 9.0.1.28) <5FC6C059-D74C-3F40-99C3-2B2C111878E6> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
                           0x123c94000 -        0x123d0eff7  com.apple.xquery (1.3.1 - 30) <AAEFB337-E58A-39F5-8C19-6E990401B72F> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                           0x124868000 -        0x124944fff +com.adobe.AXEXSLT (AdobeAXSLE 3.9.0.33931 - 3.9.0.33931) <CCB15652-F2E9-3D4F-825D-AA1012DD1E97> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
                           0x1267c2000 -        0x1267e8ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <E2CDA7A7-711A-37AC-902A-3CA5A133E4D4> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                           0x1270f7000 -        0x1270f9fff +AcrobatUpdateHelperLib.dylib (1) <81DA43D1-23B0-3671-9C5C-DFDA1839D5E0> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
                           0x1280b1000 -        0x128164ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 15 - 81.157285) <C07C646A-64B4-383F-A3F0-6E39FE41347D> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                           0x12b0a6000 -        0x12bdebfff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                           0x12bdff000 -        0x12bf02ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                           0x12bf4d000 -        0x12bfc9ff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <4D65F948-FC77-3DCB-8370-995E98502B48> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                           0x12c1e1000 -        0x12c1fbff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                           0x12c2e4000 -        0x12c3eafff +com.lextek.onix (3.12.3.26 - 3.12.3.26) <8BDDA37A-C6FE-33F1-8F98-A59CFC3BC984> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Onix.framework/Onix
                           0x1303b8000 -        0x13041afff  com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (10.12.13 - 10.1.2) <F37F440A-FB57-3E0C-8FEF-9C409F96A1DD> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD4000GraphicsMTLDriver
                           0x1358ea000 -        0x135dd9fff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.12.13 - 10.1.2) <F1909016-64B8-30D2-B478-27C69A851616> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD4000GraphicsGLDriver
                           0x136574000 -        0x13662dff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35592) <F906104A-17CD-3F56-A7F9-DA70C4EFE92C> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                           0x137061000 -        0x139e83fff +com.adobe.PreflightLib (PreflightLib version 15.0.0 [153] - 15.0.0 [153]) <D0DF1153-B509-32FA-AB3C-E9CF22027820> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Preflight.acroplugin/Contents/Frameworks/PreflightLib.framew ork/PreflightLib
                        0x7fff6a8c6000 -     0x7fff6a8fd007  dyld (360.19) <9D05FDF4-65CE-3B53-86D4-ABE1A5BF35F3> /usr/lib/dyld
                        0x7fff8968f000 -     0x7fff896b9ff7  GLRendererFloat (12.0.40.6) <E739EE06-2F9C-3D46-AC6D-122DCD66E8C9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                        0x7fff896ba000 -     0x7fff89b30fff  com.apple.CoreFoundation (6.9 - 1256.14) <768A7FB7-9143-3148-8591-7C6ED3162D35> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x7fff89b55000 -     0x7fff89b5dfff  com.apple.AppleSRP (5.0 - 1) <25775E90-1DBB-3BFA-B4B4-F8F262B9EC1F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                        0x7fff89bf1000 -     0x7fff89bf9ffb  libsystem_dnssd.dylib (625.20.4) <945B5FB1-DA91-3D45-A961-A8FAD53C1E7E> /usr/lib/system/libsystem_dnssd.dylib
                        0x7fff89bfa000 -     0x7fff89f37ff3  com.apple.WebKit (11601 - 11601.4.4) <F35B60CF-8F10-3FC3-9E01-F7C887070EA2> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                        0x7fff89f8e000 -     0x7fff89fb2fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <58FAFE0C-A2D8-3746-AC8F-BF553A7CDED7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                        0x7fff89fb8000 -     0x7fff8a05ffff  com.apple.LanguageModeling (1.0 - 1) <E1E4091D-6CAB-36E0-A206-AAADE69791DC> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                        0x7fff8a067000 -     0x7fff8a274ffb  libicucore.A.dylib (551.41) <CFFD7342-A7D6-323A-AC14-B9EECF6EFFED> /usr/lib/libicucore.A.dylib
                        0x7fff8a275000 -     0x7fff8a280fff  com.apple.AppSandbox (4.0 - 261.20.7) <0CA08EB7-D574-3E2F-A3AE-FEA80FF3F304> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                        0x7fff8a540000 -     0x7fff8a56fff7  com.apple.securityinterface (10.0 - 55065.20.1) <EDBD990A-0960-3DBB-BB42-43A36F49477F> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                        0x7fff8a575000 -     0x7fff8a57afff  com.apple.AssetCacheServices (14 - 14) <33685005-A92A-3006-97F5-FBF8530925B2> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                        0x7fff8a57b000 -     0x7fff8a5a2fff  com.apple.ProtectedCloudStorage (1.0 - 1) <F9E1BDE2-16AF-34B5-B7FE-127D511BDC9E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                        0x7fff8a5e7000 -     0x7fff8a65bff3  com.apple.securityfoundation (6.0 - 55126) <11644DA4-F1CF-3FB1-86A0-0DA8E8C27148> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                        0x7fff8a69a000 -     0x7fff8a69bff3  com.apple.print.framework.Print (10.0 - 266) <BF573614-5666-3D16-9D45-4690911F030A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                        0x7fff8a8df000 -     0x7fff8a8fbff7  libextension.dylib (78) <589FA312-F17C-3A8D-986F-FD995D0065D5> /usr/lib/libextension.dylib
                        0x7fff8a8fc000 -     0x7fff8a912ff7  libsystem_coretls.dylib (83.20.8) <75C97D88-0A63-3093-AE83-DE33EB7405CE> /usr/lib/system/libsystem_coretls.dylib
                        0x7fff8ae0f000 -     0x7fff8aebafff  com.apple.PDFKit (3.1 - 3.1) <F6796D8B-3BE1-3D09-B6D4-15016CDE14D9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                        0x7fff8aebb000 -     0x7fff8c126ffb  com.apple.CoreGraphics (1.600.0 - 948) <A5BCCC6D-D931-360D-BF45-02F5ED4E1773> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                        0x7fff8c173000 -     0x7fff8c187fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <8D8A190B-3C08-3624-8DC6-E9EBE22BC3BB> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                        0x7fff8c188000 -     0x7fff8c18cfff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                        0x7fff8c1cc000 -     0x7fff8c242ff7  com.apple.MMCS (1.3 - 351) <13D01D37-66F0-30BB-AA7E-D1D348F738E3> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                        0x7fff8c243000 -     0x7fff8c261fff  libsystem_kernel.dylib (3248.30.4) <9CEB6C3B-1CAF-3C32-A9FD-93BC72CBCEA1> /usr/lib/system/libsystem_kernel.dylib
                        0x7fff8cb46000 -     0x7fff8cb61fff  com.apple.aps.framework (4.0 - 4.0) <894B1FD6-6EBE-302B-947B-D5813DABEDF0> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                        0x7fff8cb62000 -     0x7fff8cb8dffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
                        0x7fff8cb8e000 -     0x7fff8cc05fe7  libcorecrypto.dylib (335.20.1) <C6BD205F-4ECE-37EE-BCAB-A76F39CDCFFA> /usr/lib/system/libcorecrypto.dylib
                        0x7fff8cc06000 -     0x7fff8cc54ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
                        0x7fff8cc8c000 -     0x7fff8cc93ff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                        0x7fff8ccdf000 -     0x7fff8ce24fff  com.apple.QTKit (7.7.3 - 2943) <6DD72D38-9449-3289-904E-B6E148993AA5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                        0x7fff8ceb8000 -     0x7fff8ced5ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <2B459E1F-0563-30B2-A04D-CF1793426B66> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                        0x7fff8cee5000 -     0x7fff8d0f0fff  libFosl_dynamic.dylib (16.24) <363B7CEE-B662-32F3-9D7B-245E64927C35> /usr/lib/libFosl_dynamic.dylib
                        0x7fff8d152000 -     0x7fff8d159ff7  libcompiler_rt.dylib (62) <D3C4AB40-23B4-3BC6-8C38-5B8758D14E80> /usr/lib/system/libcompiler_rt.dylib
                        0x7fff8d1f5000 -     0x7fff8d28afff  com.apple.ink.framework (10.9 - 214) <6B573126-A6E9-357F-B36A-AA5BDC0BEAF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                        0x7fff8d2b3000 -     0x7fff8d2ebfff  com.apple.RemoteViewServices (2.0 - 99) <596153FD-3CB9-3FED-9D63-1B73B01AC6DB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                        0x7fff8d2ec000 -     0x7fff8d46afff  com.apple.UIFoundation (1.0 - 436.1) <8C254BB0-1DED-36A2-AAAF-786EB19CCE39> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                        0x7fff8d55c000 -     0x7fff8d564fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <D44F75E7-C679-3C21-AD76-8FA8A2B898F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                        0x7fff8d565000 -     0x7fff8d591fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <FDCA9F2D-E06A-3DEC-8E1A-7535BAE68B62> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                        0x7fff8d592000 -     0x7fff8d5defff  com.apple.print.framework.PrintCore (11.2 - 472.2) <449D8AB5-7891-32D0-9DC5-C90FE10DC0BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                        0x7fff8d5df000 -     0x7fff8d7ecff7  com.apple.CoreImage (11.2.0 - 366.2.7) <344F1067-5F52-3626-8F6C-2B678DEB80A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                        0x7fff8d7ed000 -     0x7fff8d832ff3  libFontRegistry.dylib (155.1) <593CC743-3785-3CC5-A229-D3846C51E054> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                        0x7fff8d833000 -     0x7fff8d925ff7  libJP2.dylib (1442) <3B374049-CCA4-3B4D-9517-583F2BF6B77D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                        0x7fff8d926000 -     0x7fff8dad1ffb  GLEngine (12.0.40.6) <D55FDA69-AE2C-3AA1-9565-309C13C1C5C2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                        0x7fff8dad2000 -     0x7fff8db89ff7  com.apple.CoreDuet (1.0 - 1) <20BDA287-415A-385E-BCB5-934D165BDAA4> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                        0x7fff8db91000 -     0x7fff8dc9fff3  com.apple.desktopservices (1.10 - 1.10) <0BAED9FA-EFA5-3DA0-8715-043FD2400B77> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                        0x7fff8dca0000 -     0x7fff8e1f7fff  com.apple.MediaToolbox (1.0 - 1731.15.33) <16374746-DF5E-3103-994B-74CF151BD06A> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                        0x7fff8e257000 -     0x7fff8e5abff7  com.apple.Foundation (6.9 - 1256.1) <66106CC9-9D97-3846-88D8-4BF6BB508296> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x7fff8e5ac000 -     0x7fff8e5aeff7  com.apple.xpc.ServiceManagement (1.0 - 1) <3777FD15-B6F3-32A2-A8E3-3E8CE3B8D5E7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                        0x7fff8e5c6000 -     0x7fff8e5c9fff  libspindump.dylib (197.1) <61EB1BFE-8600-3420-B18E-1541D3C15C5C> /usr/lib/libspindump.dylib
                        0x7fff8e5ca000 -     0x7fff8eaecfff  com.apple.QuartzComposer (5.1 - 334) <0A407B05-5CF5-3084-93EF-F4619BDEEF8B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                        0x7fff8ebb9000 -     0x7fff8ebf7ff7  libGLImage.dylib (12.0.40.6) <ACC6C7B0-A805-344C-AAC3-BA50780227E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                        0x7fff8ecb4000 -     0x7fff8ecbcfff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
                        0x7fff8ecc4000 -     0x7fff8ecccfff  libGFXShared.dylib (12.0.40.6) <7E84C8A9-40DA-302A-A3DE-9AE3C61A3465> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                        0x7fff8ecd3000 -     0x7fff8ede5fef  libvDSP.dylib (563.4) <C069B6A3-D7CD-3B72-918C-15514066A2F3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                        0x7fff8ede6000 -     0x7fff8edefff7  com.apple.CommonAuth (4.0 - 2.0) <B2CEE6B5-9464-35F2-9339-9F52001C8A27> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                        0x7fff8edf0000 -     0x7fff8ee1dfff  libdispatch.dylib (501.20.1) <324C9189-2AF3-3356-847F-6F4CE1C6E901> /usr/lib/system/libdispatch.dylib
                        0x7fff8ee3c000 -     0x7fff8ef2eff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
                        0x7fff8f01a000 -     0x7fff8f101ff7  libcrypto.0.9.8.dylib (59) <ED1C2A26-8FFC-30FF-8726-FF952EF94ADF> /usr/lib/libcrypto.0.9.8.dylib
                        0x7fff8f10d000 -     0x7fff8f22afff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
                        0x7fff8f22b000 -     0x7fff8f22cffb  libSystem.B.dylib (1226.10.1) <5A4257EF-3145-3BB3-87A4-0D2404A9462D> /usr/lib/libSystem.B.dylib
                        0x7fff8f22d000 -     0x7fff8f28dfff  com.apple.QuickLookFramework (5.0 - 696.3) <D20C8962-7BB8-3A2C-BB80-5B61259B50F2> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                        0x7fff8f28e000 -     0x7fff8f290fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
                        0x7fff8f291000 -     0x7fff8f380fff  libxml2.2.dylib (29.2) <F70308DF-313F-334F-8F0E-82E79821583D> /usr/lib/libxml2.2.dylib
                        0x7fff8f381000 -     0x7fff8f3d0ff7  com.apple.opencl (2.6.9 - 2.6.9) <27643341-DC6F-3C2F-8B8B-637061979BF3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                        0x7fff8f3d1000 -     0x7fff8f3dcfff  com.apple.DirectoryService.Framework (10.11 - 194) <159606E0-F3AF-36B0-9744-4BFE1DA3EC74> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                        0x7fff8f3ed000 -     0x7fff8f760ff7  com.apple.FinderKit (1.4.2 - 1.4.2) <217CF784-DAED-361C-91E9-689F3DA0C617> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                        0x7fff8f895000 -     0x7fff8f8a1ff7  com.apple.OpenDirectory (10.11 - 194) <5409AC27-3B83-3F35-8EB5-51228B4604AE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                        0x7fff8f8d0000 -     0x7fff8f944fff  com.apple.framework.IOKit (2.0.2 - 1179.20.6) <D92E537D-F96D-39E1-B9AC-9A18943AFCC7> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                        0x7fff8f945000 -     0x7fff8f950fff  libGPUSupportMercury.dylib (12.0.40.6) <6061FB76-565E-3E11-B659-50827DFB0BDE> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                        0x7fff8f954000 -     0x7fff8f9a6fff  com.apple.ImageCaptureCore (7.0 - 7.0) <68537DDB-383F-3D4D-8125-789053333B13> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                        0x7fff8f9ab000 -     0x7fff8fa00ff7  com.apple.AE (701 - 701) <FB22BE84-9CB8-36BF-8061-F93D716C0A84> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                        0x7fff8fa01000 -     0x7fff8fa14fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                        0x7fff8fa15000 -     0x7fff8fa20fff  libkxld.dylib (3248.30.4) <BAA3DDEC-AD81-3C29-AECC-59E4AD114D3C> /usr/lib/system/libkxld.dylib
                        0x7fff8fa21000 -     0x7fff8fa22fff  libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
                        0x7fff8fa34000 -     0x7fff8fa65ff7  libtidy.A.dylib (15.17) <03EF1071-8B43-3B41-9879-118FA27F89C5> /usr/lib/libtidy.A.dylib
                        0x7fff8fa66000 -     0x7fff8fa69ffb  libdyld.dylib (360.19) <AA629043-C6F6-32FE-8007-E3478E99ACA7> /usr/lib/system/libdyld.dylib
                        0x7fff8fa6a000 -     0x7fff8fa93fff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
                        0x7fff8faac000 -     0x7fff8fab7fff  libGL.dylib (12.0.40.6) <2A13E40A-BFA1-34FD-925A-C7023FEF254C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                        0x7fff8fb41000 -     0x7fff8fb9efff  com.apple.CoreServices.OSServices (728.6 - 728.6) <CA616ACB-A872-386C-B16D-193A7E495C4D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                        0x7fff8fb9f000 -     0x7fff8fbaeffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <0D1BCC13-76B9-3C19-85AA-D8DD8299F007> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                        0x7fff8fc63000 -     0x7fff8fc6efff  libcsfde.dylib (517.20.1) <42376761-F1B3-3086-AFBC-231507582BBE> /usr/lib/libcsfde.dylib
                        0x7fff8fd5c000 -     0x7fff8fdaafff  libcurl.4.dylib (90) <FF42FAA6-E71B-3D0D-B5C9-B05BD2460C9A> /usr/lib/libcurl.4.dylib
                        0x7fff8fdb1000 -     0x7fff8fdb9fff  libcopyfile.dylib (127) <F5133269-0B22-388C-A57C-079667B6291E> /usr/lib/system/libcopyfile.dylib
                        0x7fff8fdba000 -     0x7fff8fdbdff7  libsystem_sandbox.dylib (460.30.1) <3E0036AF-FC64-3352-8DA4-6B550C2C2562> /usr/lib/system/libsystem_sandbox.dylib
                        0x7fff8fdd1000 -     0x7fff8fe32ff7  libsystem_network.dylib (583.20.10) <865FE79A-A22D-3733-A14F-FC7B37F3AECD> /usr/lib/system/libsystem_network.dylib
                        0x7fff8fe33000 -     0x7fff8fe34ff7  libodfde.dylib (23) <5475AB3E-8C9A-3279-8294-E565293F7EF1> /usr/lib/libodfde.dylib
                        0x7fff8fe5a000 -     0x7fff8feaaff7  com.apple.Symbolication (1.4 - 58044) <2EC9F04A-4370-39C8-8549-FC6411D87463> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                        0x7fff8feab000 -     0x7fff8feacfff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
                        0x7fff901f4000 -     0x7fff90200fff  com.apple.CacheDelete (1.0 - 1) <8B6526D9-2DC5-35AA-A60D-8DCB0B77035E> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
                        0x7fff9062b000 -     0x7fff9063bff3  com.apple.ProtocolBuffer (1 - 242) <127AF54F-615B-362A-A221-3E758C46A235> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                        0x7fff9063c000 -     0x7fff907c8ff7  libGLProgrammability.dylib (12.0.40.6) <60C68BA6-D375-39D5-9ADD-B394FB760A86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                        0x7fff907cf000 -     0x7fff907ecfff  com.apple.pluginkit.framework (1.0 - 1) <AE3DFBE5-A012-345F-8A77-520686B6FBFF> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
                        0x7fff907ed000 -     0x7fff90809ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
                        0x7fff9080a000 -     0x7fff90815ff7  libChineseTokenizer.dylib (16) <998637AB-DC37-3A7C-A85C-F10FD98CAAD7> /usr/lib/libChineseTokenizer.dylib
                        0x7fff9081c000 -     0x7fff9081eff7  libsystem_configuration.dylib (802.20.7) <5FD79070-36CC-3D02-BEA7-BB5D2AE97D5D> /usr/lib/system/libsystem_configuration.dylib
                        0x7fff9081f000 -     0x7fff90846fff  com.apple.shortcut (2.16 - 93) <D9DD2F6A-4AC7-38BD-A3B6-A9682EFCCE2E> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                        0x7fff9088d000 -     0x7fff908fcfff  com.apple.datadetectorscore (7.0 - 460) <CDBB7D7D-B189-37B0-AA4B-DC79090D0D71> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                        0x7fff908fd000 -     0x7fff90907fff  com.apple.KerberosHelper (4.0 - 1.0) <B7669D5E-4113-3160-A465-B4786A4E8850> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
                        0x7fff90b0f000 -     0x7fff90b2eff7  com.apple.framework.Apple80211 (11.0 - 1110.33) <EC583C00-9073-39C3-B613-96D5BA0FDD32> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                        0x7fff90bed000 -     0x7fff90c5bff7  com.apple.ApplicationServices.ATS (377 - 394.3) <0DDD3503-3D74-3CCA-BD25-7F19B03C2579> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                        0x7fff90c5c000 -     0x7fff90cb8fff  com.apple.Suggestions (5.0 - 180) <BCC095D1-3BF6-3AC6-9074-948ECE9885DF> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                        0x7fff90cb9000 -     0x7fff90cbeff7  com.apple.NetFSServer (2.0 - 1) <04A64A5A-2DBA-3925-9670-D3488C7D68AD> /System/Library/PrivateFrameworks/NetFSServer.framework/Versions/A/NetFSServer
                        0x7fff90cf1000 -     0x7fff90dd7fef  unorm8_bgra.dylib (2.6.4.1) <F2A325FF-D55F-3091-88E2-5EBF3648274A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                        0x7fff90dd8000 -     0x7fff90de6ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
                        0x7fff90de7000 -     0x7fff90dfefff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
                        0x7fff90dff000 -     0x7fff90e44ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <72156BE7-0804-3F90-9AF9-14C4739430C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                        0x7fff90e45000 -     0x7fff90e4afff  com.apple.TCC (1.0 - 1) <C53628CA-0C75-34B6-AE6E-8BCF8A3ED099> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                        0x7fff90e4b000 -     0x7fff91014ff7  com.apple.ImageIO.framework (3.3.0 - 1442) <2C8AF87E-080E-3FD8-824D-332B43DF4B61> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                        0x7fff91052000 -     0x7fff910cfff7  com.apple.iLifeMediaBrowser (2.10.1 - 721) <C7081359-4300-3D44-A8AE-143D6E5ED153> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
                        0x7fff910fd000 -     0x7fff9115bfff  com.apple.SystemConfiguration (1.14 - 1.14) <5A70115B-E346-3EBD-A617-9A11C61EEF2E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                        0x7fff9115c000 -     0x7fff911e4fff  com.apple.CoreSymbolication (3.1 - 58048.1) <6436E5E0-B05C-36D6-942A-47026DD2D874> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                        0x7fff911e5000 -     0x7fff91204ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                        0x7fff9120d000 -     0x7fff91291fff  com.apple.AVKit (1.1 - 285.1) <5F49A0E6-0A48-3E15-9864-4F8C296098CB> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
                        0x7fff91292000 -     0x7fff91294fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                        0x7fff912c9000 -     0x7fff912dffff  com.apple.CoreMediaAuthoring (2.2 - 953) <D74307B6-EC7E-3E5F-B2CF-7CE7A183F0F0> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                        0x7fff912f6000 -     0x7fff912f8fff  com.apple.SecCodeWrapper (4.0 - 261.20.7) <E3E10533-B295-39EB-B0A3-42BD238E8C85> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                        0x7fff91318000 -     0x7fff914d8feb  libBLAS.dylib (1159) <943445A4-F6CA-3923-882C-154D7D4AEFE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                        0x7fff914d9000 -     0x7fff914eafff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
                        0x7fff91595000 -     0x7fff91595fff  libOpenScriptingUtil.dylib (169.1) <03BEF6F0-07CD-3EDC-9D11-32202C1857B6> /usr/lib/libOpenScriptingUtil.dylib
                        0x7fff91596000 -     0x7fff9159bfff  com.apple.MediaAccessibility (1.0 - 79) <CCF71DC1-BB6A-3227-BD1B-AFD172592A63> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                        0x7fff9159c000 -     0x7fff915aafff  com.apple.opengl (12.0.40 - 12.0.40) <D37D88AE-0731-3105-99AB-984DA9B9BCE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                        0x7fff915ab000 -     0x7fff915bcff7  libsystem_trace.dylib (201.10.3) <B485369F-E3A1-319E-998C-89AAF606079E> /usr/lib/system/libsystem_trace.dylib
                        0x7fff915d6000 -     0x7fff915dbfff  com.apple.SymptomReporter (1.0 - 1) <99B086A8-9955-3A3B-8D8F-BB9B7742E311> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomReporter.framework /SymptomReporter
                        0x7fff91df9000 -     0x7fff9226aff3  com.apple.GeoServices (1.0 - 1151.2.13.9) <52A8FBB6-267C-3371-A516-264572B5800F> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                        0x7fff922ae000 -     0x7fff922f4ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
                        0x7fff922f5000 -     0x7fff92341ff3  com.apple.HIServices (1.22 - 549) <14FB5BB6-8456-39F9-A694-8A1C12426880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                        0x7fff92342000 -     0x7fff92800fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                        0x7fff92801000 -     0x7fff9280bfff  com.apple.NetAuth (6.0 - 6.0) <19E44307-6F9F-3DEC-8C1A-4685BC252A35> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                        0x7fff92819000 -     0x7fff92abfff7  com.apple.CoreData (120 - 641.3) <65509AA2-A0E6-3EE3-BDFE-B9B120F744ED> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                        0x7fff92ac0000 -     0x7fff92ac8fe7  libsystem_platform.dylib (74.10.3) <D3A27E10-7F08-3603-ACC8-7A92B2C04BAB> /usr/lib/system/libsystem_platform.dylib
                        0x7fff92b4d000 -     0x7fff92b80ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                        0x7fff92c2b000 -     0x7fff92c54fff  libxpc.dylib (756.20.4) <61AB4610-9304-354C-9E9B-D57198AE9866> /usr/lib/system/libxpc.dylib
                        0x7fff93b9e000 -     0x7fff93c74ff7  com.apple.DiskImagesFramework (10.11.3 - 417.2) <25BBE20C-E92B-360F-A326-093B61CC7B5E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                        0x7fff93c75000 -     0x7fff93c86ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
                        0x7fff93c99000 -     0x7fff93ca4ff7  libcommonCrypto.dylib (60075.20.1) <766BC3F5-41F3-3315-BABC-72718A98EA92> /usr/lib/system/libcommonCrypto.dylib
                        0x7fff93ca5000 -     0x7fff93d19fff  com.apple.Heimdal (4.0 - 2.0) <009F223D-B89B-376B-94F5-6D982CBEF771> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                        0x7fff93d1a000 -     0x7fff93ee8ffb  com.apple.QuartzCore (1.11 - 410.14) <CB19502B-D25F-379C-B50F-08A98FF73B68> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                        0x7fff93ee9000 -     0x7fff93eeeff7  libmacho.dylib (875.1) <CB745E1F-4885-3F96-B38B-2093DF488FD5> /usr/lib/system/libmacho.dylib
                        0x7fff93eef000 -     0x7fff93f09ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
                        0x7fff93f0a000 -     0x7fff93f0dff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <2B3F04CE-3C7D-3F51-99F3-C7847D1E4277> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                        0x7fff9413c000 -     0x7fff9415eff7  com.apple.framework.familycontrols (4.1 - 410) <50F14127-3FCC-39A2-9158-5C2581B0FAE3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                        0x7fff9415f000 -     0x7fff9416bff7  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <8B6C0DB6-8744-3AEB-BD00-9FA6967E7125> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                        0x7fff94291000 -     0x7fff94331fff  com.apple.ViewBridge (159 - 159) <A42BD1E4-C838-3135-B00E-8B051E42D5D3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                        0x7fff94332000 -     0x7fff945c2ff7  com.apple.RawCamera.bundle (6.18 - 828) <CB7F6CCD-3753-3147-816A-B613F500AE33> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                        0x7fff945c3000 -     0x7fff945c3ff7  libkeymgr.dylib (28) <09397E01-6066-3179-A50C-2CE666FDA929> /usr/lib/system/libkeymgr.dylib
                        0x7fff945c4000 -     0x7fff945e0fff  com.apple.GenerationalStorage (2.0 - 239) <EE667C63-3ADF-34D3-A8A7-316B66C7E290> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                        0x7fff945e1000 -     0x7fff94c87ffb  com.apple.JavaScriptCore (11601 - 11601.4.2) <33235884-914C-3A2B-AD91-142E5AB8899F> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                        0x7fff94c88000 -     0x7fff94ceffff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <BEC7B27E-8CE8-3DAB-BFDF-6C240C6A4B12> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                        0x7fff94cf0000 -     0x7fff94d0cff7  libsystem_malloc.dylib (67) <9EECAB18-F025-34C4-8E32-7EFFA6720EFC> /usr/lib/system/libsystem_malloc.dylib
                        0x7fff94d95000 -     0x7fff94dc7fff  libTrueTypeScaler.dylib (158.4) <4AEF2CB9-407D-3FEB-B0BD-4DB162EB9519> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                        0x7fff94e3c000 -     0x7fff95121ff3  com.apple.CoreServices.CarbonCore (1136 - 1136) <FFBDE3BF-0BB3-37A2-8A44-6E25284CC348> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                        0x7fff95122000 -     0x7fff9513cfff  com.apple.Kerberos (3.0 - 1) <836358DE-2731-3ACD-98E3-E5FA48917728> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                        0x7fff9513d000 -     0x7fff95156fff  com.apple.CFOpenDirectory (10.11 - 194) <C21F33AA-CD06-3163-A1F3-1D116F788A11> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                        0x7fff95157000 -     0x7fff951edfff  com.apple.ColorSync (4.9.0 - 4.9.0) <8BB8DF19-C24F-39F8-8B90-AD186D74587C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                        0x7fff951ee000 -     0x7fff952a0fff  com.apple.cloudkit.CloudKit (481.8 - 481.8) <E927AE82-8E55-38A4-BE6E-4D0829272653> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                        0x7fff9547f000 -     0x7fff95494fff  com.apple.ToneKit (1.0 - 1) <298E6855-B818-3949-85ED-08CF12ACEE59> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                        0x7fff95495000 -     0x7fff95498fff  libCoreVMClient.dylib (119.5) <CD7DE25C-D7AD-3ECD-BEEC-F57992A4A08E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                        0x7fff95499000 -     0x7fff954aeff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                        0x7fff954fd000 -     0x7fff9556cfff  com.apple.SearchKit (1.4.0 - 1.4.0) <CA50106F-F45A-36AC-AD2B-C3B19F5DD52F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                        0x7fff9556d000 -     0x7fff9559efff  com.apple.GSS (4.0 - 2.0) <25DECD44-0905-3E53-9480-DE7BEB84DB83> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                        0x7fff9559f000 -     0x7fff955a0fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                        0x7fff955a1000 -     0x7fff959a3fff  libLAPACK.dylib (1159) <A333AA38-9C2C-329C-AB92-94774C8264C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                        0x7fff959a4000 -     0x7fff959bbfff  com.apple.ScriptingBridge (1.3.3 - 68) <4C81A32D-9B9F-354F-9857-E5BD0852290A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                        0x7fff959bc000 -     0x7fff9624cff7  libclh.dylib (4.0.3 - 4.0.3) <69B1B4C9-DF93-3CE9-A4E1-CCD0D5F69C4B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                        0x7fff9624d000 -     0x7fff965b8657  libobjc.A.dylib (680) <58CB8CFC-7DBD-3A53-BD72-A42FF799B21E> /usr/lib/libobjc.A.dylib
                        0x7fff965b9000 -     0x7fff965bbfff  libCVMSPluginSupport.dylib (12.0.40.6) <C88875DF-9888-37A6-AE69-3CABFACDAF45> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                        0x7fff96a5d000 -     0x7fff96a69ff7  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <E507D438-517D-32AE-8609-02ACD2F0D692> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                        0x7fff96a9d000 -     0x7fff96aa0ffb  libScreenReader.dylib (425.102) <BDC46586-4925-38F2-85D3-BD23DB6E6D43> /usr/lib/libScreenReader.dylib
                        0x7fff96aa1000 -     0x7fff96aaaff3  libsystem_notify.dylib (150.20.3) <243FADE1-255A-3B78-8033-F336CD64B817> /usr/lib/system/libsystem_notify.dylib
                        0x7fff96abb000 -     0x7fff96ac6fff  com.apple.CommerceCore (1.0 - 459) <4179210D-00E6-397D-AAA3-2A1E9992CB2D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                        0x7fff96ac7000 -     0x7fff96c6effb  com.apple.avfoundation (2.0 - 1046.9.2) <FE83988E-9A6D-3386-ACD7-A0A4D7A006DF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                        0x7fff96c6f000 -     0x7fff96d29fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <C4EC1EA7-E2AA-30F7-83CC-79171CDD50AA> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                        0x7fff96d2a000 -     0x7fff96d2afff  com.apple.ApplicationServices (48 - 48) <DD9C4070-C0FC-3984-BCED-72E6E99838FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                        0x7fff97454000 -     0x7fff97488ff7  com.apple.CoreVideo (1.8 - 191.2) <88D903C8-E608-320E-8ACD-11E5B3003C18> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                        0x7fff9748b000 -     0x7fff9748dfff  com.apple.CoreDuetDebugLogging (1.0 - 1) <B461272B-2DFF-3CA9-8DCA-689B2AAC0379> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                        0x7fff974cc000 -     0x7fff97559dd7  com.apple.AppleJPEG (1.0 - 1) <9F0E8564-FCC4-33BE-9C6A-2BA926A33F6F> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                        0x7fff9755a000 -     0x7fff975e9ff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
                        0x7fff97642000 -     0x7fff9766bfff  libsystem_info.dylib (477.20.1) <6513635B-4ADE-3B45-BF63-ED7AC565B0C9> /usr/lib/system/libsystem_info.dylib
                        0x7fff9766c000 -     0x7fff97670fff  com.apple.CommonPanels (1.2.6 - 96) <61E9D84F-435A-3C7B-A065-047B80775777> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                        0x7fff97671000 -     0x7fff97675fff  libcache.dylib (75) <6B245C0A-F3EA-383B-A542-5B0D0456A41B> /usr/lib/system/libcache.dylib
                        0x7fff976c6000 -     0x7fff976cbfff  com.apple.ImageCapture (9.0 - 9.0) <33F7822F-1124-3D73-AF66-515EA32A4A47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                        0x7fff979bc000 -     0x7fff979bcff7  liblaunch.dylib (756.20.4) <EDF719D6-D2BB-38DD-8C94-4272BEFDA2CD> /usr/lib/system/liblaunch.dylib
                        0x7fff979bd000 -     0x7fff979c6fff  com.apple.icloud.FindMyDevice (1.0 - 1) <BB049D2D-9789-39E8-A09D-D300E7AA94D2> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                        0x7fff979c7000 -     0x7fff979d2fff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                        0x7fff979d3000 -     0x7fff97a25fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <04AB634C-FB23-3538-937C-FF60E5E59DF8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                        0x7fff97a27000 -     0x7fff97a35fff  com.apple.IntlPreferences (2.0 - 192) <CACF49DE-A307-3066-B168-B47DFC531B97> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                        0x7fff97a52000 -     0x7fff97b7eff7  com.apple.CoreText (352.0 - 494.10) <9FD834B1-FF8E-3EB0-BB11-6E9120969086> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                        0x7fff97b7f000 -     0x7fff97b85fff  com.apple.XPCService (2.0 - 1) <9A305622-14E1-3D9A-BE47-6524419BA58D> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                        0x7fff97bee000 -     0x7fff97bf6fff  com.apple.NetFS (6.0 - 4.0) <BDD59EC5-D399-31EA-9B2A-60E3A859FC42> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                        0x7fff97d5f000 -     0x7fff97ebaffb  com.apple.WebKitLegacy (11601 - 11601.4.4) <5CC2787B-FDD4-3025-BD63-4021F97787A8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                        0x7fff97ebb000 -     0x7fff97ebeff7  libCoreFSCache.dylib (119.5) <C7008E64-0AFB-3446-929E-BC3F76DEF049> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                        0x7fff97f2b000 -     0x7fff981c1fff  libmecabra.dylib (696.4) <0A1574F0-3222-3856-A1C6-D8BE20DC4C48> /usr/lib/libmecabra.dylib
                        0x7fff981d8000 -     0x7fff981eeff7  libLinearAlgebra.dylib (1159) <FA316609-9851-3C5C-AF46-685A25768D45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                        0x7fff98227000 -     0x7fff98268ff7  libGLU.dylib (12.0.40.6) <1C9899B5-4741-340F-A2D7-F9AF03B42A47> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                        0x7fff983a7000 -     0x7fff98434fff  libsystem_c.dylib (1082.20.4) <EAB38A6C-8671-3B13-B500-90EC1B912063> /usr/lib/system/libsystem_c.dylib
                        0x7fff9843f000 -     0x7fff98447ff7  libcldcpuengine.dylib (2.6.4.1) <5FFEDBEF-2EFE-3F91-BABC-1E73B28487A2> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                        0x7fff98448000 -     0x7fff98478ff7  libsandbox.1.dylib (460.30.1) <AD0156FC-EF07-3689-9403-586517AE7037> /usr/lib/libsandbox.1.dylib
                        0x7fff98479000 -     0x7fff9847bff7  libquarantine.dylib (80) <163CF63A-7455-3D1F-AE57-8C4475A9204C> /usr/lib/system/libquarantine.dylib
                        0x7fff9847c000 -     0x7fff984b6fff  com.apple.QD (3.12 - 302) <3F36A108-C557-353A-A3F7-80DDCB82BB37> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                        0x7fff984b7000 -     0x7fff984e7ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <C34F0ECF-AABA-3FBC-980F-B4809C9B2DD1> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                        0x7fff984e8000 -     0x7fff98588ff7  com.apple.Metadata (10.7.0 - 972.16) <3E42A570-BE32-396D-96E1-01B4A778D991> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                        0x7fff98589000 -     0x7fff985c6ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                        0x7fff985c7000 -     0x7fff985cafff  com.apple.IOSurface (108.0.1 - 108.0.1) <7B05B27A-5CC4-30D4-8A10-ED444A2807A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                        0x7fff985cb000 -     0x7fff985cbfff  com.apple.Accelerate (1.10 - Accelerate 1.10) <97B71D88-9C93-3943-B09E-642183B4E1AC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                        0x7fff985cc000 -     0x7fff985cdfff  libsystem_secinit.dylib (20) <FD6ECF2C-1489-32CA-981B-9045B5EB1FAA> /usr/lib/system/libsystem_secinit.dylib
                        0x7fff985ce000 -     0x7fff985e7fef  libcompression.dylib (25) <C8546222-B022-39EA-9896-0387BA1D5C51> /usr/lib/libcompression.dylib
                        0x7fff985f5000 -     0x7fff98619ff7  libJPEG.dylib (1442) <0F9069AB-D830-37DD-8813-B635D1ECB3E4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                        0x7fff98840000 -     0x7fff98842fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                        0x7fff98843000 -     0x7fff98c71fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <B8482831-77BD-3FBC-A0B1-12502353AA57> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                        0x7fff98c79000 -     0x7fff98c7bffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
                        0x7fff98c7c000 -     0x7fff98c7cfff  com.apple.CoreServices (728.6 - 728.6) <1FC9300C-6D3D-330C-829C-C8F094BC38C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                        0x7fff98cdf000 -     0x7fff98d49ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <6A535459-6A8A-3D60-986B-EE7ED833A9C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                        0x7fff98d66000 -     0x7fff99989ff7  com.apple.AppKit (6.9 - 1404.34) <467468E2-C551-3408-B351-414B21F57DEB> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x7fff99b17000 -     0x7fff99b3bfff  com.apple.MultitouchSupport.framework (304.10 - 304.10) <1E0206D9-34AD-3810-8ED0-29DC450D1485> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                        0x7fff99b3c000 -     0x7fff99b41ff3  libunwind.dylib (35.3) <124E0F05-2350-3774-A32C-7F5BF38EDE73> /usr/lib/system/libunwind.dylib
                        0x7fff99b42000 -     0x7fff99b43fff  libsystem_blocks.dylib (65) <49D42329-7DE9-3413-92C3-A473A7E9CF35> /usr/lib/system/libsystem_blocks.dylib
                        0x7fff99b55000 -     0x7fff99be4fff  com.apple.CorePDF (4.0 - 4) <6147B89F-46D8-38B2-A7D0-C5AABCE35BC6> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                        0x7fff99be5000 -     0x7fff99bf5fff  libSparseBLAS.dylib (1159) <81330B45-9CA3-34AC-891C-6E770C3DFC24> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                        0x7fff99bf6000 -     0x7fff99bffff7  libsystem_pthread.dylib (138.10.4) <327CECD0-B881-3153-8FCC-4FD4818B7F16> /usr/lib/system/libsystem_pthread.dylib
                        0x7fff99c7d000 -     0x7fff99eeafff  com.apple.imageKit (2.6 - 932) <6738F065-3D55-3165-8D3E-33AA18D6E3EA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                        0x7fff99fbb000 -     0x7fff99fbdff7  com.apple.SafariServices.framework (11601 - 11601.4.4) <FB9EA83E-574E-31D4-AA47-B4EA086BF886> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                        0x7fff99fbe000 -     0x7fff9a09eff7  unorm8_rgba.dylib (2.6.4.1) <6970FC46-0D13-3614-929D-9504AB54C740> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                        0x7fff9a09f000 -     0x7fff9a102fff  libAVFAudio.dylib (161.2) <C42EF0ED-56B2-387F-B188-C42FB8A1B7AB> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                        0x7fff9a103000 -     0x7fff9a105ff7  com.apple.securityhi (9.0 - 55006) <B97C1C77-AA51-33ED-941D-F766BC94CD9E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                        0x7fff9a12d000 -     0x7fff9a17dfff  libcups.2.dylib (435) <28A05475-9DBF-35EA-B218-3432B69EA18B> /usr/lib/libcups.2.dylib
                        0x7fff9a18e000 -     0x7fff9a267fff  com.apple.CoreMedia (1.0 - 1731.15.33) <6109D83B-4E0B-3DE2-9856-9FD80EA51CE0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                        0x7fff9a2df000 -     0x7fff9a2e3fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
                        0x7fff9a2e4000 -     0x7fff9a2e4fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <D2E8EA94-3828-3D7C-87E2-97E4CD00269D> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                        0x7fff9a2e5000 -     0x7fff9a2f4fe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <735A903C-EB3A-32EB-BA6B-C55644C59C5C> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                        0x7fff9a2f5000 -     0x7fff9a350ff7  libTIFF.dylib (1442) <FC2ADE78-3710-31E7-9CE7-44CD61F4B8DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                        0x7fff9a351000 -     0x7fff9a368ff7  libsystem_asl.dylib (322.30.1) <9B500E4E-E462-321E-828E-5524DC984C1B> /usr/lib/system/libsystem_asl.dylib
                        0x7fff9acb4000 -     0x7fff9acb7ff7  com.apple.help (1.3.3 - 46) <62056D9B-A87C-3E4D-B4E2-7E1CDB74CE68> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                        0x7fff9acba000 -     0x7fff9acc8fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
                        0x7fff9acc9000 -     0x7fff9acf7ff7  com.apple.DictionaryServices (1.2 - 250) <D9AB6B92-CAF5-3EC2-8D07-639B42DA1CB9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                        0x7fff9acf8000 -     0x7fff9acf8fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                        0x7fff9acf9000 -     0x7fff9ae43fc7  com.apple.coreui (2.1 - 365.2) <727C55D3-503A-3EC4-8A23-C984E320F65F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                        0x7fff9ae44000 -     0x7fff9ae97ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
                        0x7fff9ae98000 -     0x7fff9aec3ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <D4463131-B469-30B1-84C4-50DB1BAADC32> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                        0x7fff9aec4000 -     0x7fff9af06ff7  com.apple.Metal (55.2.8 - 55.2.8) <D4D7AC6F-7B31-3D94-B4B1-587EC2856CDB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                        0x7fff9afdc000 -     0x7fff9b25cff3  com.apple.security (7.0 - 57337.20.44) <290E0078-464E-30EE-8288-8B29A875FFE3> /System/Library/Frameworks/Security.framework/Versions/A/Security
                        0x7fff9b25d000 -     0x7fff9b272fff  com.apple.AppContainer (4.0 - 261.20.7) <30414623-E68F-31A1-9794-1C052391E900> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                        0x7fff9b273000 -     0x7fff9b29cffb  libRIP.A.dylib (948) <96E8F983-A8BA-3B0F-9035-E09642A63F6E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                        0x7fff9b30b000 -     0x7fff9b324fff  com.apple.openscripting (1.7.1 - 169.1) <F6532253-9EC5-3FF3-AA16-8AE58531B1D1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                        0x7fff9b325000 -     0x7fff9b346fff  com.apple.Sharing (442.9.1 - 442.9.1) <672DE6DF-98E0-30A4-BA25-44BDE188D0BE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                        0x7fff9b347000 -     0x7fff9b34ffff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                        0x7fff9b350000 -     0x7fff9c40fff7  com.apple.WebCore (11601 - 11601.4.4) <815CFF7F-3839-3FDE-9B82-79253BFB3624> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                        0x7fff9c7ba000 -     0x7fff9c7bdfff  com.apple.Mangrove (1.0 - 1) <7919AD18-0EDE-3408-A6AC-A9121B8D857F> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                        0x7fff9c7be000 -     0x7fff9c7d9ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
                        0x7fff9c7da000 -     0x7fff9c8c5ff7  com.apple.QuickLookUIFramework (5.0 - 696.3) <8416C721-85D3-3F4A-9916-2CB4640BB0CB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                        0x7fff9c8c6000 -     0x7fff9cb12ff7  com.apple.AddressBook.framework (9.0 - 1679.4) <B18B0933-04A3-3092-9B33-C9C91AF59E00> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                        0x7fff9cb13000 -     0x7fff9cb42ffb  com.apple.datadetectors (5.0 - 308) <F6564D99-03ED-3F4F-8922-E6D9508DA6F4> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                        0x7fff9cb43000 -     0x7fff9cb71ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <7D0D2C65-C4C4-3FBD-89A7-12302EA444AA> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                        0x7fff9cb72000 -     0x7fff9cba9ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <79D981F2-F70C-3E47-B124-DC0C90D45563> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                        0x7fff9cc0a000 -     0x7fff9cc0afff  libmetal_timestamp.dylib (600.0.43.5) <4BA5B935-F932-3863-9B31-EF0A7DEAF15C> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                        0x7fff9cc15000 -     0x7fff9cc1dfff  libsystem_networkextension.dylib (385.20.6) <DC8A102A-BF02-31A4-8914-65C34DF6B592> /usr/lib/system/libsystem_networkextension.dylib
                        0x7fff9cc1e000 -     0x7fff9cc4dffb  libsystem_m.dylib (3105) <26655445-CA97-321E-B221-801CB378D1AA> /usr/lib/system/libsystem_m.dylib
                        0x7fff9cc51000 -     0x7fff9cc8bff7  com.apple.DebugSymbols (132 - 132) <BDF57386-2881-35BD-9310-36904C764E93> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                        0x7fff9ccad000 -     0x7fff9ccb3ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <FA5CB89A-2BFE-38CC-B1A3-E48792CD898C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                        0x7fff9ccb8000 -     0x7fff9cd5cfff  com.apple.Bluetooth (4.4.3 - 4.4.3f4) <B5F46DA5-EAE8-3F79-864D-1423C61C0A69> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                        0x7fff9cd5d000 -     0x7fff9cda9ff7  com.apple.corelocation (1486.17 - 1615.38) <5AE891F7-ED25-3C6C-A8DD-5D702FB87DC7> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                        0x7fff9cdaa000 -     0x7fff9cdbafff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
                        0x7fff9cdbb000 -     0x7fff9cdc0fff  com.apple.DiskArbitration (2.7 - 2.7) <B7FAE647-156A-30C8-BA8B-69D188D02602> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                        0x7fff9cdc1000 -     0x7fff9cebdff7  libFontParser.dylib (158.4) <BF7F82EB-7820-364A-865E-442F42BFDFA4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                        0x7fff9cff9000 -     0x7fff9cffeff7  libheimdal-asn1.dylib (453.20.2) <EE3DD8E9-E543-3849-ADC9-EDBF2379C97C> /usr/lib/libheimdal-asn1.dylib
                        0x7fff9cfff000 -     0x7fff9d04aff7  com.apple.CoreMediaIO (703.0 - 4791) <A401D0BE-7618-3A75-A77D-2387CF168072> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                        0x7fff9d0ad000 -     0x7fff9d0adfff  com.apple.Cocoa (6.11 - 22) <0A634D46-B468-3CBC-B2A0-16C381C11BF2> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                        0x7fff9d0ea000 -     0x7fff9d1a3ff7  libvMisc.dylib (563.4) <3114F9E9-2B0D-3371-93A1-04BB55CE8DBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                        0x7fff9d1a4000 -     0x7fff9d1a6fff  libCGXType.A.dylib (948) <C3D473CF-7261-3E0D-A161-E9B642B75D6A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                        0x7fff9d261000 -     0x7fff9d2eaff7  com.apple.PerformanceAnalysis (1.0 - 1) <FB33FACE-5A99-34E0-83CC-CEDCCFAC74C3> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                        0x7fff9d715000 -     0x7fff9d715fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <E0D5C411-052F-3B71-9562-C1098FB2F86D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                        0x7fff9d716000 -     0x7fff9d99cff7  com.apple.CFNetwork (760.2.6 - 760.2.6) <653B1552-C1EC-36A5-85D0-9FC3ED3CCF72> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x7fff9d99d000 -     0x7fff9d9effff  com.apple.CloudDocs (1.0 - 383.5) <BBE4C32D-75E6-3EDD-A787-625BDD66DA20> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                        0x7fff9da30000 -     0x7fff9da57fff  com.apple.ChunkingLibrary (167 - 167) <508861C9-F5E6-343B-8DD0-D71DFE49ECFD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                        0x7fff9da58000 -     0x7fff9ddd3ffb  com.apple.VideoToolbox (1.0 - 1731.15.33) <33AED54A-87AE-330F-BAAD-FB8389C3E686> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                        0x7fff9dde5000 -     0x7fff9ddf1fff  com.apple.HelpData (2.1.4 - 90) <3A533F58-9C3B-3341-A8F8-084C96BDB70D> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                        0x7fff9e4a6000 -     0x7fff9e4b4fff  com.apple.ToneLibrary (1.0 - 1) <E92CE7C6-43CB-3312-9B1F-77353FE2C5DD> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                        0x7fff9e51f000 -     0x7fff9e531fff  libsasl2.2.dylib (209) <02BF4226-23E9-34EC-A727-CF0E205395F8> /usr/lib/libsasl2.2.dylib
                        0x7fff9e535000 -     0x7fff9e55aff7  libPng.dylib (1442) <E8391CE4-9B83-3895-A406-D987FC826D4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                        0x7fff9e55e000 -     0x7fff9e5afff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <BB7C0F61-E39B-382C-AF03-1650C054BFE1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                        0x7fff9e5b0000 -     0x7fff9e5b6fff  com.apple.IOAccelerator (205.1 - 205.1) <9B56A248-FA12-3DB9-AD97-51EB4700E8A8> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                        0x7fff9e6ff000 -     0x7fff9e8a5ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <F912765D-88ED-3324-B512-3778A8CE878B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                        0x7fff9e8a6000 -     0x7fff9e9cbff7  com.apple.LaunchServices (728.6 - 728.6) <204CD7A1-D99C-3655-82D7-E8E89F9C666B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                        0x7fff9e9d5000 -     0x7fff9e9e8fff  com.apple.CoreBluetooth (1.0 - 1) <BF5F87E3-6AAA-3B1F-9979-7A03D77937C8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                        0x7fff9ea03000 -     0x7fff9ea04fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
                        0x7fff9ea05000 -     0x7fff9ea06ffb  libremovefile.dylib (41) <B8D1A5FC-CFD5-3AAB-8A10-14DDC129710A> /usr/lib/system/libremovefile.dylib
                        0x7fff9eae1000 -     0x7fff9eb03fff  com.apple.IconServices (68.1 - 68.1) <3ECAA762-1193-3D76-A25F-7680DB3A957E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                        0x7fff9eb08000 -     0x7fff9ebb8fff  com.apple.backup.framework (1.7.2 - 1.7.2) <F6A2F892-0728-3DD6-883C-2CDE789BF26F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                        0x7fff9ecba000 -     0x7fff9f092fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <B43C7811-38A4-3F9A-9417-FD8F4B55EA82> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                        0x7fff9f093000 -     0x7fff9f097fff  libGIF.dylib (1442) <2F7DA684-3510-38C2-B48F-9D33194860A1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                        0x7fff9f098000 -     0x7fff9f09aff7  libRadiance.dylib (1442) <9E9084DC-C0DF-30DF-BD6B-7AED3799A129> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                        0x7fff9f10e000 -     0x7fff9f96cfff  com.apple.GeForceGLDriver (10.8.14 - 10.0.8) <76880827-266C-31E8-812D-4F6650906A79> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                        0x7fff9fb6c000 -     0x7fff9fe61fff  com.apple.HIToolbox (2.1.1 - 807.2) <D9338BEF-CA84-3085-B6CB-4E93B3B9A2E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                        0x7fff9fe9e000 -     0x7fff9fe9eff7  libunc.dylib (29) <1D0F8265-F026-3CBD-93D3-F8DF14FFCE68> /usr/lib/system/libunc.dylib
                        0x7fff9fef4000 -     0x7fff9fef4fff  com.apple.Carbon (154 - 157) <34263101-328D-3FE4-B212-14BD3CFF6965> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                        0x7fff9ff06000 -     0x7fff9ff2fff7  libxslt.1.dylib (14.1) <AE86E275-499F-3D4F-8433-142186D383CB> /usr/lib/libxslt.1.dylib
                        0x7fff9ff30000 -     0x7fff9ff30fff  libenergytrace.dylib (10) <A4AE7CBD-CF0A-3A74-8098-B642CE496611> /usr/lib/libenergytrace.dylib
                        0x7fff9ff31000 -     0x7fff9ff3aff7  com.apple.DisplayServicesFW (3.0 - 378) <E459962E-90C6-36CE-BA30-BC9E29E6C14A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                    External Modification Summary:
                      Calls made by other processes targeting this process:
                        task_for_pid: 53
                        thread_create: 0
                        thread_set_state: 0
                      Calls made by this process:
                        task_for_pid: 0
                        thread_create: 0
                        thread_set_state: 0
                      Calls made by all processes on this machine:
                        task_for_pid: 28696
                        thread_create: 0
                        thread_set_state: 0
                    VM Region Summary:
                    ReadOnly portion of Libraries: Total=462.8M resident=0K(0%) swapped_out_or_unallocated=462.8M(100%)
                    Writable regions: Total=381.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=381.0M(100%)
                                                    VIRTUAL   REGION
                    REGION TYPE                        SIZE    COUNT (non-coalesced)
                    ATS (font support)                32.0M        6
                    ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
                    Accelerate.framework               256K        3
                    Activity Tracing                  2048K        2
                    CG backing stores                 15.6M        5
                    CG image                          2440K       67
                    CG shared images                   336K       10
                    CoreAnimation                      304K       52
                    CoreUI image data                 5680K       33
                    CoreUI image file                  320K        5
                    Dispatch continuations            16.0M        2
                    Foundation                          36K        3
                    IOKit                             15.5M        2
                    Image IO                          5388K        3
                    Kernel Alloc Once                    8K        3
                    MALLOC                           212.1M      204
                    MALLOC guard page                   32K        7
                    Memory Tag 242                      12K        2
                    Memory Tag 251                      12K        2
                    OpenCL                               8K        2
                    OpenGL GLSL                        256K        4
                    Process Corpse Info               2048K        2
                    STACK GUARD                       56.0M       13
                    Stack                             13.2M       18
                    VM_ALLOCATE                       57.3M       30
                    __DATA                            47.3M      343
                    __GLSLBUILTINS                    2588K        2
                    __IMAGE                            528K        2
                    __LINKEDIT                       113.9M       42
                    __TEXT                           348.8M      336
                    __UNICODE                          552K        2
                    mapped file                      237.1M       83
                    shared memory                     16.4M       11
                    TOTAL                              1.2G     1271
                    TOTAL, minus reserved VM space     1.2G     1271
                    System Profile:
                    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.94.136.1a1)
                    Bluetooth: Version 4.4.3f4 16616, 3 services, 27 devices, 1 incoming serial ports
                    Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
                    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
                    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
                    USB Device: USB 2.0 Bus
                    USB Device: Hub
                    USB Device: FaceTime HD Camera (Built-in)
                    USB Device: Hub
                    USB Device: Hub
                    USB Device: Apple Internal Keyboard / Trackpad
                    USB Device: BRCM20702 Hub
                    USB Device: Bluetooth USB Host Controller
                    USB Device: USB 3.0 Bus
                    USB Device: USB Receiver
                    Serial ATA Device: APPLE SSD SM256E, 251 GB
                    Model: MacBookPro10,1, BootROM MBP101.00EE.B0A, 4 processors, Intel Core i7, 2.3 GHz, 8 GB, SMC 2.3f36
                    Network Service: Wi-Fi, AirPort, en0
                    Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
                    Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
                    4. The screenshot
                    • 7. Re: Issue using Fill & Sign in Acrobat Pro DC
                      sangrover Adobe Employee
                      Hi Akshay Raj,
                      Thanks for your quick response. We have started working on finding the root cause of the issue. We would require some more information from your side :
                      1. The logs you shared were for Acrobat process. Could you please also share the logs present for the AcroCEF process as well.
                      2. It appears that the AcroCEF process is in hung state. Could you please sample the process and share the findings with us. To do so, Go to Activity Monitor-->Gear Icon-->Sample process.
                      Thanks and Regards,
                      Sandeep Grover
                      • 8. Re: Issue using Fill & Sign in Acrobat Pro DC
                        Akshay Raj Level 1
                        .HI,
                        I could'nt find any crash/error reports on AcroCEF, but the following is the "sample process"
                        Sampling process 5685 for 3 seconds with 1 millisecond of run time between samples
                        Sampling completed, processing symbols...
                        Analysis of sampling AcroCEF (pid 5685) every 1 millisecond
                        Process:         AcroCEF [5685]
                        Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/MacOS/AcroCEF
                        Load Address:    0x106413000
                        Identifier:      com.adobe.AdobeAcroCEF
                        Version:         15.010.20056
                        Code Type:       X86-64
                        Parent Process:  ??? [1]
                        Date/Time:       2016-02-29 18:30:12.515 +1300
                        Launch Time:     2016-02-28 18:29:34.447 +1300
                        OS Version:      Mac OS X 10.11.3 (15D21)
                        Report Version:  7
                        Analysis Tool:   /usr/bin/sample
                        Call graph:
                            2700 Thread_474770   DispatchQueue_1: com.apple.main-thread  (serial)
                            + 2700 start  (in AcroCEF) + 52  [0x106416864]
                            +   2700 main  (in AcroCEF) + 1533  [0x10643268d]
                            +     2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x15427d  [0x10688627d]
                            +       2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1659b3  [0x1068979b3]
                            +         2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12f68c  [0x10686168c]
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x130071  [0x106862071]
                            +             2700 -[NSApplication run]  (in AppKit) + 682  [0x7fff9923cfc8]
                            +               2700 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:]  (in AppKit) + 454  [0x7fff99613943]
                            +                 2700 _DPSNextEvent  (in AppKit) + 1067  [0x7fff992470ee]
                            +                   2700 _BlockUntilNextEventMatchingListInModeWithFilter  (in HIToolbox) + 71  [0x7fff9fff35af]
                            +                     2700 ReceiveNextEventCommon  (in HIToolbox) + 432  [0x7fff9fff376f]
                            +                       2700 RunCurrentEventLoopInMode  (in HIToolbox) + 235  [0x7fff9fff3935]
                            +                         2700 CFRunLoopRunSpecific  (in CoreFoundation) + 296  [0x7fff89b80338]
                            +                           2700 __CFRunLoopRun  (in CoreFoundation) + 927  [0x7fff89b8093f]
                            +                             2700 __CFRunLoopDoSources0  (in CoreFoundation) + 556  [0x7fff89b8141c]
                            +                               2700 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__  (in CoreFoundation) + 17  [0x7fff89b8f5c1]
                            +                                 2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12f244  [0x106861244]
                            +                                   2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x14caca  [0x10687eaca]
                            +                                     2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12f841  [0x106861841]
                            +                                       2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x154d1c  [0x106886d1c]
                            +                                         2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x154b1e  [0x106886b1e]
                            +                                           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x15498f  [0x10688698f]
                            +                                             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x137932  [0x106869932]
                            +                                               2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x41d3c  [0x106773d3c]
                            +                                                 2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x4200a  [0x10677400a]
                            +                                                   2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x42271  [0x106774271]
                            +                                                     2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x42a11  [0x106774a11]
                            +                                                       2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c06b9f  [0x109338b9f]
                            +                                                         2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c070b2  [0x1093390b2]
                            +                                                           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c06254  [0x109338254]
                            +                                                             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c09655  [0x10933b655]
                            +                                                               2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c0f5d0  [0x1093415d0]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c1ccc4  [0x10934ecc4]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2c1d637  [0x10934f637]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2e29ac2  [0x10955bac2]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2d5084a  [0x10948284a]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2d545a5  [0x1094865a5]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2d546af  [0x1094866af]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2d510ec  [0x1094830ec]
                            +        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2264c18  [0x108996c18]
                            +        2700 _pthread_cond_wait  (in libsystem_pthread.dylib) + 767  [0x7fff9a051150]
                            +        2700 __psynch_cvwait  (in libsystem_kernel.dylib) + 10  [0x7fff8c6b0eb2]
                            2700 Thread_474774   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
                            + 2700 _dispatch_mgr_thread  (in libdispatch.dylib) + 52  [0x7fff8f24ed01]
                            +   2700 _dispatch_mgr_invoke  (in libdispatch.dylib) + 216  [0x7fff8f24f099]
                            +     2700 kevent_qos  (in libsystem_kernel.dylib) + 10  [0x7fff8c6b1ff6]
                            2700 Thread_474799: NetworkConfigWatcher
                            + 2700 thread_start  (in libsystem_pthread.dylib) + 13  [0x7fff9a04e375]
                            +   2700 _pthread_start  (in libsystem_pthread.dylib) + 168  [0x7fff9a050b90]
                            +     2700 _pthread_body  (in libsystem_pthread.dylib) + 131  [0x7fff9a050c13]
                            +       2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1826cb  [0x1068b46cb]
                            +         2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x186824  [0x1068b8824]
                            +                 2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12feb4  [0x106861eb4]
                            +                   2700 -[NSRunLoop(NSRunLoop) runMode:beforeDate:]  (in Foundation) + 270  [0x7fff8e739e61]
                            +                       2700 __CFRunLoopRun  (in CoreFoundation) + 1356  [0x7fff89b80aec]
                            +                         2700 __CFRunLoopServiceMachPort  (in CoreFoundation) + 212  [0x7fff89b81624]
                            +                           2700 mach_msg  (in libsystem_kernel.dylib) + 55  [0x7fff8c6aa7c7]
                            +                             2700 mach_msg_trap  (in libsystem_kernel.dylib) + 10  [0x7fff8c6ab386]
                            2700 Thread_474800: DnsConfigService
                            +               2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12e8f7  [0x1068608f7]
                            +                 2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1aa11d  [0x1068dc11d]
                            +                   2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1ac635  [0x1068de635]
                            +                     2700 kevent  (in libsystem_kernel.dylib) + 10  [0x7fff8c6b1fc6]
                            2700 Thread_474804: Chrome_DBThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b75116  [0x1092a7116]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b74dc8  [0x1092a6dc8]
                            +                     2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12fc2f  [0x106861c2f]
                            2700 Thread_474805: Chrome_FileThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b75126  [0x1092a7126]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b74e48  [0x1092a6e48]
                            2700 Thread_474806: Chrome_FileUserBlockingThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b75133  [0x1092a7133]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b74ec8  [0x1092a6ec8]
                            2700 Thread_474807: Chrome_ProcessLauncherThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b75140  [0x1092a7140]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b74f48  [0x1092a6f48]
                            2700 Thread_474808: Chrome_CacheThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b7514d  [0x1092a714d]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b74fc8  [0x1092a6fc8]
                            2700 Thread_474809: Chrome_IOThread
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b7515a  [0x1092a715a]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2b75048  [0x1092a7048]
                            2700 Thread_474810: IndexedDB
                            2700 Thread_474811: CompositorTileWorker1/43011
                            +         2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x185ca2  [0x1068b7ca2]
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1c383c9  [0x10836a3c9]
                            2700 Thread_474813: AudioThread
                            2700 Thread_474814: BrowserBlockingWorker1/46099
                            +           2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x182ea3  [0x1068b4ea3]
                            +             2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x183956  [0x1068b5956]
                            2700 Thread_474815: NetworkConfigWatcher
                            2700 Thread_474816
                            +       2700 ???  (in AcroCEF)  load address 0x106413000 + 0x11d124  [0x106530124]
                            +         2700 ???  (in AcroCEF)  load address 0x106413000 + 0x10da93  [0x106520a93]
                            +           2700 CefBrowserMessageCenter::DoInLoop()  (in AcroCEF) + 35  [0x106456117]
                            +             2700 rna::messaging::MessageCenter::DoInLoop()  (in AcroCEF) + 61  [0x106526577]
                            +               2700 ???  (in AcroCEF)  load address 0x106413000 + 0x123b2f  [0x106536b2f]
                            2700 Thread_474817
                            +           2700 rna::messaging::ProxyRemoteSender::ProcessRemoteMessages()  (in AcroCEF) + 42  [0x10652dbb4]
                            +             2700 ???  (in AcroCEF)  load address 0x106413000 + 0x3273d  [0x10644573d]
                            2700 Thread_474818
                            +           2700 rna::messaging::MessageRouter::DoInLoop()  (in AcroCEF) + 57  [0x10652b203]
                            2700 Thread_474819: SocketServer
                            +           2700 rna::messaging::SocketServer::DoInLoop()  (in AcroCEF) + 40  [0x1064568ea]
                            +             2700 rna::messaging::SocketWaitForConnection(int, unsigned int)  (in AcroCEF) + 88  [0x106524de7]
                            +               2700 __accept  (in libsystem_kernel.dylib) + 10  [0x7fff8c6b04de]
                            2700 Thread_474831: com.apple.NSEventThread
                            +       2700 _NSEventThread  (in AppKit) + 149  [0x7fff99306065]
                            2700 Thread_474832: handle-watcher-thread
                                            2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2472d7a  [0x108ba4d7a]
                                              2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2472df3  [0x108ba4df3]
                                                2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2473325  [0x108ba5325]
                                                  2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x24780e6  [0x108baa0e6]
                                                    2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x247f3a6  [0x108bb13a6]
                                                      2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x247f0c8  [0x108bb10c8]
                                                        2700 ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x2493168  [0x108bc5168]
                        Total number in stack (recursive counted multiple, when >=5):
                                19       _pthread_body  (in libsystem_pthread.dylib) + 131  [0x7fff9a050c13]
                                19       _pthread_start  (in libsystem_pthread.dylib) + 168  [0x7fff9a050b90]
                                19       thread_start  (in libsystem_pthread.dylib) + 13  [0x7fff9a04e375]
                                14       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1826cb  [0x1068b46cb]
                                13       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x15427d  [0x10688627d]
                                13       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x1659b3  [0x1068979b3]
                                12       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x186824  [0x1068b8824]
                                9       CFRunLoopRunSpecific  (in CoreFoundation) + 296  [0x7fff89b80338]
                                8       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12f68c  [0x10686168c]
                                8       __CFRunLoopRun  (in CoreFoundation) + 1356  [0x7fff89b80aec]
                                8       __CFRunLoopServiceMachPort  (in CoreFoundation) + 212  [0x7fff89b81624]
                                8       mach_msg  (in libsystem_kernel.dylib) + 55  [0x7fff8c6aa7c7]
                                8       mach_msg_trap  (in libsystem_kernel.dylib) + 0  [0x7fff8c6ab37c]
                                7       __psynch_cvwait  (in libsystem_kernel.dylib) + 0  [0x7fff8c6b0ea8]
                                7       _pthread_cond_wait  (in libsystem_pthread.dylib) + 767  [0x7fff9a051150]
                                5       ???  (in Chromium Embedded Framework)  load address 0x106732000 + 0x12fc2f  [0x106861c2f]
                        Sort by top of stack, same collapsed (when >= 5):
                                mach_msg_trap  (in libsystem_kernel.dylib)        21600
                                __psynch_cvwait  (in libsystem_kernel.dylib)        18900
                                kevent  (in libsystem_kernel.dylib)        10800
                                __accept  (in libsystem_kernel.dylib)        2700
                                kevent_qos  (in libsystem_kernel.dylib)        2700
                        Binary Images:
                               0x106413000 -        0x106640fff +com.adobe.AdobeAcroCEF (15.010.20056) <0CAA7E1B-2610-39A6-A60F-673A90FCF5E0> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/MacOS/AcroCEF
                               0x106732000 -        0x10abe8faf +org.chromium.ContentShell.framework (45.0.2454.85 - 2454.85) <96A1CA88-4B1F-3B82-BB58-75ACF7C74542> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
                               0x10b0b7000 -        0x10b0bafff +com.adobe.AdobeCrashReporter (7.2 - 7.2.3) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/Frameworks/AdobeCrashReporter.f ramework/Versions/A/AdobeCrashReporter
                               0x10b0c4000 -        0x10b0fbfff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <4A755EA1-3CF5-32A6-8939-8D2998577406> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                               0x10b126000 -        0x10b13ffff  libexpat.1.dylib (12.20.1) <AA76E4CF-52F5-3CF9-907B-FBB80BAFB125> /usr/lib/libexpat.1.dylib
                            0x7fff6d35d000 -     0x7fff6d394007  dyld (0.0 - ???) <9D05FDF4-65CE-3B53-86D4-ABE1A5BF35F3> /usr/lib/dyld
                            0x7fff89b11000 -     0x7fff89f87fff  com.apple.CoreFoundation (6.9 - 1256.14) <768A7FB7-9143-3148-8591-7C6ED3162D35> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                            0x7fff89fac000 -     0x7fff89fb4fff  com.apple.AppleSRP (5.0 - 1) <25775E90-1DBB-3BFA-B4B4-F8F262B9EC1F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                            0x7fff8a048000 -     0x7fff8a050ffb  libsystem_dnssd.dylib (625.20.4) <945B5FB1-DA91-3D45-A961-A8FAD53C1E7E> /usr/lib/system/libsystem_dnssd.dylib
                            0x7fff8a40f000 -     0x7fff8a4b6fff  com.apple.LanguageModeling (1.0 - 1) <E1E4091D-6CAB-36E0-A206-AAADE69791DC> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                            0x7fff8a4be000 -     0x7fff8a6cbffb  libicucore.A.dylib (551.41) <CFFD7342-A7D6-323A-AC14-B9EECF6EFFED> /usr/lib/libicucore.A.dylib
                            0x7fff8a6cc000 -     0x7fff8a6d7fff  com.apple.AppSandbox (4.0 - 261.20.7) <0CA08EB7-D574-3E2F-A3AE-FEA80FF3F304> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                            0x7fff8a9d2000 -     0x7fff8a9f9fff  com.apple.ProtectedCloudStorage (1.0 - 1) <F9E1BDE2-16AF-34B5-B7FE-127D511BDC9E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                            0x7fff8aa3e000 -     0x7fff8aab2ff3  com.apple.securityfoundation (6.0 - 55126) <11644DA4-F1CF-3FB1-86A0-0DA8E8C27148> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                            0x7fff8aaf1000 -     0x7fff8aaf2ff3  com.apple.print.framework.Print (10.0 - 266) <BF573614-5666-3D16-9D45-4690911F030A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                            0x7fff8ad36000 -     0x7fff8ad52ff7  libextension.dylib (78) <589FA312-F17C-3A8D-986F-FD995D0065D5> /usr/lib/libextension.dylib
                            0x7fff8ad53000 -     0x7fff8ad69ff7  libsystem_coretls.dylib (83.20.8) <75C97D88-0A63-3093-AE83-DE33EB7405CE> /usr/lib/system/libsystem_coretls.dylib
                            0x7fff8b312000 -     0x7fff8c57dffb  com.apple.CoreGraphics (1.600.0 - 948) <A5BCCC6D-D931-360D-BF45-02F5ED4E1773> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                            0x7fff8c5df000 -     0x7fff8c5e3fff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                            0x7fff8c69a000 -     0x7fff8c6b8fff  libsystem_kernel.dylib (3248.30.4) <9CEB6C3B-1CAF-3C32-A9FD-93BC72CBCEA1> /usr/lib/system/libsystem_kernel.dylib
                            0x7fff8cfb9000 -     0x7fff8cfe4ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
                            0x7fff8cfe5000 -     0x7fff8d05cfe7  libcorecrypto.dylib (335.20.1) <C6BD205F-4ECE-37EE-BCAB-A76F39CDCFFA> /usr/lib/system/libcorecrypto.dylib
                            0x7fff8d05d000 -     0x7fff8d0abff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
                            0x7fff8d136000 -     0x7fff8d27bfff  com.apple.QTKit (7.7.3 - 2943) <6DD72D38-9449-3289-904E-B6E148993AA5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                            0x7fff8d30f000 -     0x7fff8d32cff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <2B459E1F-0563-30B2-A04D-CF1793426B66> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                            0x7fff8d33c000 -     0x7fff8d547fff  libFosl_dynamic.dylib (16.24) <363B7CEE-B662-32F3-9D7B-245E64927C35> /usr/lib/libFosl_dynamic.dylib
                            0x7fff8d5a9000 -     0x7fff8d5b0ff7  libcompiler_rt.dylib (62) <D3C4AB40-23B4-3BC6-8C38-5B8758D14E80> /usr/lib/system/libcompiler_rt.dylib
                            0x7fff8d64c000 -     0x7fff8d6e1fff  com.apple.ink.framework (10.9 - 214) <6B573126-A6E9-357F-B36A-AA5BDC0BEAF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                            0x7fff8d70a000 -     0x7fff8d742fff  com.apple.RemoteViewServices (2.0 - 99) <596153FD-3CB9-3FED-9D63-1B73B01AC6DB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                            0x7fff8d743000 -     0x7fff8d8c1fff  com.apple.UIFoundation (1.0 - 436.1) <8C254BB0-1DED-36A2-AAAF-786EB19CCE39> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                            0x7fff8d9b3000 -     0x7fff8d9bbfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <D44F75E7-C679-3C21-AD76-8FA8A2B898F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                            0x7fff8d9bc000 -     0x7fff8d9e8fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <FDCA9F2D-E06A-3DEC-8E1A-7535BAE68B62> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                            0x7fff8d9e9000 -     0x7fff8da35fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <449D8AB5-7891-32D0-9DC5-C90FE10DC0BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                            0x7fff8da36000 -     0x7fff8dc43ff7  com.apple.CoreImage (11.2.0 - 366.2.7) <344F1067-5F52-3626-8F6C-2B678DEB80A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                            0x7fff8dc44000 -     0x7fff8dc89ff3  libFontRegistry.dylib (155.1) <593CC743-3785-3CC5-A229-D3846C51E054> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                            0x7fff8dc8a000 -     0x7fff8dd7cff7  libJP2.dylib (1442) <3B374049-CCA4-3B4D-9517-583F2BF6B77D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                            0x7fff8dfe8000 -     0x7fff8e0f6ff3  com.apple.desktopservices (1.10 - 1.10) <0BAED9FA-EFA5-3DA0-8715-043FD2400B77> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                            0x7fff8e0f7000 -     0x7fff8e64efff  com.apple.MediaToolbox (1.0 - 1731.15.33) <16374746-DF5E-3103-994B-74CF151BD06A> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                            0x7fff8e6ae000 -     0x7fff8ea02ff7  com.apple.Foundation (6.9 - 1256.1) <66106CC9-9D97-3846-88D8-4BF6BB508296> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                            0x7fff8ea03000 -     0x7fff8ea05ff7  com.apple.xpc.ServiceManagement (1.0 - 1) <3777FD15-B6F3-32A2-A8E3-3E8CE3B8D5E7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                            0x7fff8ea1d000 -     0x7fff8ea20fff  libspindump.dylib (197.1) <61EB1BFE-8600-3420-B18E-1541D3C15C5C> /usr/lib/libspindump.dylib
                            0x7fff8f010000 -     0x7fff8f04eff7  libGLImage.dylib (12.0.40.6) <ACC6C7B0-A805-344C-AAC3-BA50780227E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                            0x7fff8f10b000 -     0x7fff8f113fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
                            0x7fff8f11b000 -     0x7fff8f123fff  libGFXShared.dylib (12.0.40.6) <7E84C8A9-40DA-302A-A3DE-9AE3C61A3465> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                            0x7fff8f12a000 -     0x7fff8f23cfef  libvDSP.dylib (563.4) <C069B6A3-D7CD-3B72-918C-15514066A2F3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                            0x7fff8f23d000 -     0x7fff8f246ff7  com.apple.CommonAuth (4.0 - 2.0) <B2CEE6B5-9464-35F2-9339-9F52001C8A27> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                            0x7fff8f247000 -     0x7fff8f274fff  libdispatch.dylib (501.20.1) <324C9189-2AF3-3356-847F-6F4CE1C6E901> /usr/lib/system/libdispatch.dylib
                            0x7fff8f293000 -     0x7fff8f385ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
                            0x7fff8f471000 -     0x7fff8f558ff7  libcrypto.0.9.8.dylib (59) <ED1C2A26-8FFC-30FF-8726-FF952EF94ADF> /usr/lib/libcrypto.0.9.8.dylib
                            0x7fff8f564000 -     0x7fff8f681fff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
                            0x7fff8f682000 -     0x7fff8f683ffb  libSystem.B.dylib (1226.10.1) <5A4257EF-3145-3BB3-87A4-0D2404A9462D> /usr/lib/libSystem.B.dylib
                            0x7fff8f6e5000 -     0x7fff8f6e7fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
                            0x7fff8f6e8000 -     0x7fff8f7d7fff  libxml2.2.dylib (29.2) <F70308DF-313F-334F-8F0E-82E79821583D> /usr/lib/libxml2.2.dylib
                            0x7fff8f7d8000 -     0x7fff8f827ff7  com.apple.opencl (2.6.9 - 2.6.9) <27643341-DC6F-3C2F-8B8B-637061979BF3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                            0x7fff8f828000 -     0x7fff8f833fff  com.apple.DirectoryService.Framework (10.11 - 194) <159606E0-F3AF-36B0-9744-4BFE1DA3EC74> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                            0x7fff8fcec000 -     0x7fff8fcf8ff7  com.apple.OpenDirectory (10.11 - 194) <5409AC27-3B83-3F35-8EB5-51228B4604AE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                            0x7fff8fd27000 -     0x7fff8fd9bfff  com.apple.framework.IOKit (2.0.2 - 1179.20.6) <D92E537D-F96D-39E1-B9AC-9A18943AFCC7> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                            0x7fff8fdab000 -     0x7fff8fdfdfff  com.apple.ImageCaptureCore (7.0 - 7.0) <68537DDB-383F-3D4D-8125-789053333B13> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                            0x7fff8fe02000 -     0x7fff8fe57ff7  com.apple.AE (701 - 701) <FB22BE84-9CB8-36BF-8061-F93D716C0A84> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                            0x7fff8fe6c000 -     0x7fff8fe77fff  libkxld.dylib (3248.30.4) <BAA3DDEC-AD81-3C29-AECC-59E4AD114D3C> /usr/lib/system/libkxld.dylib
                            0x7fff8febd000 -     0x7fff8fec0ffb  libdyld.dylib (360.19) <AA629043-C6F6-32FE-8007-E3478E99ACA7> /usr/lib/system/libdyld.dylib
                            0x7fff8fec1000 -     0x7fff8feeafff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
                            0x7fff8ff03000 -     0x7fff8ff0efff  libGL.dylib (12.0.40.6) <2A13E40A-BFA1-34FD-925A-C7023FEF254C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                            0x7fff8ff98000 -     0x7fff8fff5fff  com.apple.CoreServices.OSServices (728.6 - 728.6) <CA616ACB-A872-386C-B16D-193A7E495C4D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                            0x7fff8fff6000 -     0x7fff90005ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <0D1BCC13-76B9-3C19-85AA-D8DD8299F007> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                            0x7fff900ba000 -     0x7fff900c5fff  libcsfde.dylib (517.20.1) <42376761-F1B3-3086-AFBC-231507582BBE> /usr/lib/libcsfde.dylib
                            0x7fff901b3000 -     0x7fff90201fff  libcurl.4.dylib (90) <FF42FAA6-E71B-3D0D-B5C9-B05BD2460C9A> /usr/lib/libcurl.4.dylib
                            0x7fff90208000 -     0x7fff90210fff  libcopyfile.dylib (127) <F5133269-0B22-388C-A57C-079667B6291E> /usr/lib/system/libcopyfile.dylib
                            0x7fff90211000 -     0x7fff90214ff7  libsystem_sandbox.dylib (460.30.1) <3E0036AF-FC64-3352-8DA4-6B550C2C2562> /usr/lib/system/libsystem_sandbox.dylib
                            0x7fff90228000 -     0x7fff90289ff7  libsystem_network.dylib (583.20.10) <865FE79A-A22D-3733-A14F-FC7B37F3AECD> /usr/lib/system/libsystem_network.dylib
                            0x7fff9028a000 -     0x7fff9028bff7  libodfde.dylib (23) <5475AB3E-8C9A-3279-8294-E565293F7EF1> /usr/lib/libodfde.dylib
                            0x7fff902b1000 -     0x7fff90301ff7  com.apple.Symbolication (1.4 - 58044) <2EC9F04A-4370-39C8-8549-FC6411D87463> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                            0x7fff90302000 -     0x7fff90303fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
                            0x7fff90c44000 -     0x7fff90c60ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
                            0x7fff90c61000 -     0x7fff90c6cff7  libChineseTokenizer.dylib (16) <998637AB-DC37-3A7C-A85C-F10FD98CAAD7> /usr/lib/libChineseTokenizer.dylib
                            0x7fff90c73000 -     0x7fff90c75ff7  libsystem_configuration.dylib (802.20.7) <5FD79070-36CC-3D02-BEA7-BB5D2AE97D5D> /usr/lib/system/libsystem_configuration.dylib
                            0x7fff90ce4000 -     0x7fff90d53fff  com.apple.datadetectorscore (7.0 - 460) <CDBB7D7D-B189-37B0-AA4B-DC79090D0D71> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                            0x7fff90f66000 -     0x7fff90f85ff7  com.apple.framework.Apple80211 (11.0 - 1110.33) <EC583C00-9073-39C3-B613-96D5BA0FDD32> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                            0x7fff91044000 -     0x7fff910b2ff7  com.apple.ApplicationServices.ATS (377 - 394.3) <0DDD3503-3D74-3CCA-BD25-7F19B03C2579> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                            0x7fff9122f000 -     0x7fff9123dff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
                            0x7fff9123e000 -     0x7fff91255fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
                            0x7fff91256000 -     0x7fff9129bff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <72156BE7-0804-3F90-9AF9-14C4739430C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                            0x7fff9129c000 -     0x7fff912a1fff  com.apple.TCC (1.0 - 1) <C53628CA-0C75-34B6-AE6E-8BCF8A3ED099> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                            0x7fff912a2000 -     0x7fff9146bff7  com.apple.ImageIO.framework (3.3.0 - 1442) <2C8AF87E-080E-3FD8-824D-332B43DF4B61> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                            0x7fff91554000 -     0x7fff915b2fff  com.apple.SystemConfiguration (1.14 - 1.14) <5A70115B-E346-3EBD-A617-9A11C61EEF2E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                            0x7fff915b3000 -     0x7fff9163bfff  com.apple.CoreSymbolication (3.1 - 58048.1) <6436E5E0-B05C-36D6-942A-47026DD2D874> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                            0x7fff916e9000 -     0x7fff916ebfff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                            0x7fff91720000 -     0x7fff91736fff  com.apple.CoreMediaAuthoring (2.2 - 953) <D74307B6-EC7E-3E5F-B2CF-7CE7A183F0F0> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                            0x7fff9174d000 -     0x7fff9174ffff  com.apple.SecCodeWrapper (4.0 - 261.20.7) <E3E10533-B295-39EB-B0A3-42BD238E8C85> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                            0x7fff9176f000 -     0x7fff9192ffeb  libBLAS.dylib (1159) <943445A4-F6CA-3923-882C-154D7D4AEFE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                            0x7fff91930000 -     0x7fff91941fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
                            0x7fff919ec000 -     0x7fff919ecfff  libOpenScriptingUtil.dylib (169.1) <03BEF6F0-07CD-3EDC-9D11-32202C1857B6> /usr/lib/libOpenScriptingUtil.dylib
                            0x7fff919ed000 -     0x7fff919f2fff  com.apple.MediaAccessibility (1.0 - 79) <CCF71DC1-BB6A-3227-BD1B-AFD172592A63> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                            0x7fff919f3000 -     0x7fff91a01fff  com.apple.opengl (12.0.40 - 12.0.40) <D37D88AE-0731-3105-99AB-984DA9B9BCE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                            0x7fff91a02000 -     0x7fff91a13ff7  libsystem_trace.dylib (201.10.3) <B485369F-E3A1-319E-998C-89AAF606079E> /usr/lib/system/libsystem_trace.dylib
                            0x7fff92705000 -     0x7fff9274bff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
                            0x7fff9274c000 -     0x7fff92798ff3  com.apple.HIServices (1.22 - 549) <14FB5BB6-8456-39F9-A694-8A1C12426880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                            0x7fff92799000 -     0x7fff92c57fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                            0x7fff92c58000 -     0x7fff92c62fff  com.apple.NetAuth (6.0 - 6.0) <19E44307-6F9F-3DEC-8C1A-4685BC252A35> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                            0x7fff92c70000 -     0x7fff92f16ff7  com.apple.CoreData (120 - 641.3) <65509AA2-A0E6-3EE3-BDFE-B9B120F744ED> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                            0x7fff92f17000 -     0x7fff92f1ffe7  libsystem_platform.dylib (74.10.3) <D3A27E10-7F08-3603-ACC8-7A92B2C04BAB> /usr/lib/system/libsystem_platform.dylib
                            0x7fff92fa4000 -     0x7fff92fd7ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                            0x7fff93082000 -     0x7fff930abfff  libxpc.dylib (756.20.4) <61AB4610-9304-354C-9E9B-D57198AE9866> /usr/lib/system/libxpc.dylib
                            0x7fff93ff5000 -     0x7fff940cbff7  com.apple.DiskImagesFramework (10.11.3 - 417.2) <25BBE20C-E92B-360F-A326-093B61CC7B5E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                            0x7fff940cc000 -     0x7fff940ddff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
                            0x7fff940f0000 -     0x7fff940fbff7  libcommonCrypto.dylib (60075.20.1) <766BC3F5-41F3-3315-BABC-72718A98EA92> /usr/lib/system/libcommonCrypto.dylib
                            0x7fff940fc000 -     0x7fff94170fff  com.apple.Heimdal (4.0 - 2.0) <009F223D-B89B-376B-94F5-6D982CBEF771> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                            0x7fff94171000 -     0x7fff9433fffb  com.apple.QuartzCore (1.11 - 410.14) <CB19502B-D25F-379C-B50F-08A98FF73B68> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                            0x7fff94340000 -     0x7fff94345ff7  libmacho.dylib (875.1) <CB745E1F-4885-3F96-B38B-2093DF488FD5> /usr/lib/system/libmacho.dylib
                            0x7fff94346000 -     0x7fff94360ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
                            0x7fff94593000 -     0x7fff945b5ff7  com.apple.framework.familycontrols (4.1 - 410) <50F14127-3FCC-39A2-9158-5C2581B0FAE3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                            0x7fff945b6000 -     0x7fff945c2ff7  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <8B6C0DB6-8744-3AEB-BD00-9FA6967E7125> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                            0x7fff94a1a000 -     0x7fff94a1aff7  libkeymgr.dylib (28) <09397E01-6066-3179-A50C-2CE666FDA929> /usr/lib/system/libkeymgr.dylib
                            0x7fff94a1b000 -     0x7fff94a37fff  com.apple.GenerationalStorage (2.0 - 239) <EE667C63-3ADF-34D3-A8A7-316B66C7E290> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                            0x7fff950df000 -     0x7fff95146fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <BEC7B27E-8CE8-3DAB-BFDF-6C240C6A4B12> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                            0x7fff95147000 -     0x7fff95163ff7  libsystem_malloc.dylib (67) <9EECAB18-F025-34C4-8E32-7EFFA6720EFC> /usr/lib/system/libsystem_malloc.dylib
                            0x7fff95293000 -     0x7fff95578ff3  com.apple.CoreServices.CarbonCore (1136 - 1136) <FFBDE3BF-0BB3-37A2-8A44-6E25284CC348> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                            0x7fff95579000 -     0x7fff95593fff  com.apple.Kerberos (3.0 - 1) <836358DE-2731-3ACD-98E3-E5FA48917728> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                            0x7fff95594000 -     0x7fff955adfff  com.apple.CFOpenDirectory (10.11 - 194) <C21F33AA-CD06-3163-A1F3-1D116F788A11> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                            0x7fff955ae000 -     0x7fff95644fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8BB8DF19-C24F-39F8-8B90-AD186D74587C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                            0x7fff958ec000 -     0x7fff958effff  libCoreVMClient.dylib (119.5) <CD7DE25C-D7AD-3ECD-BEEC-F57992A4A08E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                            0x7fff95954000 -     0x7fff959c3fff  com.apple.SearchKit (1.4.0 - 1.4.0) <CA50106F-F45A-36AC-AD2B-C3B19F5DD52F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                            0x7fff959c4000 -     0x7fff959f5fff  com.apple.GSS (4.0 - 2.0) <25DECD44-0905-3E53-9480-DE7BEB84DB83> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                            0x7fff959f6000 -     0x7fff959f7fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                            0x7fff959f8000 -     0x7fff95dfafff  libLAPACK.dylib (1159) <A333AA38-9C2C-329C-AB92-94774C8264C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                            0x7fff966a4000 -     0x7fff96a0f657  libobjc.A.dylib (680) <58CB8CFC-7DBD-3A53-BD72-A42FF799B21E> /usr/lib/libobjc.A.dylib
                            0x7fff96a10000 -     0x7fff96a12fff  libCVMSPluginSupport.dylib (12.0.40.6) <C88875DF-9888-37A6-AE69-3CABFACDAF45> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                            0x7fff96eb4000 -     0x7fff96ec0ff7  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <E507D438-517D-32AE-8609-02ACD2F0D692> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                            0x7fff96ef4000 -     0x7fff96ef7ffb  libScreenReader.dylib (425.102) <BDC46586-4925-38F2-85D3-BD23DB6E6D43> /usr/lib/libScreenReader.dylib
                            0x7fff96ef8000 -     0x7fff96f01ff3  libsystem_notify.dylib (150.20.3) <243FADE1-255A-3B78-8033-F336CD64B817> /usr/lib/system/libsystem_notify.dylib
                            0x7fff96f12000 -     0x7fff96f1dfff  com.apple.CommerceCore (1.0 - 459) <4179210D-00E6-397D-AAA3-2A1E9992CB2D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                            0x7fff96f1e000 -     0x7fff970c5ffb  com.apple.avfoundation (2.0 - 1046.9.2) <FE83988E-9A6D-3386-ACD7-A0A4D7A006DF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                            0x7fff970c6000 -     0x7fff97180fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <C4EC1EA7-E2AA-30F7-83CC-79171CDD50AA> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                            0x7fff97181000 -     0x7fff97181fff  com.apple.ApplicationServices (48 - 48) <DD9C4070-C0FC-3984-BCED-72E6E99838FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                            0x7fff978ab000 -     0x7fff978dfff7  com.apple.CoreVideo (1.8 - 191.2) <88D903C8-E608-320E-8ACD-11E5B3003C18> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                            0x7fff97923000 -     0x7fff979b0dd7  com.apple.AppleJPEG (1.0 - 1) <9F0E8564-FCC4-33BE-9C6A-2BA926A33F6F> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                            0x7fff979b1000 -     0x7fff97a40ff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
                            0x7fff97a99000 -     0x7fff97ac2fff  libsystem_info.dylib (477.20.1) <6513635B-4ADE-3B45-BF63-ED7AC565B0C9> /usr/lib/system/libsystem_info.dylib
                            0x7fff97ac3000 -     0x7fff97ac7fff  com.apple.CommonPanels (1.2.6 - 96) <61E9D84F-435A-3C7B-A065-047B80775777> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                            0x7fff97ac8000 -     0x7fff97accfff  libcache.dylib (75) <6B245C0A-F3EA-383B-A542-5B0D0456A41B> /usr/lib/system/libcache.dylib
                            0x7fff97b1d000 -     0x7fff97b22fff  com.apple.ImageCapture (9.0 - 9.0) <33F7822F-1124-3D73-AF66-515EA32A4A47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                            0x7fff97e13000 -     0x7fff97e13ff7  liblaunch.dylib (756.20.4) <EDF719D6-D2BB-38DD-8C94-4272BEFDA2CD> /usr/lib/system/liblaunch.dylib
                            0x7fff97e14000 -     0x7fff97e1dfff  com.apple.icloud.FindMyDevice (1.0 - 1) <BB049D2D-9789-39E8-A09D-D300E7AA94D2> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                            0x7fff97e1e000 -     0x7fff97e29fff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                            0x7fff97e2a000 -     0x7fff97e7cfff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <04AB634C-FB23-3538-937C-FF60E5E59DF8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                            0x7fff97ea9000 -     0x7fff97fd5ff7  com.apple.CoreText (352.0 - 494.10) <9FD834B1-FF8E-3EB0-BB11-6E9120969086> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                            0x7fff97fd6000 -     0x7fff97fdcfff  com.apple.XPCService (2.0 - 1) <9A305622-14E1-3D9A-BE47-6524419BA58D> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                            0x7fff98045000 -     0x7fff9804dfff  com.apple.NetFS (6.0 - 4.0) <BDD59EC5-D399-31EA-9B2A-60E3A859FC42> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                            0x7fff98312000 -     0x7fff98315ff7  libCoreFSCache.dylib (119.5) <C7008E64-0AFB-3446-929E-BC3F76DEF049> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                            0x7fff98382000 -     0x7fff98618fff  libmecabra.dylib (696.4) <0A1574F0-3222-3856-A1C6-D8BE20DC4C48> /usr/lib/libmecabra.dylib
                            0x7fff9862f000 -     0x7fff98645ff7  libLinearAlgebra.dylib (1159) <FA316609-9851-3C5C-AF46-685A25768D45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                            0x7fff9867e000 -     0x7fff986bfff7  libGLU.dylib (12.0.40.6) <1C9899B5-4741-340F-A2D7-F9AF03B42A47> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                            0x7fff987fe000 -     0x7fff9888bfff  libsystem_c.dylib (1082.20.4) <EAB38A6C-8671-3B13-B500-90EC1B912063> /usr/lib/system/libsystem_c.dylib
                            0x7fff9889f000 -     0x7fff988cfff7  libsandbox.1.dylib (460.30.1) <AD0156FC-EF07-3689-9403-586517AE7037> /usr/lib/libsandbox.1.dylib
                            0x7fff988d0000 -     0x7fff988d2ff7  libquarantine.dylib (80) <163CF63A-7455-3D1F-AE57-8C4475A9204C> /usr/lib/system/libquarantine.dylib
                            0x7fff988d3000 -     0x7fff9890dfff  com.apple.QD (3.12 - 302) <3F36A108-C557-353A-A3F7-80DDCB82BB37> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                            0x7fff9890e000 -     0x7fff9893eff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <C34F0ECF-AABA-3FBC-980F-B4809C9B2DD1> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                            0x7fff9893f000 -     0x7fff989dfff7  com.apple.Metadata (10.7.0 - 972.16) <3E42A570-BE32-396D-96E1-01B4A778D991> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                            0x7fff98a1e000 -     0x7fff98a21fff  com.apple.IOSurface (108.0.1 - 108.0.1) <7B05B27A-5CC4-30D4-8A10-ED444A2807A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                            0x7fff98a22000 -     0x7fff98a22fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <97B71D88-9C93-3943-B09E-642183B4E1AC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                            0x7fff98a23000 -     0x7fff98a24fff  libsystem_secinit.dylib (20) <FD6ECF2C-1489-32CA-981B-9045B5EB1FAA> /usr/lib/system/libsystem_secinit.dylib
                            0x7fff98a25000 -     0x7fff98a3efef  libcompression.dylib (25) <C8546222-B022-39EA-9896-0387BA1D5C51> /usr/lib/libcompression.dylib
                            0x7fff98a4c000 -     0x7fff98a70ff7  libJPEG.dylib (1442) <0F9069AB-D830-37DD-8813-B635D1ECB3E4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                            0x7fff98c97000 -     0x7fff98c99fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                            0x7fff98c9a000 -     0x7fff990c8fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <B8482831-77BD-3FBC-A0B1-12502353AA57> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                            0x7fff990d0000 -     0x7fff990d2ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
                            0x7fff990d3000 -     0x7fff990d3fff  com.apple.CoreServices (728.6 - 728.6) <1FC9300C-6D3D-330C-829C-C8F094BC38C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                            0x7fff99136000 -     0x7fff991a0ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <6A535459-6A8A-3D60-986B-EE7ED833A9C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                            0x7fff991bd000 -     0x7fff99de0ff7  com.apple.AppKit (6.9 - 1404.34) <467468E2-C551-3408-B351-414B21F57DEB> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                            0x7fff99f6e000 -     0x7fff99f92fff  com.apple.MultitouchSupport.framework (304.10 - 304.10) <1E0206D9-34AD-3810-8ED0-29DC450D1485> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                            0x7fff99f93000 -     0x7fff99f98ff3  libunwind.dylib (35.3) <124E0F05-2350-3774-A32C-7F5BF38EDE73> /usr/lib/system/libunwind.dylib
                            0x7fff99f99000 -     0x7fff99f9afff  libsystem_blocks.dylib (65) <49D42329-7DE9-3413-92C3-A473A7E9CF35> /usr/lib/system/libsystem_blocks.dylib
                            0x7fff9a03c000 -     0x7fff9a04cfff  libSparseBLAS.dylib (1159) <81330B45-9CA3-34AC-891C-6E770C3DFC24> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                            0x7fff9a04d000 -     0x7fff9a056ff7  libsystem_pthread.dylib (138.10.4) <327CECD0-B881-3153-8FCC-4FD4818B7F16> /usr/lib/system/libsystem_pthread.dylib
                            0x7fff9a4f6000 -     0x7fff9a559fff  libAVFAudio.dylib (161.2) <C42EF0ED-56B2-387F-B188-C42FB8A1B7AB> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                            0x7fff9a55a000 -     0x7fff9a55cff7  com.apple.securityhi (9.0 - 55006) <B97C1C77-AA51-33ED-941D-F766BC94CD9E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                            0x7fff9a584000 -     0x7fff9a5d4fff  libcups.2.dylib (435) <28A05475-9DBF-35EA-B218-3432B69EA18B> /usr/lib/libcups.2.dylib
                            0x7fff9a5e5000 -     0x7fff9a6befff  com.apple.CoreMedia (1.0 - 1731.15.33) <6109D83B-4E0B-3DE2-9856-9FD80EA51CE0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                            0x7fff9a736000 -     0x7fff9a73afff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
                            0x7fff9a73b000 -     0x7fff9a73bfff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <D2E8EA94-3828-3D7C-87E2-97E4CD00269D> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                            0x7fff9a74c000 -     0x7fff9a7a7ff7  libTIFF.dylib (1442) <FC2ADE78-3710-31E7-9CE7-44CD61F4B8DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                            0x7fff9a7a8000 -     0x7fff9a7bfff7  libsystem_asl.dylib (322.30.1) <9B500E4E-E462-321E-828E-5524DC984C1B> /usr/lib/system/libsystem_asl.dylib
                            0x7fff9b10b000 -     0x7fff9b10eff7  com.apple.help (1.3.3 - 46) <62056D9B-A87C-3E4D-B4E2-7E1CDB74CE68> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                            0x7fff9b111000 -     0x7fff9b11ffff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
                            0x7fff9b120000 -     0x7fff9b14eff7  com.apple.DictionaryServices (1.2 - 250) <D9AB6B92-CAF5-3EC2-8D07-639B42DA1CB9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                            0x7fff9b150000 -     0x7fff9b29afc7  com.apple.coreui (2.1 - 365.2) <727C55D3-503A-3EC4-8A23-C984E320F65F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                            0x7fff9b29b000 -     0x7fff9b2eeff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
                            0x7fff9b31b000 -     0x7fff9b35dff7  com.apple.Metal (55.2.8 - 55.2.8) <D4D7AC6F-7B31-3D94-B4B1-587EC2856CDB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                            0x7fff9b433000 -     0x7fff9b6b3ff3  com.apple.security (7.0 - 57337.20.44) <290E0078-464E-30EE-8288-8B29A875FFE3> /System/Library/Frameworks/Security.framework/Versions/A/Security
                            0x7fff9b6b4000 -     0x7fff9b6c9fff  com.apple.AppContainer (4.0 - 261.20.7) <30414623-E68F-31A1-9794-1C052391E900> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                            0x7fff9b762000 -     0x7fff9b77bfff  com.apple.openscripting (1.7.1 - 169.1) <F6532253-9EC5-3FF3-AA16-8AE58531B1D1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                            0x7fff9b77c000 -     0x7fff9b79dfff  com.apple.Sharing (442.9.1 - 442.9.1) <672DE6DF-98E0-30A4-BA25-44BDE188D0BE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                            0x7fff9b79e000 -     0x7fff9b7a6fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                            0x7fff9cc11000 -     0x7fff9cc14fff  com.apple.Mangrove (1.0 - 1) <7919AD18-0EDE-3408-A6AC-A9121B8D857F> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                            0x7fff9cc15000 -     0x7fff9cc30ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
                            0x7fff9cf9a000 -     0x7fff9cfc8ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <7D0D2C65-C4C4-3FBD-89A7-12302EA444AA> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                            0x7fff9cfc9000 -     0x7fff9d000ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <79D981F2-F70C-3E47-B124-DC0C90D45563> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                            0x7fff9d061000 -     0x7fff9d061fff  libmetal_timestamp.dylib (600.0.43.5) <4BA5B935-F932-3863-9B31-EF0A7DEAF15C> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                            0x7fff9d06c000 -     0x7fff9d074fff  libsystem_networkextension.dylib (385.20.6) <DC8A102A-BF02-31A4-8914-65C34DF6B592> /usr/lib/system/libsystem_networkextension.dylib
                            0x7fff9d075000 -     0x7fff9d0a4ffb  libsystem_m.dylib (3105) <26655445-CA97-321E-B221-801CB378D1AA> /usr/lib/system/libsystem_m.dylib
                            0x7fff9d0a8000 -     0x7fff9d0e2ff7  com.apple.DebugSymbols (132 - 132) <BDF57386-2881-35BD-9310-36904C764E93> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                            0x7fff9d104000 -     0x7fff9d10aff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <FA5CB89A-2BFE-38CC-B1A3-E48792CD898C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                            0x7fff9d10f000 -     0x7fff9d1b3fff  com.apple.Bluetooth (4.4.3 - 4.4.3f4) <B5F46DA5-EAE8-3F79-864D-1423C61C0A69> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                            0x7fff9d201000 -     0x7fff9d211fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
                            0x7fff9d212000 -     0x7fff9d217fff  com.apple.DiskArbitration (2.7 - 2.7) <B7FAE647-156A-30C8-BA8B-69D188D02602> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                            0x7fff9d218000 -     0x7fff9d314ff7  libFontParser.dylib (158.4) <BF7F82EB-7820-364A-865E-442F42BFDFA4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                            0x7fff9d450000 -     0x7fff9d455ff7  libheimdal-asn1.dylib (453.20.2) <EE3DD8E9-E543-3849-ADC9-EDBF2379C97C> /usr/lib/libheimdal-asn1.dylib
                            0x7fff9d456000 -     0x7fff9d4a1ff7  com.apple.CoreMediaIO (703.0 - 4791) <A401D0BE-7618-3A75-A77D-2387CF168072> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                            0x7fff9d504000 -     0x7fff9d504fff  com.apple.Cocoa (6.11 - 22) <0A634D46-B468-3CBC-B2A0-16C381C11BF2> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                            0x7fff9d541000 -     0x7fff9d5faff7  libvMisc.dylib (563.4) <3114F9E9-2B0D-3371-93A1-04BB55CE8DBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                            0x7fff9d6b8000 -     0x7fff9d741ff7  com.apple.PerformanceAnalysis (1.0 - 1) <FB33FACE-5A99-34E0-83CC-CEDCCFAC74C3> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                            0x7fff9db6c000 -     0x7fff9db6cfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <E0D5C411-052F-3B71-9562-C1098FB2F86D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                            0x7fff9db6d000 -     0x7fff9ddf3ff7  com.apple.CFNetwork (760.2.6 - 760.2.6) <653B1552-C1EC-36A5-85D0-9FC3ED3CCF72> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                            0x7fff9de87000 -     0x7fff9deaefff  com.apple.ChunkingLibrary (167 - 167) <508861C9-F5E6-343B-8DD0-D71DFE49ECFD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                            0x7fff9deaf000 -     0x7fff9e22affb  com.apple.VideoToolbox (1.0 - 1731.15.33) <33AED54A-87AE-330F-BAAD-FB8389C3E686> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                            0x7fff9e976000 -     0x7fff9e988fff  libsasl2.2.dylib (209) <02BF4226-23E9-34EC-A727-CF0E205395F8> /usr/lib/libsasl2.2.dylib
                            0x7fff9e98c000 -     0x7fff9e9b1ff7  libPng.dylib (1442) <E8391CE4-9B83-3895-A406-D987FC826D4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                            0x7fff9e9b5000 -     0x7fff9ea06ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <BB7C0F61-E39B-382C-AF03-1650C054BFE1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                            0x7fff9ea07000 -     0x7fff9ea0dfff  com.apple.IOAccelerator (205.1 - 205.1) <9B56A248-FA12-3DB9-AD97-51EB4700E8A8> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                            0x7fff9eb56000 -     0x7fff9ecfcff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <F912765D-88ED-3324-B512-3778A8CE878B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                            0x7fff9ecfd000 -     0x7fff9ee22ff7  com.apple.LaunchServices (728.6 - 728.6) <204CD7A1-D99C-3655-82D7-E8E89F9C666B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                            0x7fff9ee2c000 -     0x7fff9ee3ffff  com.apple.CoreBluetooth (1.0 - 1) <BF5F87E3-6AAA-3B1F-9979-7A03D77937C8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                            0x7fff9ee5a000 -     0x7fff9ee5bfff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
                            0x7fff9ee5c000 -     0x7fff9ee5dffb  libremovefile.dylib (41) <B8D1A5FC-CFD5-3AAB-8A10-14DDC129710A> /usr/lib/system/libremovefile.dylib
                            0x7fff9ef38000 -     0x7fff9ef5afff  com.apple.IconServices (68.1 - 68.1) <3ECAA762-1193-3D76-A25F-7680DB3A957E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                            0x7fff9ef5f000 -     0x7fff9f00ffff  com.apple.backup.framework (1.7.2 - 1.7.2) <F6A2F892-0728-3DD6-883C-2CDE789BF26F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                            0x7fff9f111000 -     0x7fff9f4e9fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <B43C7811-38A4-3F9A-9417-FD8F4B55EA82> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                            0x7fff9f4ea000 -     0x7fff9f4eefff  libGIF.dylib (1442) <2F7DA684-3510-38C2-B48F-9D33194860A1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                            0x7fff9f4ef000 -     0x7fff9f4f1ff7  libRadiance.dylib (1442) <9E9084DC-C0DF-30DF-BD6B-7AED3799A129> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                            0x7fff9ffc3000 -     0x7fffa02b8fff  com.apple.HIToolbox (2.1.1 - 807.2) <D9338BEF-CA84-3085-B6CB-4E93B3B9A2E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                            0x7fffa02f5000 -     0x7fffa02f5ff7  libunc.dylib (29) <1D0F8265-F026-3CBD-93D3-F8DF14FFCE68> /usr/lib/system/libunc.dylib
                            0x7fffa034b000 -     0x7fffa034bfff  com.apple.Carbon (154 - 157) <34263101-328D-3FE4-B212-14BD3CFF6965> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                            0x7fffa035d000 -     0x7fffa0386ff7  libxslt.1.dylib (14.1) <AE86E275-499F-3D4F-8433-142186D383CB> /usr/lib/libxslt.1.dylib
                            0x7fffa0387000 -     0x7fffa0387fff  libenergytrace.dylib (10) <A4AE7CBD-CF0A-3A74-8098-B642CE496611> /usr/lib/libenergytrace.dylib
                        Sample analysis of process 5685 written to file /dev/stdout
