8 Replies Latest reply on Feb 18, 2016 3:29 PM by Qwertyfly...
    How to change specific colors to another color in Illustrator javescript
    saranr37921948 Level 1
      From (Specific Color)
      C:85
      Y:50
      M:0
      K:0
      To (Another Color )
      C:50
      Y:100
      M:0
      K:0
        • 1. Re: How to change specific colors to another color in Illustrator javescript
          Qwertyfly... Level 4
          I'm sure to if statement in the modify function could be cleaned up.
          but this should work for you.
          function reColorSelection(){
              var col = new CMYKColor;
              col.cyan = 50;
              col.magenta = 100;
              col.yellow = 0;
              col.black = 0;
              var oldCol = [];
              oldCol.C = 85;
              oldCol.M = 50;
              oldCol.Y = 0;
              oldCol.K = 0;
              oldCol.tolerance = 1;
              var sel = app.activeDocument.selection;
              for(var i=0; i < sel.length; i++){
                  if(sel[i].typename === "CompoundPathItem"){
                      for(var j=0; j< sel[i].pathItems.length; j++){
                          modify(sel[i].pathItems[j]);
                  modify(sel[i]);
              function modify(obj){
                  if(obj.fillColor.cyan >= (oldCol.C-(oldCol.tolerance/2)) && obj.fillColor.cyan < (oldCol.C+(oldCol.tolerance/2))
                      && obj.fillColor.magenta >= (oldCol.M-(oldCol.tolerance/2)) && obj.fillColor.magenta < (oldCol.M+(oldCol.tolerance/2))
                      && obj.fillColor.yellow >= (oldCol.Y-(oldCol.tolerance/2)) && obj.fillColor.yellow < (oldCol.Y+(oldCol.tolerance/2))
                      && obj.fillColor.black >= (oldCol.K-(oldCol.tolerance/2)) && obj.fillColor.black < (oldCol.K+(oldCol.tolerance/2))){
                          obj.filled = true;
                          obj.fillColor = col;
          reColorSelection();
          • 2. Re: How to change specific colors to another color in Illustrator javescript
            karthickm50893796 Level 1
            Hi Qwertyfly
            Hey good to see this  thank u
            But i need one change on it, every time i am selecting objects to change colors,
            is there any other javascript to change colors with out selecting objects??
            • 3. Re: How to change specific colors to another color in Illustrator javescript
              I think this should work
              change this line:
              to this:
              var sel = app.activeDocument.pathItems;
              untested!!
              • 4. Re: How to change specific colors to another color in Illustrator javescript
                gabriels98539908
                Thanks Qwertyfly
                It works out well. But, when we try using this, the stroke and text frame does not get changed as it should have been. It needs to changed as well. Please advise if there is any script or if any changes needs to be made in the given script. I have also attached a sample for easy understanding.
                        col.cyan = 50;
                        col.magenta = 100;
                        col.yellow = 0;
                        col.black = 0;
                        var oldCol = [];
                        oldCol.C = 85;
                        oldCol.M = 50;
                        oldCol.Y = 0;
                        oldCol.K = 0;
                            modify(sel[i]);
                                    obj.filled = true;
                    reColorSelection();
                • 5. Re: How to change specific colors to another color in Illustrator javescript
                  I am also facing same issues !!! It's there any solution
                  stroke and text frame does not get changed color
                  Saran
                  • 6. Re: How to change specific colors to another color in Illustrator javescript
                    it's just a matter of testing for all the items you want changed.
                    Try this...
                        col.cyan = 50;
                        col.magenta = 100;
                        col.yellow = 0;
                        col.black = 0;
                        var oldCol = [];
                        oldCol.C = 85;
                        oldCol.M = 50;
                        oldCol.Y = 0;
                        oldCol.K = 0;
                        var stuff = app.activeDocument.pageItems;
                        for(var i=0; i < stuff.length; i++){
                            if(stuff[i].typename === "CompoundPathItem"){
                                    modify(stuff[i].pathItems[j]);
                            if(stuff[i].typename === "PathItem"||stuff[i].typename === "TextFrame"){
                                modify(stuff[i]);
                            if(obj.typename === "TextFrame"){
                                obj = obj.textRange;
                                    obj.filled = true;
                            if(obj.strokeColor.cyan >= (oldCol.C-(oldCol.tolerance/2)) && obj.strokeColor.cyan < (oldCol.C+(oldCol.tolerance/2))
                                && obj.strokeColor.magenta >= (oldCol.M-(oldCol.tolerance/2)) && obj.strokeColor.magenta < (oldCol.M+(oldCol.tolerance/2))
                                && obj.strokeColor.yellow >= (oldCol.Y-(oldCol.tolerance/2)) && obj.strokeColor.yellow < (oldCol.Y+(oldCol.tolerance/2))
                                && obj.strokeColor.black >= (oldCol.K-(oldCol.tolerance/2)) && obj.strokeColor.black < (oldCol.K+(oldCol.tolerance/2))){
                                    obj.stroked = true;
                                    obj.strokeColor = col;
                    reColorSelection();
                    • 7. Re: How to change specific colors to another color in Illustrator javescript
                      yes this is working thank you very much Qwetyfly
