4 Replies Latest reply on Feb 14, 2016 3:39 AM by Mylenium
    Opencl and XFX R7850
    raul371
      Hello I have a video card XFX 2GB r7800 double disapador
      and not if it is compatible with Adobe Premiere Pro and After Effects
      I have
      my version Adobe After Effects CC 2015 v13.5.0.347
      and executed AEGPUSniffer file is in the folder after effect and displays the following message
      I executed GPUSniffer Premiere Pro folder and displays the following message
      I saw some tuturiales to add my card compatibility list raytracer_supported_cards.txt editing the document is in the folder and after effect cuda_supported_cards.txt document in the premiere pro folder
      but still nothing
      what am I doing wrong
      my video card is not compatible?
        • 1. Re: Opencl and XFX R7850
          It's completely irrelevant for AE. AE doesn't use OpenCL and CUDA is a proprietary nVidia technology. You can hack those text files all day long and all you do is waste your time. For Premiere you might need to fiddle with driver versions or turn off the second GPU.
          Mylenium
          • 2. Re: Opencl and XFX R7850
            raul371 Level 1
            OK as an achievement to be able to use the OpenGL video card with my really need to buy an Nvidia card?
            • 3. Re: Opencl and XFX R7850
              raul371 Level 1
              add a third picture from my after effect
              view data
              Fast Draft:Available
              Texture Memory:812,00 MB
              Ray-tracing:CPU
              (GPU not available - incompatible device or display driver)
              OpenGL
              Vendor:ATI Technologies Inc.
              Device:AMD Radeon HD 7800 Series
              Version:3.0.13416 Compatibility Profile Context 15.300.1025.1001
              Total Memory:1,98 GB
              Shader Model:4.0 or later
              CUDA
              Driver Version:-
              Devices:-
              Current Usable Memory:-
              Maximum Usable Memory:
              • 4. Re: Opencl and XFX R7850
                You are throwing together different, unrelated things. OpenCL is different from OpenGL and both are supported by a variety of cards from intel to AMD to nVidia. Only CUDA definitely requires a supported nVidia card as used by the Raytrace 3D in AE.
                Mylenium
