2 Replies Latest reply on Feb 14, 2016 1:16 PM by caiblack
    toLocaleString
    caiblack Level 1
      I'm trying to create an animated text effect that outputs using the JavaScript "toLocaleString" method of the built-in String class.
      I want to format a numerical value (it's actually a Number in the JavaScript sense) as currency with the currency symbol, commas, and decimal point, but when I use the following command, I only get the raw value:
      [slider value]
      123456.78
      [code]
      A = effect("Slider Control")("Slider").value.toLocaleString( "en-US", { style: "currency", currency: "USD" });
      [output]
      123456.78
      [expected]
      $123,456.78
      Additionally, values greater than 1000000.00 appear to not be supported in the Slider effect. Is this a known and documented issue/feature?
      If there's an alternate way to achieve this effect, then, please, let me know ASAP.
      Thanks.
        • 1. Re: toLocaleString
          Are you talking expressions in After Effects to create a video or are you talking about Web design or some other kind of scripting? Sliders do have a finite value but you can add a multiplier.
          If you're talking expressions then take a look at Dan Ebberts Universal counter. universal counter - Dan Ebberts's Expressioneering Design ...
          I have a highly modified version of that as an aviation preset that I use all the time.
          • 2. Re: toLocaleString
            caiblack Level 1
            Hi, Rick.
            Yes, in After Effects.
            I'll take a look at the Expressioneering link that you suggested. I have an alternate idea that may do what I need, since the "toLocaleString" method doesn't appear to work as-expected.
            Thanks for the swift response.
            [edited]
            It looks like that the "universal counter" link will do what I need it to do. It's only "universal" in the sense that the developer can replace (manually) the currency symbol, comma usage, and decimal places.
            A better resolution would be for Adobe to support the internationalization features available in JavaScript.
