2 Replies Latest reply on Feb 26, 2016 2:59 AM by cédricl67786023
    UVW Materiel artefact when importing with Cineware Plugin
    cédricl67786023
      Hello,
      I have a trouble when I try to use multipass with Cineware plugin.
      I have a simple Cinema 4D scene (made with the Lite version provided with AE), and I want to import the UVW Material pass Inside AE. The Cineware plugin does that but... it totally mess the aliasing. As you can see on the screenshot I have black edges , regarding that, I can't use the UV pass with this big artefact. If I switch to "Draft" renderer in the Cineware plugin,black edges are removed but the UV pass is still not correct because it need anti aliasing on it ! Is there a trick to fix this issue ? Thank you for your help !
