0 Replies Latest reply on Feb 15, 2016 6:04 AM by 2Charlie
    Exception: An error has occured while trying to execute query :LDAP.owl.com:939; socket closed.
    2Charlie Level 1
      I have the following custom-application.cfm file and I kept getting the above error when trying to login.
      <!--- Custom-Application.cfm --->
      <cfparam name="Cas_Server_Secure" default="https://ash.owl.com/cas">
      <!--- <cfparam name="ReturnURL" default="http://#cgi.server_name##cgi.script_name#?#cgi.query_string#"> --->
      <cfparam name="ReturnURL" default="http://#cgi.server_name##cgi.script_name#">
      <cfparam name="Session.CAS" default="">
      <cfparam name="tempMember" default="">
      <cfparam name="strstart" default="0">
      <cfparam name="strend" default="0">
      <cfparam name="teststring" default="">
      <cfparam name="strtotalmember" default="">
      <cfset session.updatedForGolive = 1 >
      <!---include adf core--->
      <cfset request.scriptsExecuted = "">
      <cfinclude template="/ADF/core/load_site_adf.cfm">
          <!--- <cfif not IsDefined("url.ticket") >
          <cfset ReturnURL = URLEncodedFormat(ReturnURL)>
          </cfif> --->
      <cflock scope="Session" type="ReadOnly" timeout="5" throwontimeout="no">
           <cfscript>
            if (not IsStruct(Session.CAS))
                  session.CAS = StructNew();
                  session.CAS.IsAuthenticated = "";
                  //session.CAS.owlTarget = "http://www2.owl.com";
                  session.CAS.owlTarget = URLEncodedFormat(Replace(GetDirectoryFromPath(ReturnURL), "http://www.owl.com/", "http://www2.owl.com/" ));
          //Testing requestTarget
          //needs additional validation
          </cfscript>
      </cflock>
      <cfif not cgi.query_string contains "csModule=security/logout" and not cgi.SCRIPT_NAME contains "/commonspot/" >
          <cfif SERVER_PORT_SECURE eq 1 >
              <cfset ReturnURL ="https://#cgi.server_name##cgi.script_name#">
          </cfif>
      <cfif not FindNoCase("?login=1", ReturnURL) and not FindNoCase("login.cfm", ReturnURL) >
          </cfif>
                      <cfscript>
                          if (not IsDefined("url.ticket")){
                                  Session.CAS.owlTarget = ReturnURL;
                      </cfscript>
          </cflock>
      </cfif>
      <!--- <cfdump var="#session.CAS#"> --->
      <!--- <cfabort> --->
      <cfscript>
      //session.CAS.IsAuthenticated = "";
          //LDAP Starting Point
          LDAP.StartLevel="ou=owl users,dc=owl,dc=com";
          //Active Directory Server or IP Address
          LDAP.Server="cabage.owl.com";
          //LDAP.Server="potato.owl.com";
          //Switch to this when Bob is done
          LDAP.Server="LDAP.owl.com";
          //LDAP Service Port Number
          LDAP.Port="939";
          //LDAP Query Timeout (in seconds)
          LDAP.Timeout="5";
          // what to query for
          strAttributes = "cn,mail,memberOf,dn";
          //LDAP User to run query as ADDED by Bob
          // example: "domainName\userName";
          LDAP.AUser="ldapAuth";
          LDAP.User="tester";
          //Password for LDAP User ADDED by Bob
          LDAP.Password="pass600";
      </cfscript>
      <!--- if we have a url.ticket then we need to get the users userid back from CAS --->
      <cfif isDefined("url.ticket")>
          <!--- Ticket returned from CAS on initial login --->
          <!--- Now we've gotten the service ticket so we must validate it --->
                  <cfset casurl = CAS_Server_Secure & "/serviceValidate?ticket=" & url.ticket & "&service=" & "#Session.cas.owlTarget#">
                  <cfhttp url="#casurl#" method="get" proxyserver="mstmgproxy.owl.com" proxyport="8080"></cfhttp>
                  <!--- Strip out the username that is returned from CAS --->
                  <!--- if ticket has expired.  Send back to CAS to reauthenticate --->
                  <cfif cfhttp.filecontent contains "not recognized">
                       <cflocation url="#Cas_Server_Secure#/login?service=#Session.cas.owlTarget#" addtoken="No">
                  </cfif>
                  <cfscript>
                  myxmldoc = XmlParse(cfhttp.filecontent);
                  selectedElements = XmlSearch(myxmldoc, "cas:serviceResponse/cas:authenticationSuccess/cas:user");
                  if(isArray(selectedElements) AND NOT ArrayIsEmpty(selectedElements)) {
                  //valid ticket found
                  ULuserid = selectedElements[1].XmlText;
                  LDAP.user = #ULuserid#;
                  else
                  //invalid ticket
                  ULuserid = 0;
                  </cfscript>
                      <!--- <cfdump var="#Cas_Server_Secure#/login?service=#ReturnURL#">
                                      <cfabort> --->
              <cfif NOT ULuserid is 0>
                      <!--- User ID returned with CAS Ticket --->
                      <!--- <cfdump var="#ULuserid#">
                                           <cfabort> --->
               <cfset LDAP.User="#ULuserid#">
                      <!--- Available cfldap parameters ACTION,ATTRIBUTES,DELIMITER,FILTER,FILTERFILE,MAXROWS,NAME,PASSWORD,PORT,REBIND,REFERRAL, RETURNASBINARY,SCOPE,SECURE,SEPARATOR,SERVER,SORT,SORTCONTROL,START,STARTROW,TIMEOUT,USERN AME --->.
                          <!--- note removed port attribute??????????? --->
                          <!--- Added application ldapuser and pwd these never change --->
                      <cfldap
                          server = "#LDAP.server#"
                          action = "query"
                          name = "loginResult"
                          start = "#LDAP.startLevel#"
                          attributes = "#strAttributes#"
                          sort = "cn ASC"
                             filter = "cn=#ldap.user#"
                          port = "939"
                          username = "owl\#ldap.auser#"
                          password = "#LDAP.Password#">
                      <cfif loginresult.recordcount>
                          <cfldap
                              action = "query"
                              name = "groupresult"
                              start = "ou=owl groups,dc=owl,dc=com"
                              attributes = "dn,name"
                              sort = "cn ASC"
                              filter = "(&(objectclass=group)(member=#loginResult.dn#))"
                              port = "939"
                      </cfif>
                      <cfif groupresult.recordcount>
                          <cfldap action="query"
                          name="getGroups"
                          attributes="name,memberof"
                          filter="(&(objectclass=group)(member=#loginResult.dn#))"
                          port = "939"
                          sort="cn ASC"
                          separator=";">
                      <cfscript>
                              for ( i=1; i LTE getGroups.RecordCount; i=(i+1)){
                                          teststring = getGroups["memberof"][i];
                                          if ( teststring neq "")
                                                  strstart =0;
                                                  strend=0;
                                                  Do
                                                      if(Findnocase("cn=",teststring,0) neq 0){
                                                      strstart = Findnocase("cn=",teststring,0);
                                                      strend = Findnocase(",",teststring,strstart);
                                                      //Get group
                                                      tempMember = mid(teststring,strstart,strend-strstart);
                                                      teststring = Replace(teststring, tempMember, "");
                                                      strtotalmember = strtotalmember &","& replacenocase(tempMember, "cn=", "");
                                                   While (Findnocase("cn=",teststring,0));
                          strtotalmember    = valuelist(groupresult.name) & strtotalmember;
                          </cfscript>
                      </cfif>
                  <!--- if we found a user and group then authorize the person --->
                  <!--- Requires finding groups --->
                  <!--- <cfif (loginresult.recordcount) and (groupresult.recordcount)> --->
                   <cfif (loginresult.recordcount)>
                          <!--- Fix for Alumni Users with Numeric userids --->
                          <cfif IsNumeric(Mid(ULuserid, 1, 1))>
                              <cfset ULuserid = "owl" & #ULuserid#>
                                      <!--- <cfoutput>#ULuserid#</cfoutput> --->
                              <!--- <cfexit> --->
                          </cfif>
                              <!--- // authorize the user --->
                              <cfmodule template="/commonspot/security/populate-user-struct.cfm"
                                                              defaultUserID = "#ULuserid#"
                                                              defaultGroupNames = "#strtotalmember#"
                                                              defaultGroupIDs = ""
                                                              additionalGroupNames = "#strtotalmember#">
                                  <cfif session.user.LICENSEDCONTRIBUTOR eq 0 >
                                      <cftry>
                                          <CFLOCK SCOPE="Session" TYPE="Exclusive"
                                                  TIMEOUT="5" THROWONTIMEOUT="Yes">
                                              <cfquery DATASOURCE="#session.user.USERSDATASOURCE#" NAME="updateContributor">
                                                 UPDATE Users
                                                 SET LicensedContributor = '1'
                                                 WHERE ID = #session.user.id#
                                              </cfquery>
                                          <cfset session.user.LicensedContributor = "1">
                                          </CFLOCK>
                                      <cfcatch><cfoutput>Error Occurred</cfoutput>
                                      </cfcatch>
                                      </cftry>
                                  </cfif>
                      <!--- We have a valid userid --->
                       <cfscript>
                          session.CAS.IsAuthenticated = "Yes";
                          session.CAS.userid = "#ULuserid#";
                          session.CAS.groups = "#strtotalmember#";
                      </cfscript>
                              <!--- <cfdump var="#session#">
                                          <cfabort> --->
                              <cflocation url="#URLDecode(Session.CAS.owlTarget)#" addtoken="No">
                      <cfelse>
                      <cflocation url="http://#cgi.server_name##request.subsitecache[1].url#restricted.cfm" addtoken="No">
                      </cfif>
              </cfif>
      </cfif>
      </cfif>
      <!--- <cfdump var="#session.user#"> --->
      And this the CommonSpot error log.
      Entry Date/Time: 2016-02-15 06:42:54.873
      >> error processing custom application module (/owl/custom-application.cfm)
      ~~~~~ CommonSpot Instance Details ~~~~~
      Request ID: 18979 (1)
      Request accepted: 2016-02-15 06:42:54
      CommonSpot Build: Build 9.0.1.175
      CFML Engine: ACF
      CFML Engine Version: ColdFusion Server 10.0.15.292620 (Apache Tomcat/7.0.54)
      JVM version: 1.7.0_67-b01 - [64 bits, Windows Server 2008 R2]
      JVM memory (MB):  max:7282 total:2696.5 free:530.23
      CFML Engine Started: 2016-02-12 06:57:23.413 (running for 3 days)
      commonspot.jar: built 2014-10-14 14:20:11
      jar path: C:/owlweb/commonspot/java/commonspot.jar
      Server ID: 1 (Master?:1) Site ID: 1 Subsite ID:5896
      User ID: 0[anonymous] - Groups: 0
      Request (GET) from 172.15.1.225
      Server: www2.owl.com Port: 80 Script: '/computer-science/index.htm'
      Referrer:
      User Agent: Mozilla/5.0 (Windows NT 6.3; WOW64; rv:44.0) Gecko/20100101 Firefox/44.0
      Args: ticket=ST-18814-KuWWvmIRIMzEQavnVDwU-ASH
      Operation: query :LDAP.owl.com:939; socket closed
      Message: An error has occured while trying to execute query :LDAP.owl.com:939; socket closed.
      Type: Application
      Detail: One or more of the required attributes may be missing or incorrect or you do not have permissions to execute this operation on the server.
      Thread 'ajp-bio-8012-exec-2' [ID=77, State='RUNNABLE']
      ... request started at 2016-02-15 06:42:54.763[running 125 milliseconds]
      ...  Request (GET) from 172.15.1.225
      ... Server: www2.owl.com Port: 80 Script: '/computer-science/index.htm'
         ...request mode: : read
      minimized stack with 57 entries
         0: ........coldfusion.tagext.net.LdapTag.doStartTag[ldaptag.java:777]
         1: ........coldfusion.runtime.CfJspPage._emptyTcfTag[cfjsppage.java:2795]
         2: CFM....cfcustom2dapplication2ecfm992673038.runPage[c:/owlweb/owl/custom-application.cfm:1 85]
         6: CFM....cfsite2dapplication2dmeat2ecfm185143928._factor10[{CS Root}/commonspot/startup/site-application-meat.cfm:527]
         7: CFM....cfsite2dapplication2dmeat2ecfm185143928._factor13[{CS Root}/commonspot/startup/site-application-meat.cfm:397]
         8: CFM....cfsite2dapplication2dmeat2ecfm185143928.runPage[{CS Root}/commonspot/startup/site-application-meat.cfm:1]
        13: CFM....cfsite2dapplication2ecfm72844038.runPage[{CS Root}/commonspot/site-application.cfm:23]
        17: CFM....cfApplication2ecfm1010495360.runPage[c:/owlweb/owl/computer-science/application.cf m:13]
