1. Re: Freeze Frame Issue
Dave LaRonde Feb 15, 2016 3:06 PM (in response to NaturalAlias)You aren't thinking about how handy Time Remapping can be in cases like this.
2. Re: Freeze Frame Issue
NaturalAlias Feb 15, 2016 6:47 PM (in response to Dave LaRonde)I tried that as well with the same issue. It takes the clip to another unrelated part of the clip and won't freeze or time map from where the play head is.
3. Re: Freeze Frame Issue
Szalam Feb 17, 2016 9:56 AM (in response to NaturalAlias)Apply Time Remapping.
Make a keyframe where your current time indicator is.
Delete all of the other keyframes.
This will get you a freeze frame at the point your CTI is.
4. Re: Freeze Frame Issue
bogiesan Feb 17, 2016 10:35 AM (in response to NaturalAlias)NaturalAlias wrote:
Is the offset always consistent, the same number of frames or seconds? Is it a multiple of some conversion frame rate? This is often a factor that includes some threes like 1.33 or 0.33. Do the frame rates of your source clip match precisely the frame rate of the project?
