10 Replies Latest reply on Mar 4, 2009 10:40 AM by Joe ... Ward
    Open a ASP file from the server
      I want to open a .asp file in a cromeless window that I have on my server, what do I have to do to get it to work?
      Thanks for your help!
        • 1. Re: Open a ASP file from the server
          tzeng Adobe Employee
          You didn't tell how you normally access the file.
          I assume you use HTTP to access it. You can load it with HTMLloader.
          • 2. Re: Open a ASP file from the server
            Hi tzeng
            Ok, can you please help me getting it to work?
            I open a new window with:
            function anewWindow()
            var options = new air.NativeWindowInitOptions();
            options.systemChrome = "none";
            options.type = "lightweight";
            options.transparent = "true";
            var windowBounds = new air.Rectangle(200,250,480,420);
            var newHTMLLoader = air.HTMLLoader.createRootWindow(
            true, options, true, windowBounds);
            newHTMLLoader.load(new air.URLRequest(" http://www.mydomain.se/air/video.asp?userId=6&id=6"));
            newHTMLLoader.window.opener = window;
            But it only show the background that I have in the video.asp!
            The content from the database is not showed?
            Do I have to set up a bridge in some way? I guess so, but I dont know how?
            • 3. Re: Open a ASP file from the server
              Joe ... Ward Level 4
              You only need to set up a bridge to pass information between the application sandbox and another sandbox.
              What is in the page that's being returned? Is it just HTML + JavaScript?
              Also note that in this case, the statement:
              won't work. Since you are loading a remote page, the anewWindow() fucnction won't be able to access the newHTMLLoader.window property. Also, since loading a page is asynchronous, setting the opener immediately may not work -- you might have to wait for the page complete or load event (sorry if I overlooked that in an earlier reply).
              • 4. Open a ASP file from the server
                Hi Joe...Ward
                Its a flashvideoplayer that Im trying to get and some values from the database.
                Could you please show me an example on what the code should look like? Thanks!
                When I look at the video it works fine in the browser, but it does not show up in the air?
                • 5. Re: Open a ASP file from the server
                  You might hit the bug:
                  SWF content in HTML does not display properly for applications using transparent windows.:
                  http://www.adobe.com/support/documentation/en/air/1_5_1/releasenotes_developers.html#fixed _bugs
                  "options.transparent = "true"; "
                  Should set to false to avoid the bug.
                  • 6. Re: Open a ASP file from the server
                    Ok, thanks ! The video works fine if I use window.open.
                    But how can I get the following to work. Thanks!
                    function openVideoWindow()
                    options.transparent = "false";
                    newHTMLLoader.load(new air.URLRequest(" http://www.manmade.se/icongadgets/admin/video/video2.asp"));
                    • 7. Re: Open a ASP file from the server
                      Set options.transparent to the Boolean value: false (no quotes), not the string value: "false" (with quotes). Other than that, your function ran for me and played the video (I did run it from ActionScript, not HTML, though, but that should work the same).
                      • 8. Re: Open a ASP file from the server
                        Thanks Joe...Ward
                        But with this code it is not working for me?
                        options.systemChrome = "normal";
                        options.transparent = false;
                        and I open the function with:
                        <a href="#" class="video" onClick="openVideoWindow()" title="VIDEO" border="0">testing</a>
                        I never thougt that it would be so hard to open a window the way I want :-)
                        • 9. Open a ASP file from the server
                          Finally it works :-)
                          With options.systemChrome = "none"; it works better! My mistake!
                          So Joe...Ward thanks for your help, lets see if I get it right?
                          If I open a file thats in the application "read_video.html" from the code above (thats in index.html), and have a link to WindowControl.js from "read_video.html" then I will be able to move, close the window and I will have access to the system API!?
                          And in read_video.html I will have an iframe that loads the video2.asp from the server.
                          The iframe code that I have looks like this:
                          <iframe
                          id="iframen"
                          src=" http://www.manmade.se/icongadgets/admin/video/video2.asp"
                          sandboxRoot=" http://www.manmade.se/icongadgets/foo"
                          documentRoot=" http://www.manmade.se/icongadgets/admin/video/"
                          onDOMInitialize="setBridge()"
                          allowCrossDomaininXHR="true">
                          </iframe>
                          Is the iframe code correct?
                          Do I have to have the crome images for the read_video.html window in the application or can I have a background image in the video2.asp that I get from the server?
                          Thanks again!
                          • 10. Re: Open a ASP file from the server
                            Correct.
                            Yes.
                            <iframe
                            id="iframen"
                            </iframe>
                            I don't think you need to set the sandboxRoot or the documentRoot values for this. These are used to map a file from your application into a remote sandbox. (Also, as a general practice, don't set allowCrossDomainXHR true, unless you need to.)
                            If you are using the images as mouse targets to trigger the window management functions, then they need to be in the read_video.html window so that the application sandbox code has access to the mouse events. The background could be from the remote page (assuming the layout works).
