1 Reply Latest reply on Feb 17, 2016 12:06 AM by Mohammad Tahseen
    Remove all old PE 7.0 & 11.0 data
    prohaley
      How do I remove all old PE 7.0 & 11.0 data & files from PC? (I mean everything)  I want to purge the PC prior to reinstalling PE 14.   been having problems trying to capture.  PC want to access PE 7.0 even though it has been uninstalled.   Thanks
        • 1. Re: Remove all old PE 7.0 & 11.0 data
          Mohammad Tahseen Adobe Employee
          Could you please give more details of the problem when you say "PC want to access PE 7.0 even though it has been uninstalled."
          Usually uninstalling a product should handle the problem of purging that product from the machines. Some files specific to that version are still left, but that does not create problem for the installation of the later version of the product. Even then if you want to manually clean those files, then after unstallation of say PRE7, go to following locations and delete those.
          - C:\ProgramData\adobe\Premiere Elements\7.0
          - C:\Users\<username>\AppData\Roaming\Adobe\Premiere Elements\7.0
          And same you can do for PRE11.
          Tahseen
