4 Replies Latest reply on Feb 17, 2016 1:27 PM by runew73276507
    Script which substract current page number with two AND export two separate PDF files got a problem
    runew73276507
      OBS: InDesign CS3 script!
      Ronald63 and Laubender helped me with this script:
      // Number to decrement:
      var nDecrement = 2;
      // pageNumberStart for a section is only valid, when continueNumbering is set to false
      app.documents[0].sections[0].continueNumbering = false;
      var myCurrentNumber = app.documents[0].sections[0].pageNumberStart;
      if(myCurrentNumber>nDecrement+1)
          app.documents[0].sections[0].pageNumberStart = myCurrentNumber - nDecrement
      var doc = app.activeDocument;
      var _PDFExportPreset = app.pdfExportPresets.item('MyDocumentProfile');
      var _DocName = doc.name.replace(/\.indd/, "");
      var _EndNumber = parseInt(_DocName.match(/\d{3}$/),10); /* extract end number */
      /* test if is a number */
      if (isNaN(_EndNumber)){
          alert('End document name is not a number');
          exit();
      for(i = 0; i < doc.pages.length; i++){
          _PageName = doc.pages.item(i).name;
          app.pdfExportPreferences.pageRange = _PageName;
          _NewNumber = _EndNumber + i; /* incresase number */
          _NewNumber = ("00"+_NewNumber).slice(-3); /* padding */
          _DocName = _DocName.replace(/\d{3}$/,_NewNumber); /* replace number in doc name */
          _PDFfile = new File('\\\\testserver\\'.concat(_DocName,'.pdf'));
          doc.exportFile(ExportFormat.pdfType, _PDFfile, false, _PDFExportPreset);
      It got a problem when I have two pages with a frame with content which cross both pages:
      When I run the script I get this result:
      So an empty page and the frame with content is on the other page outside the PB.
      If I delete this part from the script:
      var nDecrement = 2;
      then it works fine
      What am I missing?
