1 Reply Latest reply on Feb 17, 2016 3:31 AM by enilsona52821376
    ALC-DSS-303-014 Subject name and the subject alt name missing.
    enilsona52821376
      I get the following result when using the certify operation on the SignatureService (SOAP)
      <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
         <soapenv:Body>
            <soapenv:Fault>
               <faultcode>soapenv:Server.generalException</faultcode>
               <faultstring>Caused by: com.adobe.livecycle.signatures.client.types.exceptions.PDFOperationException: ALC-DSS-303-002 Could not certify Signature Field signing_slip[0].#subform[0].signature[0] (in the operation : certify)
      Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName); nested exception is:
      Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName)</faultstring>
               <detail>
                  <faultData>
                     <ns1:message xmlns:ns1="http://adobe.com/idp/services">ALC-DSS-303-002 Could not certify Signature Field signing_slip[0].#subform[0].signature[0] (in the operation : certify)
      Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName)</ns1:message>
                  </faultData>
                  <ns2:hostname xmlns:ns2="http://xml.apache.org/axis/">LP00350</ns2:hostname>
               </detail>
            </soapenv:Fault>
         </soapenv:Body>
      </soapenv:Envelope>
      The certificate used has already been used by an older version of our application. We are now using ES4 and calling the  SOAP services directly using Spring-WS. All the other operations work ok, including ReaderExtensions (Reader extensions uses a different certificate, of course).
      Thank you.
