3 Replies Latest reply on Sep 11, 2017 7:47 AM by Idiagram
    Save A copy
    ava74628296 Level 1
      Hi
      I want to save the PDF file, and the file AI file remain active, The method 'saveAs' makes the active PDF file.
      I can do Save A copy?
      Thanks in advance
        • 1. Re: Save A copy
          karthickm50893796
          Hi ava
          Try this one
          try {
            if (app.documents.length > 0 ) {
                  var destFolder = null;
            destFolder =  ('~/desktop');
            if (destFolder != null) {
            var options, i, sourceDoc, targetFile;
                  options = this.getOptions();
            for ( i = 0; i < app.documents.length; i++ ) {
            sourceDoc = app.documents[i];
            targetFile = this.getTargetFile(sourceDoc.name, '.pdf', destFolder);
            sourceDoc.saveAs( targetFile, options );
            alert( 'Documents saved as PDF' );
            else{
            throw new Error('There are no document open!');
          catch(e) {
            alert( e.message, "Script Alert", true);
          function getOptions()
            var options = new PDFSaveOptions();
            return options;
          function getTargetFile(docName, ext, destFolder) {
            var newName = "";
              if (docName.indexOf('.') < 0) {
            newName = docName + ext;
            } else {
            var dot = docName.lastIndexOf('.');
            newName += docName.substring(0, dot);
            newName += ext;
            var myFile = new File( destFolder + '/' + newName );
            if (myFile.open("w")) {
            myFile.close();
            else {
            throw new Error('Access is denied');
            return myFile;
          • 2. Re: Save A copy
            ava74628296 Level 1
            Thanks!
            But it does not work, still active file becomes a PDF file
            • 3. Re: Save A copy
              Idiagram Level 1
              I had the same issue exporting to SVG.  This script works for me: exports as SVG (you can change to PDF), then saves-back the current file to .ai so the current AI file/window doesn't change format.
              // we put the whole program into the function doEverything so that we can use return to terminate execution on an error.
              doEverything();
              function doEverything() {
                 // Export the file to SVG - this will change the current open file from .ai to .svg
                 var dest = app.activeDocument.path + "/" + app.activeDocument.name;
                 exportFileToSVG(dest);
                 // Now save as a .ai file - both to save our work, and to change the open file back to .ai from .svg
                 app.activeDocument.save(dest, SaveOptions.SAVECHANGES );
              // Exports current document to dest as an SVG file with specified
              // options, dest contains the full path including the file name
              // Unfortunately, it still REPLACES the current AI doc with the SVG doc.
              function exportFileToSVG (dest) {
                 if ( app.documents.length > 0 ) {
                 var exportOptions = new ExportOptionsSVG();
                 var type = ExportType.SVG;
                 var fileSpec = new File(dest);
                 exportOptions.embedRasterImages = true;
                 exportOptions.embedAllFonts = false;
                 exportOptions.fontSubsetting = SVGFontSubsetting.GLYPHSUSED;
                 app.activeDocument.exportFile( fileSpec, type, exportOptions );
