2 Replies Latest reply on Feb 21, 2016 11:26 AM by Jim Crabs
    Defects on images uploaded to Lightroom
    Jim Crabs
      I have just uploaded a lot of images from my camera card in Lightroom and a high proportion have thin pink vertical lines on the images.  These lines are not on the images when viewed in camera.  What's going on?
        • 1. Re: Defects on images uploaded to Lightroom
          dj_paige Level 10
          This is a hardware malfunction somewhere in between the camera and your viewing the photo in Lightroom, causing file corruption.
          It could be a bad camera card, bad card reader or bad USB cable/USB port, failing hard drive or faulty memory.
          You need to try doing this transfer of these photos again using different hardware and if possible, transfer to an entirely different computer to see if you can isolate the cause.
          • 2. Re: Defects on images uploaded to Lightroom
            Jim Crabs Level 1
            Hi Thank you very much for your advice, you were quite correct.  I finally isolated the problem to a poor USB port and have now up loaded the images without the earlier defects.  I'm sorry it has taken me longer than I would like to reply to thank you.  It took a bit of trial and error to sort out the defect.
            Thanks again
            Jim.
