• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
QoQ with WHERE clause using a list is breaking
LEGEND ,
Feb 17, 2016 Feb 17, 2016
Hello, all,
I've got a project where I need to use a list as part of the WHERE clause for a QoQ, and it's breaking.  I'm not sure what I'm doing incorrectly.
For some pseudo-code, pretend I have a full query from a database called "people".  I get a list of values for the QoQ with the first query; the second query is my QoQ:
<cfquery name="getDIR" datasource="#request.THISDSN#">
    SELECT thisName dir FROM orgs WHERE thisID in (<cfqueryparam value="#form.org#" cfsqltype="cf_sql_varchar" list="yes" />)
</cfquery>
<cfquery name="people" database="people">
    SELECT colA, colB, colC, colD
    FROM people
    WHERE 1=1
        AND (
            div IN (<cfqueryparam value="#valueList(getDIR.dir)#" cfsqltype="varchar" list="yes" />)
            OR dir IN (<cfqueryparam value="#valueList(getDIR.dir)#" cfsqltype="varchar" list="yes" />)
</cfquery>
The error message I'm getting is "QoQ syntax error: Encountered "div IN \'thisValue\'".  Incorrect conditional expression, Expected one of [like|null|between|in|comparison] condition."
Can QoQ _NOT_ support lists for WHERE clauses?
V/r,
^_^
Views
376
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Feb 17, 2016 Feb 17, 2016
SMH - Nevermind.. I just found it.
I forgot to give the lists in the second query parenthesis.
(The pseudo-code was manually typed, since my dev system is isolated from the internet, and I added them in my pseudo-code when they were not in my original code.)
*headdesk* *headdesk* *headdesk* *headdesk*
V/r,
^_^
Votes
Translate
Translate
LEGEND ,
V/r,
^_^
Votes
Translate
Translate
Report
Report
LEGEND ,
Just for the record:  I DID NOT MARK MY SECOND POST AS THE CORRECT ANSWER.  Someone else did that, and by the time I noticed, it was too late to unmark it as correct.
V/r,
^_^
Votes
Translate
Translate
Report
Report
Guide ,
I did, just to clean the thread.  Probably should have waited. Do you need me to unmark it?
-Carl V. - Moderator
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 18, 2016 Feb 18, 2016
Hi, Carl Von Stetten‌,
Thank you, no.  It is, technically, the correct answer.  I just didn't want anyone to think that I was trying to give unwarranted credit to myself.
V/r,
^_^
Votes
Translate
Translate
Report
Report
Guide ,
Don't worry.  I don't think the forum gives points to self-answered questions.
Votes
Translate
Translate
Report
Report
LEGEND ,
It wasn't the points that I was worried about, it was the perception.  Don't want to be "that guy".
V/r,
^_^
Votes
Translate
Translate
Report
Report
Guide ,
No worries.  I think people would rather see the solution quickly than wade through all the thread replies to find the answer, even if the OP is the one who answers the question.
Also, if anyone posts a question that turns out to be a PEBKAC issue, you can delete the question if you don't think anyone else will encounter the same issue the same way.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Oh, I definitely felt quite eye dee ten tee, after I discovered the truth.  But just in case someone else has the same issue.. (shrug)
V/r,
^_^
Votes
Translate
Translate
Report
Report
Resources
Documentation
