0 Replies Latest reply on Feb 17, 2016 11:14 AM by srinath2785
    cfgrid missing columns
    srinath2785
      Below is my current code, i recently changed the format set to html from flash to render in html.
      but i noticed from the time, i changed the format = html, the first and last row columns are not showing or generating,
      so when i run the below code, im only seeing the Step, Operation, RevCode columns, but not the KeyID or StatusID columns.
      what am i doing it wrong.
      But when i set the format = "flash" everything works fine, im able to get all the columns correctly displayed.
      <cfgrid name="Setup_grid" height="200" width="900" align="LEFT" autoWidth="yes"
          query="Finalquery"
          insert="No" delete="No" sort="Yes" fontsize="14"
          bold="No" italic="No" appendkey="Yes"
          griddataalign="LEFT" gridlines="Yes"
          rowheaders="Yes" rowheaderalign="CENTER" rowheaderitalic="No" rowheaderbold="No"
          colheaders="Yes" colheaderalign="CENTER" colheaderfont="Arial" colheaderfontsize="12"
          colheaderitalic="No" colheaderbold="Yes"
          selectmode="Row" picturebar="Yes"
          format="html" >
          <cfgridcolumn name = "KeyID" Header="Key ID" bold = "No" italic = "No" select = "Yes" display = "Yes" headerBold = "Yes" headerItalic = "No" width = "75">
          <cfgridcolumn name = "Step" dataAlign = "LEFT" bold = "No" italic = "No" select = "No" display = "Yes" headerBold = "Yes" headerItalic = "No" width = "75">
          <cfgridcolumn name = "Operation" dataAlign = "LEFT" bold = "No" italic = "No" select = "No" display = "Yes" headerBold = "Yes" headerItalic = "No" width = "75">
          <cfgridcolumn name = "RevCode" display = "No">
          <cfgridcolumn name = "StatusID" display = "No">
      </CFGRID>
      document.getElementById("Setup_grid").setAttribute("type", "application/xhtml xml");
      </script>
