1 Reply Latest reply on Feb 17, 2016 8:14 PM by CalebEverett
    How to Send File for Download to Browser from /agreements/{agreementId}/combinedDocument
    CalebEverett Level 1
      I am trying to create a file from the body of the response, but it is creating a file that I can't open. It requires a password even though there isn't one on the file. I think this must have something to do with the encoding / decoding.
      I am using a node express server. Here are the few lines of code I am using:
          var request = require('request');
          request({
              baseUrl: 'https://api.na1.echosign.com/api/rest/v5',
              url: '/agreements/' + req.params.id + '/combinedDocument',
              headers: {'Access-Token': process.env.ECHOSIGN_INTEGRATIONKEY}
            function(error, response, body){
              console.log(request.url);
              if(error) {
                res.send(error);
              else {
                console.log(response.headers);
                var buf = new Buffer(body)
                res.set({
                  'Content-Disposition': 'attachment; filename=test.pdf',
                  'Content-Type': 'application/pdf; charset=utf-8'
                 res.write(buf);
                 res.end();
        • 1. Re: How to Send File for Download to Browser from /agreements/{agreementId}/combinedDocument
          This is what ended up working in the end in case somebody else stumbles across this. I think the problem was that the data being returned from the API is a stream and it needed to have the chunking logic and then get concatenated in order to avoid getting corrupted.
          Also included is encoding to base64, pushing it into a database and then getting it back, decoding it and pushing it to the browser. I wasn't going to leave it like that, but had it set up that way to test the full cycle.
              router.get('/echosign/agreement/:id', function(req, res) {
                if (req.user !== 'myUserId') {
                  console.log(req.user);
                  res.redirect('/');
                } else {
                  var data = [];
                  request({
                  }).on('data', function(chunk){
                      data.push(chunk);
                    .on('end', function(){
                      data = Buffer.concat(data).toString('base64');
                      client.connect(function(err) {
                        if(err) {
                          return console.error('could not connect to postgres', err);
                        client.query("UPDATE agreements SET file = '" + data + "' WHERE agreementid = '" + req.params.id + "' RETURNING agreement, file", function(err, result) {
                          if(err) {
                            return console.log(result, err);
                          client.end();
                          res.set({
                            'Content-Type': 'application/pdf;charset=UTF-8',
                            'Content-Disposition': "inline; filename='" + result.rows[0].agreement.name + ".pdf'"
                          res.send(new Buffer(result.rows[0].file, 'base64'));
