1 Reply Latest reply on Feb 18, 2016 7:59 AM by Szalam
    Memory Issues in AE when rendering
    Jimmy Harmless
      Any help here? Rendering 5K RED footage to prores LT 5K. Knoll Lighting Effects EZ Red Giant plugin. Not many layers.
      Top spec iMac 5K Latest Adobe Updates for AE and Pr.
      Help...
      Does about 20 frames and then this message:
      29 of 32 GB RAM allocated - no other programs running.
      The RAM mnitor shows it clime steadily each frame until it runs out and the error message comes up:
        • 1. Re: Memory Issues in AE when rendering
          You're using AE version 13.7, right?
          Try using version 13.2 (CC 2014)
          AE CC 2015 is the first step in a major re-architecture, separating the renderer from the UI for the first time in AE's 20+ year history. This is a big job and it's clearly still in progress. It's a necessary step for improving After Effects performance, but it's taking a while (and multiple versions) for them to get through it. So, during this time of transition as they're introducing elements of the new architecture, sometimes it may be easier to use the older version to get a job done. And, don't worry, AE CC 2014 opens projects created in AE CC 2015 with no problems.
          How to Find and Install Previous Version of Adobe Apps in CC 2015
          I usually do most of my work in CC 2015 because the interface is so much snappier and then I render in CC 2014 to take advantage of multiprocessing.
