3 Replies Latest reply on Feb 18, 2016 9:44 AM by pixxxel schubser
    Set Opacity of an image loaded into Photoshop
    jameel flex Level 1
      I am trying to load an image into Photoshop and set it's opacity to 60% but it's not working.
      I even tried to set the layer opacity but couldn't get it work.
      Please suggest where I am doing the mistake.
      Below is my code.
      var fileRef = new File(imagepath);
        var curRefDoc = app.open(fileRef);
        var curw = curRefDoc.width;
        var curh = curRefDoc.height;
          var resW;
          var resH;
          var scw =  imgObj.wi/curw;
          var sch =  imgObj.hi/curh;
          var scale ;
          if(scw > sch)
              scale = scw;
          else
              scale = sch;
          resW = curw * scale;
          resH = curh * scale;
        if(imgObj.isAdjustImage == "true")
        resW = resW * parseFloat (imgObj.scaleOrg);
        resH = resH * parseFloat (imgObj.scaleOrg);
      curRefDoc.selection.selectAll();
        curRefDoc.resizeImage( resW,resH );
        if(imgObj.isAdjustImage == "true"){
        curRefDoc.rotateCanvas(Number(imgObj.imgRotation));
        if(imgObj.isImgHFlipped == "true" && imgObj.isImgVFlipped == "false")
             curRefDoc.flipCanvas(Direction.HORIZONTAL);
        if(imgObj.isImgVFlipped == "true" && imgObj.isImgHFlipped == "false")
             curRefDoc.flipCanvas(Direction.VERTICAL);
        curRefDoc.activeLayer.opacity = 60;
        * Added_SB(11032011):
        * New selection / copy / paste logic for opened image.
        var DPI = changedDPI;
        var offsetX = (imgObj.moveX * DPI) / 72;
        var offsetY = (imgObj.moveY * DPI) / 72;
        var iW = imgObj.innerImageWidth;
        var iH = imgObj.innerImageHeight;
        var sL = Math.abs(offsetX);
        var sT = Math.abs(offsetY);
        var sR = Number(imgObj.wi) - (offsetX>0 ? sL : -sL);
        var sB = Number(imgObj.hi) - (offsetY>0 ? sT : -sT);
        var selectionArray = Array (
        Array(offsetX>0 ? 0 : sL, offsetY>0 ? 0 : sT),
        Array(sR, offsetY>0 ? 0 : sT),
        Array(sR, sB),
        Array(offsetX>0 ? 0 : sL, sB));
        curRefDoc.selection.select (selectionArray, SelectionType.EXTEND, 0, false);
        curRefDoc.selection.copy();
        curRefDoc.close(SaveOptions.DONOTSAVECHANGES);
        var curDoc = getCurDoc(mainAppName);
        app.activeDocument = curDoc;
        curDoc.paste();
