6 Replies Latest reply on Feb 19, 2016 8:18 AM by Captiv8r
    RoboHelp 10 error - could not rename file
    BainK
      I am trying to update a RoboHelp 10 project. When I make a change to a file and try to save it, I get this error: Could not rename file. xxxx<filename>.htm# to xxx<filename>.htm.
      It seems to think the original filename is a .htm#. But the topic properties say the filename is just .htm.
      I did get a new PC and backed up this project and then downloaded it to my new PC's hard drive. Could something have gotten corrupted?
      Thank you,
      Kathleen
        • 1. Re: RoboHelp 10 error - could not rename file
          Hi Kathleen
          Can you provide more detail?
          For example, how exactly are you attempting to rename? Be specific.
          Also, if you could provide some screen shots, that would be helpful as well.
          Cheers... Rick
          • 2. Re: RoboHelp 10 error - could not rename file
            BainK Level 1
            Below is a screen of the error message I get. I don't know why it is inserting the # sign when I try to save. The files in the project do not have # signs in them.
            I am not trying to rename. I am just trying to save after changing a file. I was able to change one file and save it fine. Then when I went to others it would not let me save. When I went back to the first file I successfully updated and saved, and made a small change and tried to save it, it gave me this error.
            • 3. Re: RoboHelp 10 error - could not rename file
              Jeff_Coatsworth Adobe Community Professional & MVP
              OK, that is one super-long path name there – I think you’re getting a Windows message, not a RH one (just from the appearance). You might want to shorten your path down by taking a copy & placing it in something like “c:\projects\proj_name”
              • 4. Re: RoboHelp 10 error - could not rename file
                BainK Level 1
                I would agree, but I have been working with this project for 6 months and it has not been a problem. I have another project with a similar pathname and it has not been a problem.
                • 5. Re: RoboHelp 10 error - could not rename file
                  You mentioned you changed machines – do you have full rights to the folders in question? Any source control at play too?
                  • 6. Re: RoboHelp 10 error - could not rename file
                    That has to qualify for the gnarliest path I've seen this year!
                    What if you try to rename it to something completely different? XXX.htm? Then rename it back to what you want.
                    Question here. When you view this file using Windows Explorer, does it also display the trailing hash?
                    My thought here is that if not, it's an indication that something is a bit extra crispy inside RoboHelp.
                    One way to overcome this situation would involve using Windows Explorer to make a copy of your project/ (The link below shows you how to simply view your project location using Windows Exploer)
                    Click here to view
                    From Explorer, make a copy of the topic and rename it. Then go back to RoboHelp and see if it will allow you to delete the topic. If so, delete it and import the copy into RoboHelp.
                    Cheers... Rick
