1 Reply Latest reply on Feb 21, 2016 11:40 AM by kajzica
    Help with modifying script - export areas between guides (layers) to images but with new (trimmed) dimension in file name...
    kajzica Level 1
      Hi
      I have script which make layers from area between guides. We need this for split book cover to back, spine and front images.
      We put 2 guides around spine. After running script we have in layers palette layer 1, layer 2, layer 3 and background.
      Need modified script to:
      1. make layers from guides (work)
      2. export this new layers to files without background (source) layer but that script use original file name as base, layer 1 name to have name back, layer 2 name to have name spine, layer 3 name to have name front, AND to put as suffix dimension in cm with one decimal space.
      example, to tif:
      Picture.tif
        Picture_back_20,1_x_30,5cm.tif (from layer 1)
        Picture_spine_3,4_x_30,5cm.tif (from layer 2)
        Picture_front_20,1_x_30,5cm.tif (from layer 3)
      // split layer with layer mask according to guides;
      // 2015, use it at your own risk;
      #target photoshop
      if (app.documents.length > 0) {
      var myDocument = app.activeDocument;
      var myResolution = myDocument.resolution;
      var theLayer = myDocument.activeLayer;
      var layerID = getLayerId(theLayer);
      var originalRulerUnits = app.preferences.rulerUnits;
      app.preferences.rulerUnits = Units.POINTS;
      // check guides;
      var theVer = new Array;
      var theHor = new Array;
      var theNumber = myDocument.guides.length;
      for (var m = 0; m < theNumber; m++) {
      if (myDocument.guides[m].direction == Direction.HORIZONTAL) {theHor.push(myDocument.guides[m].coordinate)};
      if (myDocument.guides[m].direction == Direction.VERTICAL) {theVer.push(myDocument.guides[m].coordinate)};
      // sort and add beginning and end;
      theHor = treatGuideArray (theHor, app.activeDocument.height);
      theVer = treatGuideArray (theVer, app.activeDocument.width);
      $.writeln(theHor.join("\n")+"\n\n\n"+theVer.join("\n"));
      // create selections;
      for (var y = 0; y < theHor.length - 1; y++) {
        var Y1 = theHor[y];
        var Y2 = theHor[y+1];
        for (var x = 0; x < theVer.length - 1; x++) {
        try {
        var X1 = theVer[x];
        var X2 = theVer[x+1];
        rectangularSelection([Y1, X1, Y2, X2], false);
      // layer via copy;
        var id14 = charIDToTypeID( "CpTL" );
        executeAction( id14, undefined, DialogModes.NO );
      // add mask;
        intersectedLayerMask (layerID)
        } catch (e) {};
      // reselct layer;
        myDocument.activeLayer = theLayer;
      // reset the ruler units;
      app.preferences.rulerUnits = originalRulerUnits
      ////////////////// the functions //////////////////
      ////// treat array //////
      function treatGuideArray (theArray, theExtreme) {
      theArray.sort(function(a,b){return a - b});
      if (Number (theArray[theArray.length - 1]) != theExtreme) {theArray.push(theExtreme)};
      if (Number (theArray[0]) != 0) {theArray.unshift(new UnitValue(0, "pt"))};
      return theArray;
      ////// rectangular selection //////
      function rectangularSelection (theBounds, add) {
      if (add == false ||  add == undefined) {var idsetd = charIDToTypeID( "setd" )}
      else {var idsetd = charIDToTypeID( "AddT" )};
          var desc55 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref11 = new ActionReference();
              var idChnl = charIDToTypeID( "Chnl" );
              var idfsel = charIDToTypeID( "fsel" );
              ref11.putProperty( idChnl, idfsel );
          desc55.putReference( idnull, ref11 );
          var idT = charIDToTypeID( "T   " );
              var desc56 = new ActionDescriptor();
              var idTop = charIDToTypeID( "Top " );
              var idRlt = charIDToTypeID( "#Rlt" );
              desc56.putUnitDouble( idTop, idRlt, theBounds[0] );
              var idLeft = charIDToTypeID( "Left" );
              desc56.putUnitDouble( idLeft, idRlt, theBounds[1] );
              var idBtom = charIDToTypeID( "Btom" );
              desc56.putUnitDouble( idBtom, idRlt, theBounds[2] );
              var idRght = charIDToTypeID( "Rght" );
              desc56.putUnitDouble( idRght, idRlt, theBounds[3] );
          var idRctn = charIDToTypeID( "Rctn" );
          desc55.putObject( idT, idRctn, desc56 );
      executeAction( idsetd, desc55, DialogModes.NO );
      // by mike hale, via paul riggott;
      function getLayerId(theLayer){
      // http://forums.adobe.com/message/1944754#1944754
      app.activeDocument.activeLayer = theLayer;
      //Assumes activeDocument and activeLayer
          var ref = new ActionReference();
          ref.putEnumerated(charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
          d = executeActionGet(ref);
      return d.getInteger(charIDToTypeID('LyrI'));
        • 1. Re: Help with modifying script - export areas between guides (layers) to images but with new (trimmed) dimension in file name...
          kajzica Level 1
          Resolved...
          Script flatten layers, make move tool active (for guide adjustment), zoom to 100% in center (for guide adjustment), split image to layers (areas inside guides), rename layers to file name+dimension in cm as suffix, delete background layers if exist (probably not needed), export layers to various files via gui interface (layer saver script).
          Before running script we run action which put two temp vertical guides at 48% and 52% (around image center) so user cant drag it from ruler. This can be time saver on big monitors.
          Here is code
          //flaten layers
          app.activeDocument.flatten()
          //select move tool
          var idslct = charIDToTypeID( "slct" );
              var desc4 = new ActionDescriptor();
                  var ref1 = new ActionReference();
                  var idmoveTool = stringIDToTypeID( "moveTool" );
                  ref1.putClass( idmoveTool );
              desc4.putReference( idnull, ref1 );
              var iddontRecord = stringIDToTypeID( "dontRecord" );
              desc4.putBoolean( iddontRecord, true );
              var idforceNotify = stringIDToTypeID( "forceNotify" );
              desc4.putBoolean( idforceNotify, true );
          executeAction( idslct, desc4, DialogModes.NO );
          //zoom to 100%
          cTID = function(s) { return app.charIDToTypeID(s); };
          sTID = function(s) { return app.stringIDToTypeID(s); };
          doMenuItem = function(item, interactive) {
             ref.putEnumerated(cTID("Mn  "), cTID("MnIt"), item);
             var desc = new ActionDescriptor();
             desc.putReference(cTID("null"), ref);
             try {
               var mode = (interactive != true ? DialogModes.NO : DialogModes.ALL);
               executeAction(sTID("select"), desc, mode);
             } catch (e) {
               if (!e.message.match("User cancelled")) {
                 throw e;
               } else {
                 return false;
             return true;
          doMenuItem(cTID('ActP'));
          //reze sliku prema guide-ovima
          // split image to layers according to guides;
          #target photoshop
          // check guides;
            var Y1 = theHor[y];
            try {
            var X1 = theVer[x];
          // layer via copy;
          // add mask;
            } catch (e) {};
          // reselct layer;
          return theArray;
          // rename layers + dimension
          var doc = app.activeDocument;
          var docName = doc.name;
          // you have to check if the following layers really exists !!!
          doc.activeLayer = doc.artLayers.getByName("Layer 1");
          app.activeDocument.activeLayer.name = docName + "_Zadnjica_" + getSize ();
          doc.activeLayer = doc.artLayers.getByName("Layer 2");
          app.activeDocument.activeLayer.name = docName + "_Hrbat_" + getSize ();
          doc.activeLayer = doc.artLayers.getByName("Layer 3");
          app.activeDocument.activeLayer.name = docName + "_Prednjica_" + getSize ();
          // dimension
          app.preferences.rulerUnits = Units.CM;
          function getSize () {
          var actLayBds = doc.activeLayer.bounds;
          var actLayW = actLayBds[2] - actLayBds[0];
          var actLayH = actLayBds[3] - actLayBds[1];
          var cmW = new UnitValue (actLayW.as('cm').toFixed(1),'cm');
          var cmH = new UnitValue (actLayH.as('cm').toFixed(1),'cm');
          laySize = cmW + " x " + cmH;
          return laySize;
          // delete Background if exist!!!
          doc.activeLayer = doc.artLayers.getByName("Background");
          doc.activeLayer.remove();
          //Export layers to files (orig. Layer saver.jsx)
          #target photoshop
          function main(){
          if(!documents.length) return;
          if(activeDocument.layers.length == 1) return;
          var Prefs ={};
          try{
            var desc1 = app.getCustomOptions('ed0f5560-dfb3-11e0-9572-0800200c9a66');
            Prefs = eval(desc1.getString(0));
              }catch(e){
          Prefs={
          saveType:0,
          tiffComp:0,
          jpgQual:12,
          jpgsfwQual:100,
          FileName:0,
          merge:false,
          trim:false,
          rUnits:0,
          rMethod:0,
          Folder1:decodeURI(app.activeDocument.path)
          var doc = activeDocument;
          var LSets = activeDocument.layerSets.length;
          var LSetsVis=[];
          var ArtLayers = activeDocument.artLayers.length;
          var NoOfLayers = activeDocument.layers.length;
          var Back = hasBackground();
          var hasTop = false;
          var selLayers =getSelectedLayersIdx();
          var selGroups=[];
          if(LSets>0){
              for(var s in selLayers){
             if(isLayerSet(selLayers[s])) selGroups.push(selLayers[s]);
          if(activeDocument.layers[0].typename == 'ArtLayer') hasTop = true;
          var win = new Window('dialog','Layer Saver');
          //Photoshop CS6 or CC has a bug in the font size, so it won't fit on a laptop screen so use row.
          if(app.version.match(/\d+/) >= 13 && $.screens[0].bottom < 800 ){
          win.orientation = "row";
          g = win.graphics;
          var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]);
          g.backgroundColor = myBrush;
          win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
          win.p1.preferredSize=[500,260];
          win.g1 = win.p1.add('group');
          win.g1.orientation = "row";
          win.title = win.g1.add('statictext',undefined,'Layer Saver');
          win.title.alignment="fill";
          var g = win.title.graphics;
          g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
          win.g5 =win.p1.add('group');
          win.g5.orientation = "column";
          win.g5.alignChildren='left';
          win.g5.spacing=0;
          if(LSets  == 0){
          win.g5.rb1 = win.g5.add('radiobutton',undefined,'Save selected layers');
          win.g5.rb2 = win.g5.add('radiobutton',undefined,'Save selected layers along with the top layer');
          win.g5.rb3 = win.g5.add('radiobutton',undefined,'Save selected layers along with background layer');
          win.g5.rb4 = win.g5.add('radiobutton',undefined,'Save all layers');
          win.g5.rb5 = win.g5.add('radiobutton',undefined,'Save all layers along with the top layer');
          win.g5.rb6 = win.g5.add('radiobutton',undefined,'Save all layers along with background layer');
          win.g5.rb7 = win.g5.add('radiobutton',undefined,'Save all layers along with bottom layer');
          win.g5.rb8 = win.g5.add('radiobutton',undefined,'Save selected layers along with bottom layer');
          win.g5.rb9 = win.g5.add('radiobutton',undefined,'Save selected layers along with top and background layers');
          win.g5.rb3.enabled=Back;
          win.g5.rb6.enabled=Back;
          win.g5.rb7.enabled=!Back;
          win.g5.rb8.enabled=!Back;
          win.g5.rb9.enabled=Back;
          win.g5.rb4.value=true;
          }else{
          win.g5.rb1 = win.g5.add('radiobutton',undefined,'Save selected layerSets');
          win.g5.rb2 = win.g5.add('radiobutton',undefined,'Save selected layerSets along with the top layer');
          win.g5.rb3 = win.g5.add('radiobutton',undefined,'Save selected layerSets along with background layer');
          win.g5.rb4 = win.g5.add('radiobutton',undefined,'Save all layerSets');
          win.g5.rb5 = win.g5.add('radiobutton',undefined,'Save all layerSets along with the top layer');
          win.g5.rb6 = win.g5.add('radiobutton',undefined,'Save all layerSets along with background layer');
          win.g5.rb7 = win.g5.add('radiobutton',undefined,'Save all layerSets along with top layerset');
          win.g5.rb8 = win.g5.add('radiobutton',undefined,'Save all layerSets along with bottom layerset');
          win.g5.rb9 = win.g5.add('radiobutton',undefined,'Save all layerSets along with top and bottom layersets');
          win.g5.rb10 = win.g5.add('radiobutton',undefined,'Save all layers within all layerSets');
          win.g5.rb4a = win.g5.add('checkbox',undefined,'Save all layerSets along with selected layers');
          win.g5.rb4a.helpTip="No LayerSets should be selected!\rOnly layers to be saved with each LayerSet";
          win.g5.rb2.enabled=hasTop;
          win.g5.rb5.enabled=hasTop;
          if(LSets < 3){
              win.g5.rb7.enabled=false;
              win.g5.rb8.enabled=false;
          if(LSets < 4){
              win.g5.rb9.enabled=false;
          if(selGroups.length <1){
              win.g5.rb1.enabled=false;
              win.g5.rb2.enabled=false;
              win.g5.rb3.enabled=false;
          win.p2 = win.add("panel", undefined, undefined, {borderStyle:"black"});
          win.p2.preferredSize=[500,260];
          win.p2.st1 = win.p2.add('statictext',undefined,'Output details');
          win.p2.st1.graphics.font = ScriptUI.newFont("Tahoma", "Bold", 18);
          win.g10 =win.p2.add('group');
          win.g10.orientation = "row";
          win.g10.alignment='left';
          win.g10.et1 = win.g10.add('edittext');
          win.g10.et1.preferredSize=[350,20];
          win.g10.et1.enabled=false;
          win.g10.bu1 = win.g10.add('button',undefined,'Select Folder');
          win.g10.bu1.onClick=function(){
          Folder1 = Folder(Prefs.Folder1);
          outputFolder = Folder.selectDialog("Please select the output folder",Folder1);
            if(outputFolder !=null){
            win.g10.et1.text =  decodeURI(outputFolder.fsName);
          if(Folder(Prefs.Folder1).exists){
              outputFolder= Folder(Prefs.Folder1);
          win.g12 =win.p2.add('group');
          win.g12.orientation = "row";
          win.g12.alignment='left';
          win.g12.cb1 = win.g12.add('checkbox',undefined,'Merge Visible Layers?');
          win.g12.cb1.value = Prefs.merge;
          win.g12.cb2 = win.g12.add('checkbox',undefined,'Trim Layer');
          win.g12.cb2.value=Prefs.trim;
          win.g11 =win.p2.add('group');
          win.g11.spacing=10;
          win.g11.orientation = 'row';
          win.g11.alignment="left";
          win.g11.cb1 = win.g11.add('checkbox',undefined,'Run Action');
          win.g11.dd1 = win.g11.add('dropdownlist');
          win.g11.dd1.preferredSize=[150,20];
          win.g11.dd2 = win.g11.add('dropdownlist');
          win.g11.dd2.preferredSize=[150,20];
          win.g11.dd1.enabled=false;
          win.g11.dd2.enabled=false;
          win.g11.cb1.onClick = function(){
              if(win.g11.cb1.value){
                  win.g11.dd1.enabled=true;
                  win.g11.dd2.enabled=true;
                  }else{
          var actions = new Array();
          var actionSets= new Array();
          actionSets = getActionSets();
          for (var i=0,len=actionSets.length;i<len;i++) {
            win.g11.dd1.add ('item', "" + actionSets[i]);
          win.g11.dd1.selection=0;
          actions = getActions(actionSets[0]);
          for (var i=0,len=actions.length;i<len;i++) {
            win.g11.dd2.add ('item', "" + actions[i]);
          win.g11.dd2.selection=0;
          win.g11.dd1.onChange = function() {
          win.g11.dd2.removeAll();
          actions = getActions(actionSets[parseInt(this.selection)]);
          win.g14 =win.p2.add('group');
          win.g14.orientation = "row";
          win.g14.alignment='left';
          win.g14.cb1 = win.g14.add('checkbox',undefined,'Add Suffix/Prefix');
          win.g14.rb1 = win.g14.add('radiobutton',undefined,'Prefix');
          win.g14.rb2 = win.g14.add('radiobutton',undefined,'Suffix');
          win.g14.rb2.value=true;
          win.g15 =win.p2.add('group');
          win.g15.orientation = "row";
          win.g15.alignment='left';
          var Options= ["Layer/Group Name","FileName + Sequence No.","FileName + Layer/Group Name ","User Defined with Sequence No.","Group Name + LayerName"];
          win.g15.st1 = win.g15.add('statictext',undefined,'Save Options..');
          win.g15.dd1 = win.g15.add('dropdownlist',undefined,Options);
          win.g15.dd1.remove(4);
          if(Number(Prefs.FileName) == 4) Prefs.FileName = 0;
          win.g15.dd1.selection=Number(Prefs.FileName);
          if(LSets > 0){
          win.g5.rb1.onClick=function(){
              win.g5.rb4a.value=false;
                  win.g5.rb4a.enabled=false;
              win.g5.rb10.onClick();
          win.g5.rb2.onClick=function(){
          win.g5.rb3.onClick=function(){
          win.g5.rb4.onClick=function(){
              if(win.g5.rb4.value){
              win.g5.rb4a.enabled=true;
          win.g5.rb5.onClick=function(){
          win.g5.rb6.onClick=function(){
          win.g5.rb7.onClick=function(){
          win.g5.rb8.onClick=function(){
          win.g5.rb9.onClick=function(){
          win.g15.dd1.add('item','Group Name + LayerName');
          win.g5.rb10.onClick=function(){
              }else{
              if(win.g5.rb10.value){
                  }else{
                      try{
                      }catch(e){}
                      win.g15.dd1.selection=0;
          win.g5.rb4.onClick();
          win.g15.et1 = win.g15.add('edittext');
          win.g15.et1.preferredSize=[150,20];
          win.g15.et1.hide();
          win.g15.dd1.onChange=function(){
            if(this.selection.index==0){
                win.g14.cb1.enabled=true;
                }else{
                    win.g14.cb1.value=false;
                    win.g14.cb1.enabled=false;
            if(this.selection.index==3){
                win.g15.et1.show();
                }else{
                    win.g15.et1.hide();
          win.g14.cb1.onClick=function(){
              if(win.g14.cb1.value){
                  win.g15.et1.show();
                  }else{
                      win.g15.et1.hide();
          win.g15.dd1.onChange();
          win.g18 =win.p2.add('group');
          win.g18.orientation = "row";
          win.g18.st1 = win.g18.add('statictext',undefined,'Save as :');
          var Types = ["PNG","PSD","PDF","TIF","JPG","JPG SFW","PCX","PNG SFW"];
          win.g18.dd1 = win.g18.add('dropdownlist',undefined,Types);
          win.g18.dd1.selection = Number(Prefs.saveType);
          win.g18.alignment='left';
          win.g19 =win.g18.add('group');
          win.g19.orientation = "stack";
          win.g19b =win.g19.add('group');
          win.g19b.st1 = win.g19b.add('statictext',undefined,'Quality');
          win.g19b.dd1 = win.g19b.add('dropdownlist');
          for(var a =1;a<13;a++){
              win.g19b.dd1.add('item',a);
          win.g19b.dd1.selection = Number(Prefs.jpgQual);
          win.g19b.visible=false;
          win.g19c =win.g19.add('group');
          win.g19c.st1 = win.g19c.add('statictext',undefined,'Compression');
          var tiffOptions=["LZW","ZIP","JPG","None"];
          win.g19c.dd1 = win.g19c.add('dropdownlist',undefined,tiffOptions);
          win.g19c.dd1.selection = Number(Prefs.tiffComp);
          win.g19c.visible=false;
          win.g19d =win.g19.add('group');
          win.g19d.st1 = win.g19d.add('statictext',undefined,'Quality');
          win.g19d.dd1 = win.g19d.add('dropdownlist');
          for(var a =1;a<101;a++){
              win.g19d.dd1.add('item',a);
          win.g19d.dd1.selection = Number(Prefs.jpgsfwQual);
          win.g19d.visible=false;
          win.g19d.cb1 = win.g19d.add('checkbox',undefined,'Nearest Size Kilobytes');
          win.g19d.et1 = win.g19d.add('edittext');
          win.g19d.cb1.helpTip="This could take some time as multiple saves are required!";
          win.g19d.et1.preferredSize=[70,20];
          win.g19d.cb1.onClick = function(){
              if(win.g19d.cb1.value){
                  win.g19d.dd1.enabled=false;
                  win.g19d.et1.enabled=true;
                  }else{
                      win.g19d.dd1.enabled=true;
                      win.g19d.et1.enabled=false;
          win.g19d.et1.onChanging = function() {
            if (this.text.match(/[^\-\.\d]/)) {
              this.text = this.text.replace(/[^\-\.\d]/g, '');
          win.g19d.cb1.onClick();
          win.g18.dd1.onChange=function(){
              switch(Number(this.selection.index)){
                  case 0 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=false; break;
                  case 1 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=false; break;
                  case 2 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=false; break;
                  case 3 : win.g19b.visible=false; win.g19c.visible=true; win.g19d.visible=false; break;
                  case 4 : win.g19b.visible=true; win.g19c.visible=false; win.g19d.visible=false; break;
                  case 5 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=true; break;
                  case 6 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=false; break;
                  case 7 : win.g19b.visible=false; win.g19c.visible=false; win.g19d.visible=false; break;
                  default :break;
          win.g18.dd1.onChange();
          try{
          resizeMethod = ["Bicubic", "BicubicSharper","BicubicSmoother", "Bilinear", "NearestNeighbor"];
          resizeUnits = ["pixels", "percent", "inches","cm", "mm", "points", "picas"];
          win.g29a =win.p2.add('group');
          win.g29a.spacing=0;
          win.g29a.orientation = 'row';
          win.g29a.alignment="left";
          win.g29a.cb0 = win.g29a.add('checkbox',undefined,'Custom Fit Image');
          win.g29a.cb1 = win.g29a.add('checkbox',undefined,'Constrain Proportions');
          win.g29a.cb1.value=true;
          win.g29a.cb1.helpTip="If unticked this could distort the image!";
          win.g29b =win.p2.add('group');
          win.g29b.spacing=0;
          win.g29b.orientation = 'row';
          win.g29b.alignment="left";
          win.g29b.st1 = win.g29b.add('statictext',undefined,'Width');
          win.g29b.et1 = win.g29b.add('edittext',undefined,'');
          win.g29b.et1.preferredSize=[40,20];
          win.g29b.st2 = win.g29b.add('statictext',undefined,'Height');
          win.g29b.et2 = win.g29b.add('edittext',undefined,'');
          win.g29b.et2.preferredSize=[40,20];
          win.g29b.dd1 = win.g29b.add('dropdownlist',undefined,resizeUnits);
          win.g29b.dd1.selection= Prefs.rUnits;
          win.g29b.dd2 = win.g29b.add('dropdownlist',undefined,resizeMethod);
          win.g29b.dd2.selection= Prefs.rMethod;
          win.g29c =win.p2.add('group');
          win.g29c.spacing=0;
          win.g29c.orientation = 'row';
          win.g29c.alignment="left";
          win.g29c.cb0 = win.g29c.add('checkbox',undefined,'Use document resolution');
          win.g29c.cb0.value=true;
          win.g29c.st1 = win.g29c.add('statictext',undefined,'Enter resolution');
          win.g29c.et1 = win.g29c.add('edittext');
          win.g29c.et1.preferredSize=[40,20];
          win.g29c.et1.onChanging = function() {
          win.g29c.cb0.onClick=function(){
              if(win.g29c.cb0.value){
                  win.g29c.et1.visible=false;
                  win.g29c.st1.visible=false;
                  }else{
                      win.g29c.et1.visible=true;
                      win.g29c.st1.visible=true;
          win.g29c.cb0.onClick();
          win.g29a.cb0.onClick = function(){
              if(win.g29a.cb0.value){
                  win.g29a.cb1.enabled=true;
                  win.g29b.et1.enabled=true;
                  win.g29b.et2.enabled=true;
                  win.g29b.dd1.enabled=true;
                  win.g29b.dd2.enabled=true;
                  win.g29c.cb0.enabled=true;
                  }else{
                      win.g29a.cb1.enabled=false;
                      win.g29b.et1.enabled=false;
                      win.g29b.et2.enabled=false;
                      win.g29b.dd1.enabled=false;
                      win.g29b.dd2.enabled=false;
                      win.g29c.cb0.enabled=false;
          win.g29b.et1.onChanging = function() {
          win.g29b.et2.onChanging = function() {
          win.g29a.cb0.onClick();
          }catch(e){alert(e+" - "+e.line);}
          win.g200 =win.p2.add('group');
          win.g200.orientation = "row";
          win.g200.bu1 = win.g200.add('button',undefined,'Process');
          win.g200.bu1.preferredSize=[200,35];
          win.g200.bu2 = win.g200.add('button',undefined,'Cancel');
          win.g200.bu2.preferredSize=[200,35];
          win.g200.bu1.onClick=function(){
                  if(win.g19d.et1.text == ''){
                      alert("No JPG size has been entered!");
                      return;
              if(win.g10.et1.text == ''){
                  alert("No Output Folder has been Selected!");
                  return;
              if(win.g15.dd1.selection.index==3){
                  if(win.g15.et1.text ==''){
                      alert("No FileName Has Been Entered!");
                      return;
                      alert("No Prefix/Suffix Has Been Entered!");
                      return;
              if(win.g29a.cb0.value){//Resize output file
                  if(win.g29b.et1.text == ''){
                      alert("No Width has been entered for the resize!");
                      return;
                  if(win.g29b.et2.text == ''){
                      alert("No Height has been entered for the resize!");
                      return;
                  if(!win.g29c.cb0.value && win.g29c.et1.text == ''){
                      alert("No resolution has been entered!");
                      return;
          Prefs.jpgsfwQual = win.g19d.dd1.selection.index;
          Prefs.tiffComp = win.g19c.dd1.selection.index;
          Prefs.jpgQual = win.g19b.dd1.selection.index
          Prefs.saveType = win.g18.dd1.selection.index;
          Prefs.FileName = win.g15.dd1.selection.index;
          Prefs.merge = win.g12.cb1.value;
          Prefs.trim = win.g12.cb2.value;
          Prefs.rUnits = win.g29b.dd1.selection.index;
          Prefs.rMethod = win.g29b.dd2.selection.index;
          Prefs.Folder1= decodeURI(outputFolder);
          var desc2 = new ActionDescriptor();
          desc2.putString(0, Prefs.toSource());
          app.putCustomOptions('ed0f5560-dfb3-11e0-9572-0800200c9a66', desc2, true );
          win.close(1);
          if($.os.match(/windows/gi)){
          if(app.version.match(/\d+/) ==13){
          var Tabbed = isTabInterface();
          if(!Tabbed) tabInterface();
          Process();
          if(!Tabbed) tabInterface(false);
          win.center();
          win.show();
          function Process(){
          function resizeDoc(){
          //Custom Fit Image ****************************
          var doc=activeDocument;
          resUnits= win.g29b.dd1.selection.text.toString();
          resWidth = new UnitValue(Number(win.g29b.et1.text),resUnits);
          resHeight = new UnitValue(Number(win.g29b.et2.text),resUnits);
          if(win.g29a.cb1.value){//Constrain Proportions
            if(doc.width>doc.height){
                resHeight = undefined;
                }else{
                    resWidth = undefined;
          if(!win.g29a.cb1.value){
              if(doc.height > doc.width){
                  resHeight = new UnitValue(Number(win.g29b.et1.text),resUnits);
                  resWidth = new UnitValue(Number(win.g29b.et2.text),resUnits);
          resizeRes = undefined;
          }else{
              resizeRes = Math.round(Number(win.g29c.et1.text));
          resizeMethods = win.g29b.dd2.selection.text.toString().toUpperCase();
          activeDocument.resizeImage (resWidth, resHeight, resizeRes, eval("ResampleMethod."+resizeMethods));
          //end custom Fit Image
          if(LSets == 0){
          //Process layers only
          if(win.g5.rb1.value){//Save selected layers
          for(var b in selLayers){
              selectLayerByIndex(Number(selLayers[b]));
               var lName = activeDocument.activeLayer.name;
              var saveFile= File(outputFolder+ "/" + getName(b,lName));
              dupLayers();
              if(win.g12.cb1.value){
                  try{activeDocument.mergeVisibleLayers();}catch(e){}
               if(win.g12.cb2.value){
                   try{activeDocument.trim(TrimType.TRANSPARENT,true,true,true,true);}catch(e){}
               if(win.g11.cb1.value) doAction(win.g11.dd2.selection.text, win.g11.dd1.selection.text);
              if(win.g29a.cb0.value) resizeDoc();
              SaveDOC(saveFile);
              app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
              }//End Save selected layers
          if(win.g5.rb2.value){//Save selected layers along with the top layer
              activeDocument.activeLayer= activeDocument.layers[0];
              selectLayerByIndex(Number(selLayers[b]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save selected layers along with the top layer
          if(win.g5.rb3.value){//Save selected layers along with background layer
              activeDocument.activeLayer = activeDocument.layers[activeDocument.layers.length-1];
              dupLayers();
              activeDocument.layers[0].visible=true;
              SaveDOC(saveFile);
              }//End Save selected layers along with background layer
          if(win.g5.rb4.value){//Save all layers
          selectAllLayers();
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layers
          if(win.g5.rb5.value){//Save all layers along with the top layer
          selectAllLayers();
              activeDocument.activeLayer = activeDocument.layers[0];
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layers along with the top layer
          if(win.g5.rb6.value){//Save all layers along with background layer
          selectAllLayers();
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layers along with background layer
          if(win.g5.rb7.value){//Save all layers along with bottom layer
          selectAllLayers();
          var bottomLayer = getSelectedLayersIdx();
               if(Number(selLayers[b]) == Number(bottomLayer[0])) continue;
              selectLayerByIndex(Number(bottomLayer[0]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layers along with bottom layer
          if(win.g5.rb8.value){//Save selected layers along with bottom layer
              dupLayers();
              SaveDOC(saveFile);
              }//End Save selected layers along with bottom layer
          if(win.g5.rb9.value){//Save selected layers along with top and bottom layer
          var topLayer = getSelectedLayersIdx();
               if(Number(selLayers[b]) == Number(topLayer[0])) continue;
              selectLayerByIndex(Number(topLayer[0]),true);
              selectLayerByIndex(0,true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save selected layers along with top and bottom layer
              }else{
          //Process LayerSets Only
          if(win.g5.rb1.value){//Save selected layerSets
              for(var g in selGroups){
                  selectLayerByIndex(Number(selGroups[g]));
                  var saveFile= File(outputFolder+ "/" + getName(g,lName));
                  dupLayers();
              SaveDOC(saveFile);
             }//End Save selected layerSets
          if(win.g5.rb2.value){//Save selected layerSets along with the top layer
              selectLayerByIndex(Number(selGroups[g]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save selected layerSets along with the top layer
          if(win.g5.rb3.value){//Save selected layerSets along with background layer
              dupLayers();
              SaveDOC(saveFile);
              }//End Save selected layerSets along with background layer
          if(win.g5.rb4.value){//Save all layerSets
          for(var y =0; y< LSets;y++){
              LSetsVis.push(doc.layerSets[y].visible);
              doc.layerSets[y].visible=false;
              for(var g =0;g<LSets;g++){
                   activeDocument.activeLayer = activeDocument.layerSets[g];
                   activeDocument.layerSets[g].visible=true;
                   if(win.g5.rb4a.value){
                   for(var d in selLayers ){
                   selectLayerByIndex(Number(selLayers[d]),true);
              dupLayers();
              SaveDOC(saveFile);
              activeDocument.layerSets[g].visible=false;
              doc.layerSets[y].visible = LSetsVis[y];
              }//End Save all layerSets
          if(win.g5.rb5.value){//Save all layerSets along with the top layer
              var TopIDX =getSelectedLayersIdx();
                   selectLayerByIndex(Number(TopIDX[0]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layerSets along with the top layer
          if(win.g5.rb6.value){//Save all layerSets along with background layer
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layerSets along with background layer
          if(win.g5.rb7.value){//Save all layerSets along with top layerset
              activeDocument.activeLayer = activeDocument.layerSets[0];
             var topLayerSet = getSelectedLayersIdx();
              for(var g =1;g<LSets;g++){
                   selectLayerByIndex(Number(topLayerSet[0]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layerSets along with top layerset
          if(win.g5.rb8.value){//Save all layerSets along with bottom layerset
              activeDocument.activeLayer = activeDocument.layerSets[LSets-1];
             var bottomLayerSet = getSelectedLayersIdx();
              for(var g =0;g<LSets-1;g++){
                   selectLayerByIndex(Number(bottomLayerSet[0]),true);
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layerSets along with bottom layerset
          if(win.g5.rb9.value){//Save all layerSets along with top and bottom layerset
              for(var g =1;g<LSets-1;g++){
              dupLayers();
              SaveDOC(saveFile);
              }//End Save all layerSets along with top and bottom layerset
          if(win.g5.rb10.value){//Save all layers including those in layersets
          selectAllLayers();
               if(activeDocument.activeLayer.typename == 'LayerSet') continue;
               if(app.activeDocument.activeLayer.kind == LayerKind.HUESATURATION ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.COLORBALANCE ) continue;
               if(app.activeDocument.activeLayer.kind ==  LayerKind.CURVES ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.LEVELS ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.BLACKANDWHITE ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.BRIGHTNESSCONTRAST ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.GRADIENTFILL ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.GRADIENTMAP ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.INVERSION ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.PATTERNFILL ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.SELECTIVECOLOR ) continue;
                if(app.activeDocument.activeLayer.kind == LayerKind.THRESHOLD ) continue;
              dupLayers();
              SaveDOC(saveFile);
          function getName(seq,lName){
          lName = lName.replace(/\....$/,'');
          seq = zeroPad((Number(seq)+1), 3);
          var dName = decodeURI(activeDocument.name).replace(/\.[^\.]+$/, '');
          var Name ='';
          if(win.g15.dd1.selection.index ==0 && win.g14.cb1.value){
              if(win.g14.rb1.value){
                  Name += win.g15.et1.text + lName;
                  return Name;
                  }else{
                  Name += lName + win.g15.et1.text;
                  return Name;
          switch (Number(win.g15.dd1.selection.index)){
              case 0: Name += lName; break;
              case 1: Name += dName +"-"+seq; break;
              case 2: Name += dName +"-"+ lName; break;
              case 3: Name += win.g15.et1.text + "-"+seq; break;
              case 4: Name += ParentName() + lName; break;
              default :break;
          return Name;
          function ParentName(){
          if(activeDocument.activeLayer.parent.typename == "LayerSet") {
          return activeDocument.activeLayer.parent.name + " - ";
          }else{
              return "";
          function SaveDOC(saveFile){
              switch(Number(win.g18.dd1.selection.index)){
                  case 0 : SavePNG(File(saveFile+".png")); break;
                  case 1:  SavePSD(File(saveFile+".psd")); break;
                  case 2:  SavePDF(File(saveFile+".pdf")); break;
                  case 3:  SaveTIFF(File(saveFile+".tif"),Number(win.g19c.dd1.selection.index)); break;
                  case 4:  SaveJPG(File(saveFile+".jpg"),Number(win.g19b.dd1.selection.index)+1); break;
                  case 5:  SFW(saveFile); break;
                  case 6:  savePCX(saveFile +".pcx"); break;
                  case 7: saveAsPNG24SFW(File(saveFile+".png")); break;
                  default : break;
          function SFW(saveFile){
            if(!win.g19d.cb1.value){
                SaveForWeb(File(saveFile+".jpg"),Number(win.g19d.dd1.selection.index)+1);
                }else{
                    try{
                    tmpFile = File(saveFile+".jpg");
                    for(var z =100;z>5;z -=4){
                        SaveForWeb(tmpFile,z);
                        var chkFile = File(saveFile+".jpg");
                        // $.writeln(tmpFile + " qual = " + z + " Size = " +(chkFile.length/1024).toFixed(2) + "k" );
                        if((chkFile.length/1024).toFixed(2) < Number(win.g19d.et1.text)) break;
                        tmpFile.remove();
                    if(!tmpFile.exists)  SaveForWeb(tmpFile,5);
                    }catch(e){$.writeln(e + " - " + e.line);}
                    }//sfw nearest size
          main();
          function hasBackground() {
             ref.putProperty( charIDToTypeID("Prpr"), charIDToTypeID( "Bckg" ));
             ref.putEnumerated(charIDToTypeID( "Lyr " ),charIDToTypeID( "Ordn" ),charIDToTypeID( "Back" ));
             var desc =  executeActionGet(ref);
             var res = desc.getBoolean(charIDToTypeID( "Bckg" ));
             return res
          function getSelectedLayersIdx(){
                var selectedLayers = new Array;
                ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                   desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                    var c = desc.count
                    var selectedLayers = new Array();
                    for(var i=0;i<c;i++){
                      try{
                         activeDocument.backgroundLayer;
                         selectedLayers.push(  desc.getReference( i ).getIndex() );
                      }catch(e){
                         selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                 }else{
                   ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                   ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                   try{
                      selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                   }catch(e){
                      selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
               var vis = app.activeDocument.activeLayer.visible;
                  if(vis == true) app.activeDocument.activeLayer.visible = false;
                  var desc9 = new ActionDescriptor();
              var list9 = new ActionList();
              var ref9 = new ActionReference();
              ref9.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              list9.putReference( ref9 );
              desc9.putList( charIDToTypeID('null'), list9 );
              executeAction( charIDToTypeID('Shw '), desc9, DialogModes.NO );
              if(app.activeDocument.activeLayer.visible == false) selectedLayers.shift();
                  app.activeDocument.activeLayer.visible = vis;
                return selectedLayers;
          function isLayerSet(idx) {
             ref.putIndex(1283027488, idx);
             var type = desc.getEnumerationValue(stringIDToTypeID("layerSection"));
             var res = typeIDToStringID(type);
             if(res == 'layerSectionStart') return true;
                 return false;
          function deselectLayers() {
              var desc01 = new ActionDescriptor();
                  var ref01 = new ActionReference();
                  ref01.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              desc01.putReference( charIDToTypeID('null'), ref01 );
              executeAction( stringIDToTypeID('selectNoLayers'), desc01, DialogModes.NO );
          function dupLayers() {
              var desc143 = new ActionDescriptor();
                  var ref73 = new ActionReference();
                  ref73.putClass( charIDToTypeID('Dcmn') );
              desc143.putReference( charIDToTypeID('null'), ref73 );
              desc143.putString( charIDToTypeID('Nm  '), activeDocument.activeLayer.name );
                  var ref74 = new ActionReference();
                  ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              desc143.putReference( charIDToTypeID('Usng'), ref74 );
              executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
          function selectLayerByIndex(index,add){
          add = (add == undefined)  ? add = false : add;
          ref.putIndex(charIDToTypeID("Lyr "), index);
          desc.putReference(charIDToTypeID("null"), ref );
          if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
          desc.putBoolean( charIDToTypeID( "MkVs" ), false );
          try{
          executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
          }catch(e){}
          function selectAllLayers() {
              var desc29 = new ActionDescriptor();
                  var ref23 = new ActionReference();
                  ref23.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              desc29.putReference( charIDToTypeID('null'), ref23 );
              executeAction( stringIDToTypeID('selectAllLayers'), desc29, DialogModes.NO );
          function getActionSets() {
            var i = 1;
            var sets = [];
            while (true) {
              ref.putIndex(cTID("ASet"), i);
              var desc;
              var lvl = $.level;
              $.level = 0;
              try {
              } catch (e) {
                break;
              } finally {
                $.level = lvl;
              if (desc.hasKey(cTID("Nm  "))) {
                var set = {};
                set.index = i;
                set.name = desc.getString(cTID("Nm  "));
                set.toString = function() { return this.name; };
                set.count = desc.getInteger(cTID("NmbC"));
                set.actions = [];
                for (var j = 1; j <= set.count; j++) {
                  ref.putIndex(cTID('Actn'), j);
                  ref.putIndex(cTID('ASet'), set.index);
                  var adesc = executeActionGet(ref);
                  var actName = adesc.getString(cTID('Nm  '));
                  set.actions.push(actName);
                sets.push(set);
              i++;
            return sets;
          function getActions(aset) {
            var i = 1;
            var names = [];
            if (!aset) {
              throw "Action set must be specified";
            while (true) {
              var desc;
              try {
              } catch (e) {
                break;
                var name = desc.getString(cTID("Nm  "));
                if (name == aset) {
                  var count = desc.getInteger(cTID("NmbC"));
                  var names = [];
                  for (var j = 1; j <= count; j++) {
                    ref.putIndex(cTID('ASet'), i);
                    names.push(actName);
                  break;
              i++;
            return names;
          function tabInterface(onOff) {
          if(onOff == undefined) onOff=true;
              var desc19 = new ActionDescriptor();
                  var ref8 = new ActionReference();
                  ref8.putProperty( charIDToTypeID('Prpr'), stringIDToTypeID('interfacePrefs') );
                  ref8.putEnumerated( charIDToTypeID('capp'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              desc19.putReference( charIDToTypeID('null'), ref8 );
                  var desc20 = new ActionDescriptor();
                  desc20.putBoolean( charIDToTypeID('EGst'), true );
                  desc20.putBoolean( stringIDToTypeID('openNewDocsAsTabs'), onOff );
              desc19.putObject( charIDToTypeID('T   '), stringIDToTypeID('interfacePrefs'), desc20 );
              executeAction( charIDToTypeID('setd'), desc19, DialogModes.NO );
          function isTabInterface(){
          ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          return executeActionGet(ref).getObjectValue(stringIDToTypeID('interfacePrefs')).getBoolean(strin gIDToTypeID( 'openNewDocsAsTabs'));
          function zeroPad(n, s) {
             n = n.toString();
             while (n.length < s)  n = '0' + n;
             return n;
          function SavePNG(saveFile){
              pngSaveOptions = new PNGSaveOptions();
          activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
          function SaveTIFF(saveFile,Comp){
          tiffSaveOptions = new TiffSaveOptions();
          tiffSaveOptions.embedColorProfile = true;
          tiffSaveOptions.transparency = true;
          tiffSaveOptions.alphaChannels = true;
          tiffSaveOptions.layers = true;
          switch (Number(Comp)){
              case 0 : tiffSaveOptions.imageCompression = TIFFEncoding.TIFFLZW; break;
              case 1 : tiffSaveOptions.imageCompression = TIFFEncoding.TIFFZIP; break;
              case 2 : tiffSaveOptions.imageCompression = TIFFEncoding.JPEG; break;
              case 3 : tiffSaveOptions.imageCompression = TIFFEncoding.NONE; break;
              default : break;
          activeDocument.saveAs(saveFile, tiffSaveOptions, true, Extension.LOWERCASE);
          function SavePSD(saveFile){
          psdSaveOptions = new PhotoshopSaveOptions();
          psdSaveOptions.embedColorProfile = true;
          psdSaveOptions.alphaChannels = true;
          psdSaveOptions.layers = true;
          activeDocument.saveAs(saveFile, psdSaveOptions, true, Extension.LOWERCASE);
          function SavePDF(saveFile){
          pdfSaveOptions = new PDFSaveOptions();
          activeDocument.saveAs(saveFile, pdfSaveOptions, true, Extension.LOWERCASE);
          function SaveJPG(saveFile, jpegQuality){
              try{
          jpgSaveOptions = new JPEGSaveOptions();
          jpgSaveOptions.embedColorProfile = true;
          jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
          jpgSaveOptions.matte = MatteType.NONE;
          jpgSaveOptions.quality = jpegQuality;
          activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
          }catch(e){$.writeln(e+" - "+e.line);}
          function SaveForWeb(saveFile,jpegQuality) {
          var sfwOptions = new ExportOptionsSaveForWeb();
             sfwOptions.format = SaveDocumentType.JPEG;
             sfwOptions.includeProfile = false;
             sfwOptions.interlaced = 0;
             sfwOptions.optimized = true;
             sfwOptions.quality = Number(jpegQuality);
          activeDocument.exportDocument(saveFile, ExportType.SAVEFORWEB, sfwOptions);
          function savePCX(saveFile) {
          desc.putString( charIDToTypeID('As  '), "PCX" );
          desc.putPath( charIDToTypeID('In  '), new File( saveFile ) );
          executeAction( charIDToTypeID('save'), desc, DialogModes.NO );
          function saveAsPNG24SFW(fileName) {
              var desc3 = new ActionDescriptor();
                  desc4.putEnumerated( charIDToTypeID('Op  '), charIDToTypeID('SWOp'), charIDToTypeID('OpSa') );
                  desc4.putEnumerated( charIDToTypeID('Fmt '), charIDToTypeID('IRFm'), charIDToTypeID('PN24') );
                  desc4.putBoolean( charIDToTypeID('Intr'), false );
                  desc4.putBoolean( charIDToTypeID('Trns'), true );
                  desc4.putBoolean( charIDToTypeID('Mtt '), false );
                  desc4.putInteger( charIDToTypeID('MttR'), 255 );
                  desc4.putInteger( charIDToTypeID('MttG'), 255 );
                  desc4.putInteger( charIDToTypeID('MttB'), 255 );
                  desc4.putBoolean( charIDToTypeID('SHTM'), false );
                  desc4.putBoolean( charIDToTypeID('SImg'), true );
                  desc4.putBoolean( charIDToTypeID('SSSO'), false );
                      var list1 = new ActionList();
                  desc4.putList( charIDToTypeID('SSLt'), list1 );
                  desc4.putBoolean( charIDToTypeID('DIDr'), false );
                  desc4.putPath( charIDToTypeID('In  '), new File( fileName ) );
              desc3.putObject( charIDToTypeID('Usng'), stringIDToTypeID('SaveForWeb'), desc4 );
              executeAction( charIDToTypeID('Expr'), desc3, DialogModes.NO );
