3 Replies Latest reply on Feb 19, 2016 8:06 AM by whsprague
    4k jerky on HD-tv
    a_stoffer@ziggo.nl
      I made a movie with a Sony FDR AX33 in 4K format. After exporting it via Adobe Elements 14 into an PAL 25 fps 1920x1080 m2t-file it plays on my Panasonic HD-tv (100Hz, PAL very good when the camera is not panning. By moving the camera trees for example are displayed very stuttering (no frames stuttering). I found out that everything worked fine when I do not use 4K, but XVACS HD insteat with 50 frames per second. Anyone any idea how get everything smoothly played witg 4K footage?
        • 1. Re: 4k jerky on HD-tv
          For tv try mp4.
          4K is 25p and 25p is a difficult framerate to pan with, and like trees very detailed picture.
          Either dont pan or pan very very very slooooooooooooow.
          • 2. Re: 4k jerky on HD-tv
            It's probably the export to HD that's causing the stuttering.
            Which Export & Share preset are you using? It may be interlaced, which would cause the stuttering. Outputting as a 1920x1080 25p video rather than a 25i or 50i may solve the stuttering issue -- though you may need to create a custom output preset to do it.
            • 3. Re: 4k jerky on HD-tv
              whsprague Adobe Community Professional
              You write that you are outputting to a .m2t file.  I've been shooting and editing 4K footage from a Pansonic for a little over a year.  I don't have PrE 14.  In PrE 13 I've had very good results with Publish&Share > Computer > AVCHD > Presets -- MP4 - H.264 1920x1080p30.  In a PAL country, p25 would probably be better.   I've also had good results using XAVC-S to output at 4K for Vimeo (which now supports 4K).
