1 Reply Latest reply on May 4, 2016 8:28 PM by pauld62235961
    central and output instances
    PDF Solutions Level 1
      how do I create new instances in central and in output?  will this free jobs while generating the pdf and sumit them quicklier.  How many instances does central and output will support
        • 1. Re: central and output instances
          pauld62235961
          To create new instances in Central you just need to run the installation process again.
          The installation process is smart enough to recognise an instance exists and will provide a different install option. The different install option will give you an instance with a number on the end. ie: Server, Server2, Server3 etc...
          Most sites I have seen use 2 instances, test and production, but in higher volume sites I have seen 10+ instances running with no issues.
