3 Replies Latest reply on Feb 22, 2016 10:58 PM by Nanaky
    E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
    laurah449077
      What is this?
        • 1. Re: E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
          Nanaky Level 5
          Macintosh:
          1. quit Adobe Digital Editions.
          2. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
            If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
          3. Open Adobe Digital Editions and reauthorize.
          Windows:
          1. Close all applications.
          2. Choose Start > Run.
          3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
          4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
          5. Select the Adept key.
          6. Choose File > Export.
          7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
          8. Right-click the Adept key and choose Delete.
          9. In the Confirm Key Delete dialog, click OK.
          10. Close the Registry Editor.
          11. Open Adobe Digital Editions and reauthorize.
          • 2. Re: E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
            laurah449077 Level 1
            Hi there, thank you for your response. However, I can't seem to find /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file.
            How do I get there? Thanks.
            • 3. Re: E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
              Nanaky Level 5
              Has you check the steps under the link to found the Library?
