7 Replies Latest reply on Feb 20, 2016 9:47 AM by pixxxel schubser
    Rename layers - unsaved file name + suffix
    kajzica Level 1
      Hi
      I have jsx script which can rename layers with current file name + suffix. Script select layer by names. But, this work if file is saved to disk.
      Need to modify script to use name even if file is not previously save to disk, like freshly opened pdf file?
      var doc = app.activeDocument;
      doc.activeLayer = doc.artLayers.getByName("Layer 2");
      app.activeDocument.activeLayer.name = decodeURI(app.activeDocument.name).match(/(.*)(\.[^\.]+)/)[1] + "_Zadnjica";
      doc.activeLayer = doc.artLayers.getByName("Layer 3");
      app.activeDocument.activeLayer.name = decodeURI(app.activeDocument.name).match(/(.*)(\.[^\.]+)/)[1] + "_Hrbat";
      doc.activeLayer = doc.artLayers.getByName("Layer 4");
      app.activeDocument.activeLayer.name = decodeURI(app.activeDocument.name).match(/(.*)(\.[^\.]+)/)[1] + "_Prednjica";
        • 1. Re: Rename layers - unsaved file name + suffix
          pixxxel schubser MVP & Adobe Community Professional
          This is not really the best way. But you can do something like that with your existing code:
          var yourWishNamePart2Save = "NewSaveName";
          // you have to check if the following layers really exists !!!
          app.activeDocument.activeLayer.name = yourWishNamePart2Save + "_Zadnjica";
          app.activeDocument.activeLayer.name = yourWishNamePart2Save + "_Hrbat";
          app.activeDocument.activeLayer.name = yourWishNamePart2Save + "_Prednjica";
          // additional you need as save function with yourWishNamePart2Save + extension
          Have fun
          • 2. Re: Rename layers - unsaved file name + suffix
            kajzica Level 1
            but this wont get current name from image window
            • 3. Re: Rename layers - unsaved file name + suffix
              Ok.
              Try this one
              var docName = doc.name;
              var namePart = decodeURI(docName).match(/(.*)(\.[^\.]+)/)[1];
              app.activeDocument.activeLayer.name = namePart + "_Zadnjica";
              app.activeDocument.activeLayer.name = namePart + "_Hrbat";
              app.activeDocument.activeLayer.name = namePart + "_Prednjica";
              // additional you need a save function
              • 4. Re: Rename layers - unsaved file name + suffix
                kajzica Level 1
                script is ok but with changing all "namePart" to doc.name
                tnx
                • 5. Re: Rename layers - unsaved file name + suffix
                  kajzica schrieb:
                  … but with changing all "namePart" to doc.name
                  tnx
                  I thought, this is not what you want? Or?
                  In this case you can remove line #03 and replace namePart with docName.
                  Than is this the code you need:
                  app.activeDocument.activeLayer.name = docName + "_Zadnjica";
                  app.activeDocument.activeLayer.name = docName + "_Hrbat";
                  app.activeDocument.activeLayer.name = docName + "_Prednjica";
                  • 6. Re: Rename layers - unsaved file name + suffix
                    kajzica Level 1
                    Ok, name is added
                    Now, is it possible to add size in cm as suffix? Cropped layer size, without transparent pixels
                    Name_Zadnjica_23,5cm x 50,4cm?
                    I have some modified code from export layers to files for exporting with dimension in name but want to have it in layer name.
                            var fileNameBody = fileNamePrefix;
                            fileNameBody += "_" + zeroSuppress(i, 4);
                            fileNameBody += "_" + layerName;
                            fileNameBody = fileNameBody.replace(/[:\/\\*\?\"\<\>\|]/g, "_");  // '/\:*?"<>|' -> '_'
                            if (fileNameBody.length > 120) {
                      fileNameBody = fileNameBody.substring(0,120);
                             var x = 1;
                             var Width = duppedDocumentTmp.width.as('cm')/x;
                             var Height = duppedDocumentTmp.height.as('cm')/x;
                             Width = Width.toFixed(1).toString().replace(/\./g,',');
                             Height = Height.toFixed(1).toString().replace(/\./g,',');
                             var suffix = Width +"cm x "+Height+"cm";
                             fileNameBody += "_" + suffix;
                            saveFile(duppedDocumentTmp, fileNameBody, exportInfo);
                            docRef.flatten();
                            duppedDocumentTmp.close(SaveOptions.DONOTSAVECHANGES);
                            dupObj.artLayers[i].visible = false;
                    • 7. Re: Rename layers - unsaved file name + suffix
                      I'm sure, this is enough stuff for a new thread.
