0 Replies Latest reply on Feb 23, 2016 10:43 AM by 12345abcdefghi
    Adobe Animate CC crashes on exporting large project to air iOS
    12345abcdefghi Level 1
      Hello,
      I'm maintaining an older project of mine that I last built back in early 2015. I'm having trouble debugging it. Every time I choose to export my project to air iOS my application crashes with a stack overflow error but the crash details have no recommendations to remedy the problem. This is a very large project and memory consumption during building could be at fault but I've not found a remedy. I've tried increasing the heap size to 2500 but no luck. It does build, though. Took me a while to realize that it did. It will even uninstall the old version to install the new one. I used to do my Flash Pro work on a windows machine and I've recently switched to Mac. I'm not sure if that has anything to do with what is going on.
      When I launch my air app I get the window that says "Adobe AIR: waiting for connection". Is there any way I can connect the application to Flash Pro after it crashes? I'm asking because if this is a problem is really a bug in Adobe Animate I will need some way of getting in there looking at stack traces.
      Also I'm new to the mac side of things. Is it really nessisary to add the ios sdk and simulator paths in the project?
      Here is the crash dump I  got:
      Process:               Adobe Animate CC 2015 [8683]
      Path:                  /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/MacOS/Adobe Animate CC 2015
      Identifier:            com.adobe.Adobe Animate CC 2015.application
      Version:               15.1.0 (15.1.0.210)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Adobe Animate CC 2015 [8683]
      User ID:               501
      Date/Time:             2016-02-23 13:29:09.481 -0500
      OS Version:            Mac OS X 10.11.3 (15D21)
      Report Version:        11
      Anonymous UUID:        C2CB3458-423B-7FD9-9D5C-5442E91B567C
      Time Awake Since Boot: 2900 seconds
      System Integrity Protection: enabled
      Crashed Thread:        64
      Exception Type:        EXC_CRASH (SIGABRT)
      Exception Codes:       0x0000000000000000, 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      Application Specific Information:
      [8683] stack overflow
      Global Trace Buffer (reverse chronological seconds):
      169.924269   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x11238e080 SSL Handshake DONE
      169.964922   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x114b68320 SSL Handshake DONE
      170.003030   CFNetwork                 0x00007fff9a500937 TCP Conn 0x114b68320 starting SSL negotiation
      170.005258   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x114b68320 complete. fd: 39, err: 0
      170.005434   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x114b68320 event 1. err: 0
      170.050276   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x114b68320 started
      170.053167   CFNetwork                 0x00007fff9a500937 TCP Conn 0x11238e080 starting SSL negotiation
      170.053285   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x11238e080 complete. fd: 37, err: 0
      170.053436   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x11238e080 event 1. err: 0
      170.096558   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x11238e080 started
      170.617862   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x10d693240 SSL Handshake DONE
      170.692345   CFNetwork                 0x00007fff9a500937 TCP Conn 0x10d693240 starting SSL negotiation
      170.692549   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x10d693240 complete. fd: 37, err: 0
      170.692618   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x10d693240 event 1. err: 0
      170.718514   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x10d693240 started
      170.851786   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x10d649c40 complete. fd: 32, err: 0
      170.851833   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x10d649c40 event 1. err: 0
      170.898082   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x10d649c40 started
      174.944955   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x114b17fa0 SSL Handshake DONE
      175.047470   CFNetwork                 0x00007fff9a500937 TCP Conn 0x114b17fa0 starting SSL negotiation
      175.047729   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x114b17fa0 complete. fd: 23, err: 0
      175.047883   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x114b17fa0 event 1. err: 0
      175.097839   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x11701f840 SSL Handshake DONE
      175.106718   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x114b17fa0 started
      175.182039   CFNetwork                 0x00007fff9a500937 TCP Conn 0x11701f840 starting SSL negotiation
      175.182191   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x11701f840 complete. fd: 21, err: 0
      175.182257   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x11701f840 event 1. err: 0
      175.266245   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x11701f840 started
      175.398160   CFNetwork                 0x00007fff9a500a5b TCP Conn 0x11264dc10 SSL Handshake DONE
      175.575186   CFNetwork                 0x00007fff9a500937 TCP Conn 0x11264dc10 starting SSL negotiation
      175.575469   CFNetwork                 0x00007fff9a4ff303 TCP Conn 0x11264dc10 complete. fd: 13, err: 0
      175.575568   CFNetwork                 0x00007fff9a58db1d TCP Conn 0x11264dc10 event 1. err: 0
      175.664390   CFNetwork                 0x00007fff9a4fe5d3 TCP Conn 0x11264dc10 started
      Thread 0:: Dispatch queue: com.apple.main-thread
      0   libsystem_kernel.dylib         0x00007fff960af386 mach_msg_trap + 10
      1   libsystem_kernel.dylib         0x00007fff960ae7c7 mach_msg + 55
      2   com.apple.CoreFoundation       0x00007fff8f8de624 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation       0x00007fff8f8ddaec __CFRunLoopRun + 1356
      4   com.apple.CoreFoundation       0x00007fff8f8dd338 CFRunLoopRunSpecific + 296
      5   com.apple.Foundation           0x00007fff97629e61 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
      6   com.adobe.FLAirDesktopExt.framework 0x000000011d844163 -[FilePublishCtrlMustard filePublishAIR:pubinstaller:] + 451
      7   com.adobe.FLAirDesktopExt.framework 0x000000011d847b35 DoPublish(JSContext*, JSObject*, unsigned int, long*, long*, __CFString const*) + 3349
      8   com.adobe.FLAirDesktopExt.framework 0x000000011d846850 DebugOnDevice(JSContext*, JSObject*, unsigned int, long*, long*) + 16
      9   com.adobe.Adobe Animate CC 2015.application 0x000000010158ee65 js_Invoke + 1813
      10  com.adobe.Adobe Animate CC 2015.application 0x0000000101587f1a js_Interpret + 29130
      11  com.adobe.Adobe Animate CC 2015.application 0x000000010158f582 js_Execute + 722
      12  com.adobe.Adobe Animate CC 2015.application 0x000000010155cece JS_EvaluateUCScriptForPrincipals + 94
      13  com.adobe.Adobe Animate CC 2015.application 0x000000010155ce6a JS_EvaluateUCScript + 42
      14  com.adobe.Adobe Animate CC 2015.application 0x00000001013795b0 JSInterp::EvaluateScript(JSContext*, JSObject*, unsigned short const*, unsigned int, unsigned short const*, unsigned int, long*) + 160
      15  com.adobe.Adobe Animate CC 2015.application 0x0000000101372539 ExecScript(JSObject*, unsigned short const*, unsigned short const*, int, JsflDoc*, unsigned short const*, CString*, signed char) + 377
      16  com.adobe.Adobe Animate CC 2015.application 0x000000010137229d JSInterp::ExecuteScript(CPicObj*, JsflDoc*, unsigned short const*, unsigned short const*, unsigned short const*, int, unsigned short const*, CString*, JSInterp::ScriptMode, signed char, signed char, signed char, signed char, signed char, signed char) + 397
      17  com.adobe.Adobe Animate CC 2015.application 0x0000000100a66366 CSketchView::RunJSScript(CString, CString) + 278
      18  com.adobe.Adobe Animate CC 2015.application 0x0000000100a675e5 CSketchView::DebugAIRMovie(CString const&, CString const&, CString const&, CString const&, unsigned int) + 741
      19  com.adobe.Adobe Animate CC 2015.application 0x0000000100a67054 CSketchView::DebugAIRMovie(CString const&, CString const&, unsigned int) + 548
      20  com.adobe.Adobe Animate CC 2015.application 0x0000000100a6a25d CSketchView::DoDebugMovie(unsigned int, signed char, signed char) + 669
      21  com.adobe.Adobe Animate CC 2015.application 0x0000000100a6be3f CSketchView::OnControlDebugMovieOnDevice() + 31
      22  com.adobe.Adobe Animate CC 2015.application 0x000000010003ef36 flashpro::App::OnDebugDeviceViaUSB(int) + 582
      23  com.adobe.Adobe Animate CC 2015.application 0x0000000100047f31 boost::detail::function::function_obj_invoker1<boost::_bi::bind_t<bool, boost::_mfi::mf1<bool, flashpro::App, int>, boost::_bi::list2<boost::_bi::value<flashpro::App*>, boost::arg<1> > >, bool, int>::invoke(boost::detail::function::function_buffer&, int) + 33
      24  com.adobe.Adobe Animate CC 2015.application 0x0000000100041cb2 exo::uisupport::CommandDispatcher<exo::app::MultiDocApplication>::DoHandleCommand(int) + 114
      25  com.adobe.Adobe Animate CC 2015.application 0x000000010002f63d flashpro::App::DoHandleCommand(int) + 45
      26  com.adobe.Adobe Animate CC 2015.application 0x0000000100035130 non-virtual thunk to flashpro::App::DoHandleCommand(int) + 16
      27  com.adobe.exo.framework       0x00000001054c9d4c exo::uisupport::CommandHandler::HandleCommand(int) + 220
      28  com.adobe.exo.framework       0x00000001054c9f88 exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 24
      29  com.adobe.exo.framework       0x00000001054c9878 exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 56
      30  com.adobe.exo.framework       0x000000010545e512 exo::app::OS_AppBase::DispatchMenuCommand(int) + 130
      31  com.adobe.dvacore.framework   0x0000000103eadf9c int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      32  com.adobe.Adobe Animate CC 2015.application 0x0000000100059064 flashpro::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int> ) + 36
      33  com.adobe.dvacore.framework   0x0000000103eae0e8 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 136
      34  com.adobe.dvacore.framework   0x0000000103eaf5a5 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 165
      35  com.adobe.exo.framework       0x000000010545f858 -[ExoMacApplication handleMenuCommand:] + 136
      36  libsystem_trace.dylib         0x00007fff9500207a _os_activity_initiate + 75
      37  com.apple.AppKit               0x00007fff8b58251d -[NSApplication sendAction:to:from:] + 460
      38  com.apple.AppKit               0x00007fff8b5822b7 -[NSMenuItem _corePerformAction] + 336
      39  com.apple.AppKit               0x00007fff8b582017 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114
      40  libsystem_trace.dylib         0x00007fff9500207a _os_activity_initiate + 75
      41  com.apple.AppKit               0x00007fff8b6421f0 -[NSMenu performActionForItemAtIndex:] + 131
      42  com.adobe.dvaui.framework     0x00000001047a7434 -[DVAMacMenu performActionForItemAtIndex:] + 52
      43  com.apple.AppKit               0x00007fff8b642163 -[NSMenu _internalPerformActionForItemAtIndex:] + 35
      44  com.apple.AppKit               0x00007fff8b641fbb -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 107
      45  com.apple.AppKit               0x00007fff8b56aea1 NSSLMMenuEventHandler + 708
      46  com.apple.HIToolbox           0x00007fff8ae3e7be DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1231
      47  com.apple.HIToolbox           0x00007fff8ae3dc48 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 404
      48  com.apple.HIToolbox           0x00007fff8ae539e6 SendEventToEventTarget + 40
      49  com.apple.HIToolbox           0x00007fff8ae9d99a SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
      50  com.apple.HIToolbox           0x00007fff8aec8d5b SendMenuCommandWithContextAndModifiers + 59
      51  com.apple.HIToolbox           0x00007fff8aec8d0c SendMenuItemSelectedEvent + 188
      52  com.apple.HIToolbox           0x00007fff8aec8be8 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
      53  com.apple.HIToolbox           0x00007fff8aec9596 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 711
      54  com.apple.HIToolbox           0x00007fff8aec9230 _HandleMenuSelection2 + 460
      55  com.apple.AppKit               0x00007fff8b49575e _NSHandleCarbonMenuEvent + 277
      56  com.apple.AppKit               0x00007fff8b3d5435 _DPSNextEvent + 1906
      57  com.apple.AppKit               0x00007fff8b7a1943 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
      58  com.apple.AppKit               0x00007fff8b3cafc8 -[NSApplication run] + 682
      59  com.adobe.exo.framework       0x000000010545eba8 exo::app::OS_AppBase::RunEventLoop() + 56
      60  com.adobe.Adobe Animate CC 2015.application 0x0000000100161dd6 main + 758
      61  com.adobe.Adobe Animate CC 2015.application 0x0000000100002e64 start + 52
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib         0x00007fff960b5ff6 kevent_qos + 10
      1   libdispatch.dylib             0x00007fff8a861099 _dispatch_mgr_invoke + 216
      2   libdispatch.dylib             0x00007fff8a860d01 _dispatch_mgr_thread + 52
      Thread 2:: Dispatch queue: com.apple.notify.background.local.notification
      2   libsystem_notify.dylib         0x00007fff8fe30dca __notify_register_mach_port_block_invoke_3 + 89
      3   libdispatch.dylib             0x00007fff8a866871 _dispatch_call_block_and_release + 12
      4   libdispatch.dylib             0x00007fff8a85b33f _dispatch_client_callout + 8
      5   libdispatch.dylib             0x00007fff8a85ff6f _dispatch_queue_drain + 754
      6   libdispatch.dylib             0x00007fff8a86663b _dispatch_queue_invoke + 549
      7   libdispatch.dylib             0x00007fff8a85b33f _dispatch_client_callout + 8
      8   libdispatch.dylib             0x00007fff8a85f1cf _dispatch_root_queue_drain + 1890
      9   libdispatch.dylib             0x00007fff8a85ea34 _dispatch_worker_thread3 + 91
      10  libsystem_pthread.dylib       0x00007fff8ac5c68f _pthread_wqthread + 1129
      11  libsystem_pthread.dylib       0x00007fff8ac5a365 start_wqthread + 13
      Thread 3:
      0   libsystem_kernel.dylib         0x00007fff960b4eb2 __psynch_cvwait + 10
      1   libsystem_pthread.dylib       0x00007fff8ac5d150 _pthread_cond_wait + 767
      2   com.adobe.headlights.LogSessionFramework 0x0000000109fcb07c boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
      3   com.adobe.headlights.LogSessionFramework 0x0000000109fc993e boost::this_thread::hiden::sleep_until(timespec const&) + 78
      4   com.adobe.headlights.LogSessionFramework 0x0000000109f722d3 RealTimeProcessor::Sleep(int) + 243
      5   com.adobe.headlights.LogSessionFramework 0x0000000109f708e2 RealTimeProcessor::WorkerThread() + 2660
      6   com.adobe.headlights.LogSessionFramework 0x0000000109fc899a boost::(anonymous namespace)::thread_proxy(void*) + 138
      7   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      8   libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      9   libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 4:: com.apple.NSURLConnectionLoader
      5   com.apple.CFNetwork           0x00007fff9a4c56e9 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
      6   com.apple.Foundation           0x00007fff97775c6f __NSThread__start__ + 1351
      Thread 5:: com.apple.CFSocket.private
      0   libsystem_kernel.dylib         0x00007fff960b5176 __select + 10
      1   com.apple.CoreFoundation       0x00007fff8f92a16a __CFSocketManager + 762
      2   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      3   libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      4   libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 6:
      0   libsystem_kernel.dylib         0x00007fff960b50b6 __recvfrom + 10
      1   VulcanMessage5.dylib           0x000000010c73e386 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
      2   VulcanMessage5.dylib           0x000000010c73d5fd vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
      3   VulcanMessage5.dylib           0x000000010c73c9b8 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
      4   VulcanMessage5.dylib           0x000000010c73c8ee vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
      5   VulcanMessage5.dylib           0x000000010c737498 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
      6   VulcanMessage5.dylib           0x000000010c737936 vcfoundation::io::Serializer::InternalDeserialize() + 30
      7   VulcanMessage5.dylib           0x000000010c7378dd vcfoundation::io::Serializer::Deserialize() + 9
      8   VulcanMessage5.dylib           0x000000010c73b762 vcfoundation::ncomm::Connection::ReadIn() + 22
      9   VulcanMessage5.dylib           0x000000010c73b489 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
      10  VulcanMessage5.dylib           0x000000010c73b10a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
      11  VulcanMessage5.dylib           0x000000010c73b05d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
      12  VulcanMessage5.dylib           0x000000010c72de66 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
      13  VulcanMessage5.dylib           0x000000010c72e91f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
      14  VulcanMessage5.dylib           0x000000010c73c288 vcfoundation::thread::AbstractThread::Run() + 50
      15  VulcanMessage5.dylib           0x000000010c73dda9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
      16  libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      17  libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      18  libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 7:: BackgroundThread
      2   com.macromedia.Flash Player.authplaylib 0x000000012d3f75ab 0x12d000000 + 4158891
      3   com.macromedia.Flash Player.authplaylib 0x000000012d04968e 0x12d000000 + 300686
      4   com.macromedia.Flash Player.authplaylib 0x000000012d3f73bd 0x12d000000 + 4158397
      5   com.macromedia.Flash Player.authplaylib 0x000000012d3f7402 0x12d000000 + 4158466
      6   com.macromedia.Flash Player.authplaylib 0x000000012d3f7147 0x12d000000 + 4157767
      Thread 8:: BackgroundThread
      Thread 9:: BackgroundThread
      Thread 10:: BackgroundThread
      Thread 11:: BackgroundThread
      Thread 12:: BackgroundThread
      Thread 13:: BackgroundThread
      Thread 14:: BackgroundThread
      Thread 15:: BackgroundThread
      Thread 16:: BackgroundThread
      Thread 17:: BackgroundThread
      Thread 18:: BackgroundThread
      Thread 19:
      5   com.apple.Foundation           0x00007fff976bc48d -[NSConnection run] + 149
      Thread 20:
      5   com.apple.Foundation           0x00007fff975c4f86 -[NSConcreteTask waitUntilExit] + 205
      6   com.adobe.PlugPlugOwl         0x000000010a2a8778 -[HtmlEngineMonitor monitorThreadProc] + 115
      7   com.apple.Foundation           0x00007fff97775c6f __NSThread__start__ + 1351
      8   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      9   libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      10  libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 21:
      Thread 22:
      Thread 23:: com.apple.NSEventThread
      5   com.apple.AppKit               0x00007fff8b494065 _NSEventThread + 149
      Thread 24:
      0   libsystem_kernel.dylib         0x00007fff960b5206 __semwait_signal + 10
      1   libsystem_c.dylib             0x00007fff8fd64d17 nanosleep + 199
      2   com.adobe.FLBridge.framework   0x000000011dbc35a8 ScObjects::Thread::wait(unsigned int) + 56
      3   com.adobe.FLBridge.framework   0x000000011dbbea2e ScObjects::BridgeTalkThread::run() + 174
      4   com.adobe.FLBridge.framework   0x000000011dbc3165 ScObjects::Thread::go(void*) + 165
      5   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      6   libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      7   libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 25:: ScriptTimeout
      2   com.macromedia.Flash Player.authplaylib 0x000000012d3f761e 0x12d000000 + 4159006
      3   com.macromedia.Flash Player.authplaylib 0x000000012d22c4f6 0x12d000000 + 2278646
      Thread 26:: CVDisplayLink
      2   com.apple.CoreVideo           0x00007fff8c79cf76 CVDisplayLink::runIOThread() + 676
      3   com.apple.CoreVideo           0x00007fff8c79c9a9 startIOThread(void*) + 147
      4   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      5   libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      6   libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 27:
      2   libjvm.dylib                   0x000000016df8f8a4 os::PlatformEvent::park() + 192
      3   libjvm.dylib                   0x000000016df6d5f4 ParkCommon(ParkEvent*, long) + 42
      4   libjvm.dylib                   0x000000016df6deca Monitor::IWait(Thread*, long) + 168
      5   libjvm.dylib                   0x000000016df6e133 Monitor::wait(bool, long, bool) + 375
      6   libjvm.dylib                   0x000000016dd90332 GCTaskManager::get_task(unsigned int) + 56
      7   libjvm.dylib                   0x000000016dd91111 GCTaskThread::run() + 349
      8   libjvm.dylib                   0x000000016df93a8e java_start(Thread*) + 246
      9   libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      10  libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      11  libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 28:
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      Thread 33:
      Thread 34:
      Thread 35:
      Thread 36:
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      Thread 41:
      Thread 42:
      Thread 43:
      Thread 44:
      Thread 45:
      2   libjvm.dylib                   0x000000016df9078e os::PlatformEvent::park(long) + 404
      3   libjvm.dylib                   0x000000016df6deca Monitor::IWait(Thread*, long) + 168
      4   libjvm.dylib                   0x000000016df6e133 Monitor::wait(bool, long, bool) + 375
      5   libjvm.dylib                   0x000000016e0b98ca VMThread::loop() + 444
      6   libjvm.dylib                   0x000000016e0b9355 VMThread::run() + 121
      7   libjvm.dylib                   0x000000016df93a8e java_start(Thread*) + 246
      Thread 46:: Java: Reference Handler
      3   libjvm.dylib                   0x000000016df87a42 ObjectMonitor::wait(long, bool, Thread*) + 748
      4   libjvm.dylib                   0x000000016e03ca58 ObjectSynchronizer::wait(Handle, long, Thread*) + 202
      5   libjvm.dylib                   0x000000016de5eba2 JVM_MonitorWait + 156
      6   ???                           0x000000016eaf0394 0 + 6151930772
      7   ???                           0x000000016eae2c4d 0 + 6151875661
      8   ???                           0x000000016eae2c4d 0 + 6151875661
      9   ???                           0x000000016eadb7a7 0 + 6151845799
      10  libjvm.dylib                   0x000000016de0536e JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
      11  libjvm.dylib                   0x000000016de05afc JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
      12  libjvm.dylib                   0x000000016de05ca8 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
      13  libjvm.dylib                   0x000000016de581e9 thread_entry(JavaThread*, Thread*) + 124
      14  libjvm.dylib                   0x000000016e06eacf JavaThread::thread_main_inner() + 155
      15  libjvm.dylib                   0x000000016e0701c0 JavaThread::run() + 450
      16  libjvm.dylib                   0x000000016df93a8e java_start(Thread*) + 246
      17  libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      18  libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      19  libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 47:: Java: Finalizer
      7   ???                           0x000000016f26c474 0 + 6159778932
      8   ???                           0x000000016eadb7a7 0 + 6151845799
      9   libjvm.dylib                   0x000000016de0536e JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
      10  libjvm.dylib                   0x000000016de05afc JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
      11  libjvm.dylib                   0x000000016de05ca8 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
      12  libjvm.dylib                   0x000000016de581e9 thread_entry(JavaThread*, Thread*) + 124
      13  libjvm.dylib                   0x000000016e06eacf JavaThread::thread_main_inner() + 155
      14  libjvm.dylib                   0x000000016e0701c0 JavaThread::run() + 450
      15  libjvm.dylib                   0x000000016df93a8e java_start(Thread*) + 246
      Thread 48:: Java: Signal Dispatcher
      0   libsystem_kernel.dylib         0x00007fff960af3c2 semaphore_wait_trap + 10
      1   libjvm.dylib                   0x000000016df91df4 check_pending_signals(bool) + 128
      2   libjvm.dylib                   0x000000016df8e935 signal_thread_entry(JavaThread*, Thread*) + 57
      Thread 49:: Java: C2 CompilerThread0
      4   libjvm.dylib                   0x000000016df6e09a Monitor::wait(bool, long, bool) + 222
      5   libjvm.dylib                   0x000000016dcd762a CompileQueue::get() + 122
      6   libjvm.dylib                   0x000000016dcd784c CompileBroker::compiler_thread_loop() + 376
      7   libjvm.dylib                   0x000000016e06eacf JavaThread::thread_main_inner() + 155
      8   libjvm.dylib                   0x000000016e0701c0 JavaThread::run() + 450
      9   libjvm.dylib                   0x000000016df93a8e java_start(Thread*) + 246
      10  libsystem_pthread.dylib       0x00007fff8ac5cc13 _pthread_body + 131
      11  libsystem_pthread.dylib       0x00007fff8ac5cb90 _pthread_start + 168
      12  libsystem_pthread.dylib       0x00007fff8ac5a375 thread_start + 13
      Thread 50:: Java: C2 CompilerThread1
      Thread 51:: Java: C2 CompilerThread2
      Thread 52:: Java: C2 CompilerThread3
      Thread 53:: Java: C2 CompilerThread4
      Thread 54:: Java: C2 CompilerThread5
      Thread 55:: Java: C2 CompilerThread6
      Thread 56:: Java: C2 CompilerThread7
      Thread 57:: Java: C1 CompilerThread8
      Thread 58:: Java: C1 CompilerThread9
      Thread 59:: Java: C1 CompilerThread10
      Thread 60:: Java: C1 CompilerThread11
      Thread 61:: Java: Service Thread
      6   libjvm.dylib                   0x000000016dfe8c22 ServiceThread::service_thread_entry(JavaThread*, Thread*) + 132
      Thread 62:
      5   libjvm.dylib                   0x000000016e06efa2 WatcherThread::sleep() const + 126
      6   libjvm.dylib                   0x000000016e06fe35 WatcherThread::run() + 243
      Thread 63:
      0   libsystem_kernel.dylib         0x00007fff960b56de __workq_kernreturn + 10
      1   libsystem_pthread.dylib       0x00007fff8ac5c729 _pthread_wqthread + 1283
      2   libsystem_pthread.dylib       0x00007fff8ac5a365 start_wqthread + 13
      Thread 64 Crashed:
      0   libsystem_kernel.dylib         0x00007fff960b5002 __pthread_kill + 10
      1   libsystem_pthread.dylib       0x00007fff8ac5e5c5 pthread_kill + 90
      2   libsystem_c.dylib             0x00007fff8fd43787 __abort + 145
      3   libsystem_c.dylib             0x00007fff8fd44066 __stack_chk_fail + 200
      4   com.adobe.FLAirDesktopExt.framework 0x000000011d83fffa CreateAIRFile(int, NSMutableString*, TaskWrapperMustard*) + 2282
      5   ???                           0x6573552f79617272 0 + 7310280282540700274
      Thread 65:
      2   com.apple.Foundation           0x00007fff9765b353 +[NSThread sleepUntilDate:] + 176
      3   com.adobe.FLAirDesktopExt.framework 0x000000011d84429b -[FilePublishCtrlMustard updateProgressLoop] + 123
      4   com.apple.Foundation           0x00007fff97775c6f __NSThread__start__ + 1351
      Thread 66:
      Thread 67:
      Thread 64 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x000070000029d188  rdx: 0x0000000000000000
        rdi: 0x0000000000011f1b  rsi: 0x0000000000000006  rbp: 0x000070000029d1b0  rsp: 0x000070000029d188
         r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000000008000000  r11: 0x0000000000000206
        r12: 0x0000000159d92bc0  r13: 0x000000011d8734e8  r14: 0x00007000002a0000  r15: 0x0000000159d92bc0
        rip: 0x00007fff960b5002  rfl: 0x0000000000000206  cr2: 0x00007fff76821118
      Logical CPU:     0
      Error Code:      0x02000148
      Trap Number:     133
      Binary Images:
             0x100000000 -        0x101f71fff +com.adobe.Adobe Animate CC 2015.application (15.1.0 - 15.1.0.210) <306E5732-89DB-3C4B-970C-0D514B93AF40> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/MacOS/Adobe Animate CC 2015
             0x103e22000 -        0x103e25fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x103e2c000 -        0x103e2efff +com.adobe.boost_system.framework (15.1.0 - 15.1.0.210) <8DA45601-FAA6-309E-A931-1F3AE799CBC3> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x103e37000 -        0x103e3dff7 +com.adobe.boost_date_time.framework (15.1.0 - 15.1.0.210) <36410E05-A1FD-35FE-B22E-6F28AAB70419> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x103e54000 -        0x103e63ff7 +com.adobe.boost_threads.framework (15.1.0 - 15.1.0.210) <57ECEEA3-2970-300F-999D-5590C0E37D00> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x103e83000 -        0x10413efff +com.adobe.dvacore.framework (15.1.0 - 15.1.0.210) <B1FF34BE-0214-3FF7-82A7-792592CBCCB3> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x1043b4000 -        0x1043c0ff7 +com.adobe.boost_signals.framework (15.1.0 - 15.1.0.210) <6AFFA04A-2415-3EFE-8E0A-2B1B83C9B85C> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x1043db000 -        0x104976ff7 +com.adobe.dvaui.framework (15.1.0 - 15.1.0.210) <8A20EB57-5E6B-3DFA-B60F-0C0DBEACB27C> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x1051ce000 -        0x1052bdff7 +com.adobe.dvaworkspace.framework (15.1.0 - 15.1.0.210) <4680E0C2-A17A-336E-9F7F-C3BB27504F3A> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x105456000 -        0x105532fff +com.adobe.exo.framework (15.1.0 - 15.1.0.210) <E2186C16-1827-37D4-A702-0A7453990680> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x1056c6000 -        0x1056eafff +com.adobe.dvaunittesting.framework (15.1.0 - 15.1.0.210) <FB943636-B479-3F78-8FB3-5253508EDB50> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x10572b000 -        0x105744ff7 +com.adobe.dvatexteditor.framework (15.1.0 - 15.1.0.210) <11BEF2AA-7CC7-3DCE-8577-FAE6B44733B0> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvatexteditor.framework/Versions/A/dvatexteditor
             0x105789000 -        0x1058ccfff +com.adobe.scintilla.framework (15.1.0 - 15.1.0.210) <9DB4247D-B70B-3CDF-A042-551B9F0422E5> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/scintilla.framework/Versions/A/scintilla
             0x10595a000 -        0x105a48ff7 +com.adobe.FlashIK.framework (15.1.0 - 15.1.0.210) <BB1D75CC-71A9-3DC2-80DF-D7EA27690501> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
             0x105ade000 -        0x105b17ff7 +com.adobe.PFF.framework (15.1.0 - 15.1.0.210) <FC181415-5455-3B40-8F05-865E463979F8> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
             0x105b44000 -        0x105e9afff +com.adobe.dvaadameve.framework (15.1.0 - 15.1.0.210) <56D310D9-6C54-3175-83FC-7D5712301C70> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
             0x1066b8000 -        0x1066c6ff7 +com.adobe.boost_filesystem.framework (15.1.0 - 15.1.0.210) <437B384A-1B2C-3F40-B805-73CBA4FF131E> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
             0x1066da000 -        0x106781fff +com.adobe.boost_regex.framework (15.1.0 - 15.1.0.210) <477D7157-1FCB-30A7-800B-32DB31AAC565> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
             0x10681a000 -        0x106843fff +com.adobe.mfcdata.framework (15.1.0 - 15.1.0.210) <8142B35D-0572-3CEE-882A-527CA95E9FCD> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/mfcdata.framework/Versions/A/mfcdata
             0x106889000 -        0x108ab5f47 +com.adobe.psl (AdobePSL 15.1.0.34015 - 15.1.0.34015) <7B2AA133-FD2F-3DF4-9737-994B710AB33F> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x108f3d000 -        0x109137fff +com.adobe.owl (AdobeOwl version 5.2.5 - 5.2.5) <ED3A945A-FF98-38F8-8085-B0D87291D066> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
             0x10917c000 -        0x109219fff +com.adobe.flashplayercore.framework (15.1.0 - 15.1.0.210) <CDCFD0E4-ABA5-3C62-96EA-F21139D47281> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/flashplayercore.framework/Versions/A/flashplayercore
             0x109286000 -        0x109744fe7 +com.adobe.flverify.framework (15.1.0 - 15.1.0.210) <1F2D92B5-7F4B-3AD5-A9A0-98EAE7BB6681> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/flverify.framework/Versions/A/flverify
             0x109b66000 -        0x109baffff +com.adobe.brushparser.framework (15.1.0 - 15.1.0.210) <5FCCEC09-4A8E-35EA-A71D-E56C08627061> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/brushparser.framework/Versions/A/brushparser
             0x109be0000 -        0x109dcafff +com.adobe.AFlamingo (AFlamingo 2.4.402.40000 - 2.4.402.40000) <94E1DD0B-6941-3FBF-8B94-5051E9A84935> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
             0x109dec000 -        0x109e08fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x109e14000 -        0x109e28ff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.33621 - 1.1.0.33621) <4C5F9909-758F-36AF-B72C-29BE5770D9F7> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
             0x109e30000 -        0x109e4bff7 +com.adobe.cloudsync.framework (15.1.0 - 15.1.0.210) <22AB257A-6A96-36B8-B8E2-2FD5AB15EEB2> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/cloudsync.framework/Versions/A/cloudsync
             0x109ea0000 -        0x109edafff +com.adobe.pip (7.3.1.72) <A00A5967-3014-35EA-B24D-C24581F180C8> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
             0x109ee4000 -        0x10a024fff +com.adobe.headlights.LogSessionFramework (7.3.1.72) <EE72ED3F-9A64-372D-A709-67F79995E15D> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x10a0d8000 -        0x10a1d9fff +com.adobe.amtlib (9.0.0.21 - 9.0.0.21) <BAE71CEB-B622-38DB-A0A2-796C0BEB4E03> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10a1ec000 -        0x10a50afcf +com.adobe.PlugPlugOwl (6.1.0.148 - 6.1.0.148) <F0C3D3B0-612D-322E-A226-6B1648E4AB9D> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
             0x10a839000 -        0x10a987ff7 +com.adobe.ACE (AdobeACE 2.20.02.34163 - 2.20.02.34163) <DCD064B8-A43A-3D41-B499-15E602F69CDA> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x10a99b000 -        0x10af54ff7 +com.adobe.AGM (AdobeAGM 4.30.47.34163 - 4.30.47.34163) <3F0E0A79-8102-38AE-AE2A-B86B27A9432A> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x10afef000 -        0x10b00efff +com.adobe.BIB (AdobeBIB 1.2.03.34163 - 1.2.03.34163) <644F8DE0-3E61-374D-B17D-44ED3BD10D60> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x10b016000 -        0x10b03cff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <3318FE3E-8AB8-3821-A1FB-8A8D62C20303> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10b044000 -        0x10b369fff +com.adobe.CoolType (AdobeCoolType 5.15.00.34163 - 5.15.00.34163) <FDE71863-DCD4-3E7F-8EE6-AED39929AD75> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x10b3b1000 -        0x10b3eeff7 +com.adobe.ARE (AdobeARE 1.5.02.34163 - 1.5.02.34163) <B063E83E-6668-3BB1-BA6B-E8C7ECC09EC8> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x10b3f6000 -        0x10b4fbfff +com.adobe.PDFPort (AdobePDFPort 2.1.0.34163 - 2.1.0.34163) <B722768C-5135-32EC-9B39-1545486E4F78> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
             0x10b50e000 -        0x10b8c5fff +com.adobe.MPS (AdobeMPS 5.8.1.34169 - 5.8.1.34169) <552A5682-BD79-3DC1-AF7C-C7E175E63C6F> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x10b936000 -        0x10c0cffff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.34348) <4D649496-C10E-351F-B665-ABB0BD0C9FC3> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
             0x10c18c000 -        0x10c436fef +libxerces-c-3.1.dylib (0) <4B8CA11E-F109-5587-49E3-9BDEE767CD82> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/libxerces-c-3.1.dylib
             0x10c6d9000 -        0x10c6f9fff +VulcanControl.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <7DED4C28-2DC8-397F-9BCF-FB4777D99386> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/VulcanControl.dylib
             0x10c720000 -        0x10c758ff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
             0x10c79a000 -        0x10c7cafef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/libtbb.dylib
             0x10c7e6000 -        0x10c80bfff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10c835000 -        0x10c859ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34015 - 3.8.0.34015) <980415D4-681E-3EA0-B97A-121551CC5420> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
             0x10c87d000 -        0x10c9adff7 +com.winsoft.wrservices (WRServices 9.0.0 - 9.0.0) <31C071F2-CDD0-3197-BFFB-0FCE609AAB86> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10ca0b000 -        0x10cac4ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.34015) <8C8C7B04-383E-321F-8C97-0EC2E756308A> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x10cb0a000 -        0x10cc11ff7 +AdobeXMP (???) <2F05DEF3-A3F5-3C32-81F1-C9FB7CA4EBAC> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x10ccfd000 -        0x10cd01fff  com.apple.agl (3.3.1 - AGL-3.3.1) <8B380B9E-3E00-3065-842E-41F4421D8D5A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x10cd09000 -        0x10ceb4ff7 +com.adobe.SynKitLib (1.0.0.88 - 1.0.0.88) <EAD5315A-50F2-31AF-9520-99FF80DF6FF2> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
             0x10cfde000 -        0x10d126fff +com.adobe.AIDE (1.5.0 - 1.5.0.34133) <5F56EA96-F39E-3F18-9AF4-57D517C40709> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
             0x10d5e6000 -        0x10d5e8ff7  com.apple.textencoding.unicode (3.0 - 3.0) <78B2E03E-3AE3-34E0-AA72-22F1D696170B> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x118f36000 -        0x118f5ffff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
             0x11c0d3000 -        0x11c113ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.3 - 9.0.0.3) <2F5B40E6-812C-34E0-A8AC-02F55D770D49> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
             0x11c5f9000 -        0x11c736fef +IMSLib.dylib (9.0.1.28 - 9.0.1.28) <5FC6C059-D74C-3F40-99C3-2B2C111878E6> /Library/Application Support/Adobe/*/IMSLib.dylib
             0x11c973000 -        0x11c974fff  ATSHI.dylib (394.3) <5C52C614-3D7C-3E7F-9AE2-9905DDB9F10F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
             0x11c98c000 -        0x11c990fff  libFontRegistryUI.dylib (155.1) <79B125DD-4565-391D-A084-DB4F2A7CF322> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
             0x11c9c3000 -        0x11ca25fff +com.adobe.mexport.framework (15.1.0 - 15.1.0.210) <84723517-C2A5-3119-B231-F11FB7096350> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/mexport.bundle/Contents/MacOS/mexport
             0x11ccf4000 -        0x11cd6eff7  com.apple.xquery (1.3.1 - 30) <AAEFB337-E58A-39F5-8C19-6E990401B72F> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
             0x11ce0e000 -        0x11ce16fff +libverify.dylib (1) <104A5FA8-FAD8-3CF1-AECA-F66A46990FF8> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/jre/jre1.8.0_40.jre/Contents/Home/lib/libverify.dylib
             0x11cff2000 -        0x11d00eff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
             0x11d014000 -        0x11d036ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
             0x11d03b000 -        0x11d04aff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
             0x11d04f000 -        0x11d061fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
             0x11d186000 -        0x11d18afff  com.apple.audio.AppleHDAHALPlugIn (272.51.3 - 272.51.3) <7E9DC6D6-CB61-3EA1-94AD-5C6F20D3EDBF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x11d7e0000 -        0x11d80bfff +com.adobe.FLAirAndroidExt.framework (15.1.0 - 15.1.0.210) <8CBC89C7-65E8-37EE-AE21-6B087040059C> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/FLAirAndroidExt.bundle/Contents/MacOS/FLAirAndroidExt
             0x11d839000 -        0x11d86dfff +com.adobe.FLAirDesktopExt.framework (15.1.0 - 15.1.0.210) <76A954CF-98B4-3733-AA19-EE10CB1D2013> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/FLAirDesktopExt.bundle/Contents/MacOS/FLAirDesktopExt
             0x11da08000 -        0x11da9efff +com.adobe.adobe_caps (adobe_caps 9.0.0.5 - 9.0.0.5) <71BDFB88-91D4-35B1-9860-82F31ACBDE38> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
             0x11dba2000 -        0x11dba2ff7 +cl_kernels (???) <53E107C0-71DF-4EF9-9FB6-FEAD7B11821A> cl_kernels
             0x11dba4000 -        0x11dbecff7 +com.adobe.FLBridge.framework (13.2.0 - 13.2.0.0) <3DD300A6-CCC0-3F22-9A53-057803AE3854> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
             0x11dfdc000 -        0x11e01dfff +com.adobe.FLCreateJS.framework (1.2.0 - 1.2.0.0) <74C1F5C4-3AD9-32DB-BFAE-0ECD7FD0B995> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/FLCreateJS.bundle/Contents/MacOS/FLCreateJS
             0x11e052000 -        0x11ec73fff +com.adobe.AFlame (AFlame 2.07.27.1 - 2.07.27.1) <001BED54-E51B-3BC9-AA7A-2C2C56CAA42B> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
             0x11f623000 -        0x11f787ff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <F35C19E3-EADE-3DCD-A487-394A474895CE> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
             0x11f7d8000 -        0x11f7e2fff +libjli.dylib (1) <1027E2C5-53BF-3E53-9B40-51386EF0F570> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/jre/jre1.8.0_40.jre/Contents/Home/lib/jli/libjli.dylib
             0x11f821000 -        0x11f838ff7 +com.adobe.FLfile.framework (15.1.0 - 15.1.0.210) <3B7DF97A-D321-3DB1-B8E0-EA9D7E358840> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
             0x124c18000 -        0x124ccfff7  com.apple.AMDRadeonX3000GLDriver (1.40.16 - 1.4.0) <14C66039-6C8C-313B-A42C-8D23F8F0CC81> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLD river
             0x12b100000 -        0x12b319ff7  ATIRadeonX3000SCLib.dylib (1.40.16) <C68F8661-E00B-34C5-98E5-3AF8535482A5> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCL ib.dylib
             0x12d000000 -        0x12dfbbfdf +com.macromedia.Flash Player.authplaylib (19.0.0.185 - 19.0.0.185) <74B0E3C5-DAA7-31B5-B2BF-50EC2A9164D2> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
             0x159cef000 -        0x159cf4fff +libzip.dylib (1) <AF34BE5E-6133-3183-8906-087C406A1E63> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/jre/jre1.8.0_40.jre/Contents/Home/lib/libzip.dylib
             0x15c7e8000 -        0x15c7f2fff  JavaNativeFoundation (1) <D233D055-6EA4-3C7F-9C20-6E5D8FAAB75B> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
             0x1620e8000 -        0x1620edfff  com.apple.JavaVM (15.0.1 - 15.0.1) <49CA4C5A-C83E-3C46-B638-BDD8C05F6994> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
             0x1627f4000 -        0x1627f9fff  JavaLaunching (1) <013EAF8D-2ECB-3B0B-BAE7-87F4F1331516> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
             0x1673e5000 -        0x1673efff7  com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <85838C9F-E263-3DDD-85BA-8DA2C50911D5> /System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/JavaR untimeSupport
             0x16db25000 -        0x16e309fff +libjvm.dylib (1) <52DFD232-AEE6-3DF6-B562-2CAD9DA3A22C> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/jre/jre1.8.0_40.jre/Contents/Home/lib/server/libjvm.dylib
             0x16eaa3000 -        0x16eac7fef +libjava.dylib (1) <62CBD9B0-6D48-33AE-9715-1718156B4155> /Applications/Adobe Animate CC 2015/Adobe Animate CC 2015.app/Contents/jre/jre1.8.0_40.jre/Contents/Home/lib/libjava.dylib
          0x7fff69d3e000 -     0x7fff69d75007  dyld (360.19) <9D05FDF4-65CE-3B53-86D4-ABE1A5BF35F3> /usr/lib/dyld
          0x7fff85c9b000 -     0x7fff85cb4fef  libcompression.dylib (25) <C8546222-B022-39EA-9896-0387BA1D5C51> /usr/lib/libcompression.dylib
          0x7fff85cb5000 -     0x7fff85cb6ff3  com.apple.print.framework.Print (10.0 - 266) <BF573614-5666-3D16-9D45-4690911F030A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff85cb7000 -     0x7fff85cbdfff  com.apple.IOAccelerator (205.1 - 205.1) <9B56A248-FA12-3DB9-AD97-51EB4700E8A8> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fff85cbe000 -     0x7fff85cc2fff  libcache.dylib (75) <6B245C0A-F3EA-383B-A542-5B0D0456A41B> /usr/lib/system/libcache.dylib
          0x7fff85d0d000 -     0x7fff85d23ff7  libsystem_coretls.dylib (83.20.8) <75C97D88-0A63-3093-AE83-DE33EB7405CE> /usr/lib/system/libsystem_coretls.dylib
          0x7fff85d34000 -     0x7fff85d5fff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <D4463131-B469-30B1-84C4-50DB1BAADC32> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
          0x7fff85d60000 -     0x7fff86006ff7  com.apple.CoreData (120 - 641.3) <65509AA2-A0E6-3EE3-BDFE-B9B120F744ED> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff860ae000 -     0x7fff860b9fff  com.apple.CommerceCore (1.0 - 459) <4179210D-00E6-397D-AAA3-2A1E9992CB2D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x7fff860cd000 -     0x7fff860d5fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <D44F75E7-C679-3C21-AD76-8FA8A2B898F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
          0x7fff86143000 -     0x7fff86176ff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
          0x7fff86177000 -     0x7fff86179fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
          0x7fff8617e000 -     0x7fff86193fff  com.apple.ToneKit (1.0 - 1) <298E6855-B818-3949-85ED-08CF12ACEE59> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
          0x7fff86257000 -     0x7fff86295ff7  libGLImage.dylib (12.0.40.6) <ACC6C7B0-A805-344C-AAC3-BA50780227E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff86296000 -     0x7fff862e7ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <BB7C0F61-E39B-382C-AF03-1650C054BFE1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff866a6000 -     0x7fff86756fff  com.apple.backup.framework (1.7.2 - 1.7.2) <F6A2F892-0728-3DD6-883C-2CDE789BF26F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fff8675b000 -     0x7fff86771fff  com.apple.CoreMediaAuthoring (2.2 - 953) <D74307B6-EC7E-3E5F-B2CF-7CE7A183F0F0> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff867a9000 -     0x7fff867befff  com.apple.AppContainer (4.0 - 261.20.7) <30414623-E68F-31A1-9794-1C052391E900> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fff867bf000 -     0x7fff867d5ff7  libLinearAlgebra.dylib (1159) <FA316609-9851-3C5C-AF46-685A25768D45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
          0x7fff867d6000 -     0x7fff867e1fff  com.apple.AppSandbox (4.0 - 261.20.7) <0CA08EB7-D574-3E2F-A3AE-FEA80FF3F304> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fff867e2000 -     0x7fff86988ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <F912765D-88ED-3324-B512-3778A8CE878B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff869fa000 -     0x7fff869fcff7  com.apple.xpc.ServiceManagement (1.0 - 1) <3777FD15-B6F3-32A2-A8E3-3E8CE3B8D5E7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fff869fd000 -     0x7fff86a08fff  libcsfde.dylib (517.20.1) <42376761-F1B3-3086-AFBC-231507582BBE> /usr/lib/libcsfde.dylib
          0x7fff86a09000 -     0x7fff86ec7fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff86ec8000 -     0x7fff8741ffff  com.apple.MediaToolbox (1.0 - 1731.15.33) <16374746-DF5E-3103-994B-74CF151BD06A> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff87428000 -     0x7fff87633fff  libFosl_dynamic.dylib (16.24) <363B7CEE-B662-32F3-9D7B-245E64927C35> /usr/lib/libFosl_dynamic.dylib
          0x7fff8763a000 -     0x7fff87642fff  libGFXShared.dylib (12.0.40.6) <7E84C8A9-40DA-302A-A3DE-9AE3C61A3465> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff87779000 -     0x7fff8778dfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <8D8A190B-3C08-3624-8DC6-E9EBE22BC3BB> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
          0x7fff87799000 -     0x7fff877a9fff  libSparseBLAS.dylib (1159) <81330B45-9CA3-34AC-891C-6E770C3DFC24> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
          0x7fff877aa000 -     0x7fff877afff7  libheimdal-asn1.dylib (453.20.2) <EE3DD8E9-E543-3849-ADC9-EDBF2379C97C> /usr/lib/libheimdal-asn1.dylib
          0x7fff877b0000 -     0x7fff8797effb  com.apple.QuartzCore (1.11 - 410.14) <CB19502B-D25F-379C-B50F-08A98FF73B68> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff879f4000 -     0x7fff87a42fff  libcurl.4.dylib (90) <FF42FAA6-E71B-3D0D-B5C9-B05BD2460C9A> /usr/lib/libcurl.4.dylib
          0x7fff87bb2000 -     0x7fff87bd1ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
          0x7fff87bd2000 -     0x7fff87bd3fff  libsystem_blocks.dylib (65) <49D42329-7DE9-3413-92C3-A473A7E9CF35> /usr/lib/system/libsystem_blocks.dylib
          0x7fff87bd4000 -     0x7fff87bd4fff  com.apple.Cocoa (6.11 - 22) <0A634D46-B468-3CBC-B2A0-16C381C11BF2> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff87bd5000 -     0x7fff87bf7ff7  com.apple.framework.familycontrols (4.1 - 410) <50F14127-3FCC-39A2-9158-5C2581B0FAE3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff87bf8000 -     0x7fff87bfafff  com.apple.SecCodeWrapper (4.0 - 261.20.7) <E3E10533-B295-39EB-B0A3-42BD238E8C85> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fff87c17000 -     0x7fff87c1cff7  libmacho.dylib (875.1) <CB745E1F-4885-3F96-B38B-2093DF488FD5> /usr/lib/system/libmacho.dylib
          0x7fff87c1d000 -     0x7fff8813ffff  com.apple.QuartzComposer (5.1 - 334) <0A407B05-5CF5-3084-93EF-F4619BDEEF8B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff88146000 -     0x7fff88147ffb  libSystem.B.dylib (1226.10.1) <5A4257EF-3145-3BB3-87A4-0D2404A9462D> /usr/lib/libSystem.B.dylib
          0x7fff8814b000 -     0x7fff8817affb  com.apple.datadetectors (5.0 - 308) <F6564D99-03ED-3F4F-8922-E6D9508DA6F4> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
          0x7fff8837b000 -     0x7fff88411fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8BB8DF19-C24F-39F8-8B90-AD186D74587C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff88414000 -     0x7fff8844eff7  com.apple.DebugSymbols (132 - 132) <BDF57386-2881-35BD-9310-36904C764E93> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff8844f000 -     0x7fff88451ff7  com.apple.SafariServices.framework (11601 - 11601.4.4) <FB9EA83E-574E-31D4-AA47-B4EA086BF886> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
          0x7fff88479000 -     0x7fff88620ffb  com.apple.avfoundation (2.0 - 1046.9.2) <FE83988E-9A6D-3386-ACD7-A0A4D7A006DF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff88621000 -     0x7fff88623fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <B461272B-2DFF-3CA9-8DCA-689B2AAC0379> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
          0x7fff88624000 -     0x7fff886cbfff  com.apple.LanguageModeling (1.0 - 1) <E1E4091D-6CAB-36E0-A206-AAADE69791DC> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
          0x7fff886cc000 -     0x7fff886ccfff  com.apple.Accelerate (1.10 - Accelerate 1.10) <97B71D88-9C93-3943-B09E-642183B4E1AC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff886e3000 -     0x7fff88ae5fff  libLAPACK.dylib (1159) <A333AA38-9C2C-329C-AB92-94774C8264C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff88c4d000 -     0x7fff88c4dfff  libenergytrace.dylib (10) <A4AE7CBD-CF0A-3A74-8098-B642CE496611> /usr/lib/libenergytrace.dylib
          0x7fff88c4e000 -     0x7fff88dccfff  com.apple.UIFoundation (1.0 - 436.1) <8C254BB0-1DED-36A2-AAAF-786EB19CCE39> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
          0x7fff890e8000 -     0x7fff89116ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <7D0D2C65-C4C4-3FBD-89A7-12302EA444AA> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff8911c000 -     0x7fff8914bff7  com.apple.securityinterface (10.0 - 55065.20.1) <EDBD990A-0960-3DBB-BB42-43A36F49477F> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff8914c000 -     0x7fff89296fc7  com.apple.coreui (2.1 - 365.2) <727C55D3-503A-3EC4-8A23-C984E320F65F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff89ae4000 -     0x7fff89bc4ff7  unorm8_rgba.dylib (2.6.4.1) <6970FC46-0D13-3614-929D-9504AB54C740> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
          0x7fff89bc5000 -     0x7fff89bd0fff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fff89bd7000 -     0x7fff89bf3ff7  libextension.dylib (78) <589FA312-F17C-3A8D-986F-FD995D0065D5> /usr/lib/libextension.dylib
          0x7fff89bf4000 -     0x7fff89c0efff  com.apple.Kerberos (3.0 - 1) <836358DE-2731-3ACD-98E3-E5FA48917728> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff89c2b000 -     0x7fff89c37ff7  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <8B6C0DB6-8744-3AEB-BD00-9FA6967E7125> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
          0x7fff89e71000 -     0x7fff89e74ff7  libsystem_sandbox.dylib (460.30.1) <3E0036AF-FC64-3352-8DA4-6B550C2C2562> /usr/lib/system/libsystem_sandbox.dylib
          0x7fff89e75000 -     0x7fff89e78fff  libspindump.dylib (197.1) <61EB1BFE-8600-3420-B18E-1541D3C15C5C> /usr/lib/libspindump.dylib
          0x7fff89e8a000 -     0x7fff89eb8ff7  com.apple.DictionaryServices (1.2 - 250) <D9AB6B92-CAF5-3EC2-8D07-639B42DA1CB9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff89eb9000 -     0x7fff89f0eff7  com.apple.AE (701 - 701) <FB22BE84-9CB8-36BF-8061-F93D716C0A84> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff89f0f000 -     0x7fff89f14fff  com.apple.AssetCacheServices (14 - 14) <33685005-A92A-3006-97F5-FBF8530925B2> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
          0x7fff8a222000 -     0x7fff8a282fff  com.apple.QuickLookFramework (5.0 - 696.3) <D20C8962-7BB8-3A2C-BB80-5B61259B50F2> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff8a289000 -     0x7fff8a28afff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff8a28b000 -     0x7fff8a33dfff  com.apple.cloudkit.CloudKit (481.8 - 481.8) <E927AE82-8E55-38A4-BE6E-4D0829272653> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
          0x7fff8a33e000 -     0x7fff8a389ff7  com.apple.CoreMediaIO (703.0 - 4791) <A401D0BE-7618-3A75-A77D-2387CF168072> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff8a3f5000 -     0x7fff8a444ff7  com.apple.opencl (2.6.9 - 2.6.9) <27643341-DC6F-3C2F-8B8B-637061979BF3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff8a445000 -     0x7fff8a4a2fff  com.apple.CoreServices.OSServices (728.6 - 728.6) <CA616ACB-A872-386C-B16D-193A7E495C4D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff8a4a3000 -     0x7fff8a501fff  com.apple.SystemConfiguration (1.14 - 1.14) <5A70115B-E346-3EBD-A617-9A11C61EEF2E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff8a502000 -     0x7fff8a7e7ff3  com.apple.CoreServices.CarbonCore (1136 - 1136) <FFBDE3BF-0BB3-37A2-8A44-6E25284CC348> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff8a807000 -     0x7fff8a816ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <0D1BCC13-76B9-3C19-85AA-D8DD8299F007> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff8a857000 -     0x7fff8a858ffb  libremovefile.dylib (41) <B8D1A5FC-CFD5-3AAB-8A10-14DDC129710A> /usr/lib/system/libremovefile.dylib
          0x7fff8a859000 -     0x7fff8a886fff  libdispatch.dylib (501.20.1) <324C9189-2AF3-3356-847F-6F4CE1C6E901> /usr/lib/system/libdispatch.dylib
          0x7fff8a887000 -     0x7fff8a887fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <D2E8EA94-3828-3D7C-87E2-97E4CD00269D> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8a8bd000 -     0x7fff8a9a8ff7  com.apple.QuickLookUIFramework (5.0 - 696.3) <8416C721-85D3-3F4A-9916-2CB4640BB0CB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff8a9a9000 -     0x7fff8a9acff7  libCoreFSCache.dylib (119.5) <C7008E64-0AFB-3446-929E-BC3F76DEF049> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
          0x7fff8a9ad000 -     0x7fff8aad9ff7  com.apple.CoreText (352.0 - 494.10) <9FD834B1-FF8E-3EB0-BB11-6E9120969086> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fff8ab6d000 -     0x7fff8ab89ff7  libsystem_malloc.dylib (67) <9EECAB18-F025-34C4-8E32-7EFFA6720EFC> /usr/lib/system/libsystem_malloc.dylib
          0x7fff8ab9b000 -     0x7fff8aba9fff  com.apple.opengl (12.0.40 - 12.0.40) <D37D88AE-0731-3105-99AB-984DA9B9BCE6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff8abab000 -     0x7fff8abc4fff  com.apple.CFOpenDirectory (10.11 - 194) <C21F33AA-CD06-3163-A1F3-1D116F788A11> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff8ac59000 -     0x7fff8ac62ff7  libsystem_pthread.dylib (138.10.4) <327CECD0-B881-3153-8FCC-4FD4818B7F16> /usr/lib/system/libsystem_pthread.dylib
          0x7fff8ada6000 -     0x7fff8add0ff7  GLRendererFloat (12.0.40.6) <E739EE06-2F9C-3D46-AC6D-122DCD66E8C9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
          0x7fff8ae36000 -     0x7fff8b12bfff  com.apple.HIToolbox (2.1.1 - 807.2) <D9338BEF-CA84-3085-B6CB-4E93B3B9A2E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff8b22e000 -     0x7fff8b29dfff  com.apple.datadetectorscore (7.0 - 460) <CDBB7D7D-B189-37B0-AA4B-DC79090D0D71> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff8b34b000 -     0x7fff8bf6eff7  com.apple.AppKit (6.9 - 1404.34) <467468E2-C551-3408-B351-414B21F57DEB> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff8bf6f000 -     0x7fff8c347fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <B43C7811-38A4-3F9A-9417-FD8F4B55EA82> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff8c348000 -     0x7fff8c39afff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <04AB634C-FB23-3538-937C-FF60E5E59DF8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff8c39b000 -     0x7fff8c39dff7  com.apple.securityhi (9.0 - 55006) <B97C1C77-AA51-33ED-941D-F766BC94CD9E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff8c53c000 -     0x7fff8c544fff  com.apple.NetFS (6.0 - 4.0) <BDD59EC5-D399-31EA-9B2A-60E3A859FC42> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff8c573000 -     0x7fff8c57cff7  com.apple.CommonAuth (4.0 - 2.0) <B2CEE6B5-9464-35F2-9339-9F52001C8A27> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff8c57d000 -     0x7fff8c73dfeb  libBLAS.dylib (1159) <943445A4-F6CA-3923-882C-154D7D4AEFE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff8c78f000 -     0x7fff8c794fff  com.apple.ImageCapture (9.0 - 9.0) <33F7822F-1124-3D73-AF66-515EA32A4A47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff8c795000 -     0x7fff8c7c9ff7  com.apple.CoreVideo (1.8 - 191.2) <88D903C8-E608-320E-8ACD-11E5B3003C18> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff8c7ca000 -     0x7fff8c816ff3  com.apple.HIServices (1.22 - 549) <14FB5BB6-8456-39F9-A694-8A1C12426880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff8c817000 -     0x7fff8c819fff  libCGXType.A.dylib (948) <C3D473CF-7261-3E0D-A161-E9B642B75D6A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff8d2cb000 -     0x7fff8d354ff7  com.apple.PerformanceAnalysis (1.0 - 1) <FB33FACE-5A99-34E0-83CC-CEDCCFAC74C3> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fff8d424000 -     0x7fff8d42cfe7  libsystem_platform.dylib (74.10.3) <D3A27E10-7F08-3603-ACC8-7A92B2C04BAB> /usr/lib/system/libsystem_platform.dylib
          0x7fff8d4b4000 -     0x7fff8d4bcff7  libcldcpuengine.dylib (2.6.4.1) <5FFEDBEF-2EFE-3F91-BABC-1E73B28487A2> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fff8d4c6000 -     0x7fff8d4c7ff7  libodfde.dylib (23) <5475AB3E-8C9A-3279-8294-E565293F7EF1> /usr/lib/libodfde.dylib
          0x7fff8d4cf000 -     0x7fff8d8fdfff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <B8482831-77BD-3FBC-A0B1-12502353AA57> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fff8d8fe000 -     0x7fff8d9d4ff7  com.apple.DiskImagesFramework (10.11.3 - 417.2) <25BBE20C-E92B-360F-A326-093B61CC7B5E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
          0x7fff8db4c000 -     0x7fff8dbecfff  com.apple.ViewBridge (159 - 159) <A42BD1E4-C838-3135-B00E-8B051E42D5D3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fff8dbed000 -     0x7fff8dbeefff  libsystem_secinit.dylib (20) <FD6ECF2C-1489-32CA-981B-9045B5EB1FAA> /usr/lib/system/libsystem_secinit.dylib
          0x7fff8de82000 -     0x7fff8de8afff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
          0x7fff8debe000 -     0x7fff8decffff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
          0x7fff8ded7000 -     0x7fff8ded7ff7  libunc.dylib (29) <1D0F8265-F026-3CBD-93D3-F8DF14FFCE68> /usr/lib/system/libunc.dylib
          0x7fff8ded8000 -     0x7fff8df1eff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
          0x7fff8df7a000 -     0x7fff8df7dfff  com.apple.IOSurface (108.0.1 - 108.0.1) <7B05B27A-5CC4-30D4-8A10-ED444A2807A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff8dfca000 -     0x7fff8dfe5ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
          0x7fff8e006000 -     0x7fff8e016ff3  com.apple.ProtocolBuffer (1 - 242) <127AF54F-615B-362A-A221-3E758C46A235> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
          0x7fff8e02c000 -     0x7fff8e02efff  libCVMSPluginSupport.dylib (12.0.40.6) <C88875DF-9888-37A6-AE69-3CABFACDAF45> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff8e04e000 -     0x7fff8e08fff7  libGLU.dylib (12.0.40.6) <1C9899B5-4741-340F-A2D7-F9AF03B42A47> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff8e121000 -     0x7fff8e121fff  com.apple.CoreServices (728.6 - 728.6) <1FC9300C-6D3D-330C-829C-C8F094BC38C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff8e122000 -     0x7fff8e196fff  com.apple.Heimdal (4.0 - 2.0) <009F223D-B89B-376B-94F5-6D982CBEF771> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff8e197000 -     0x7fff8e19bfff  libGIF.dylib (1442) <2F7DA684-3510-38C2-B48F-9D33194860A1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fff8e231000 -     0x7fff8f2f0ff7  com.apple.WebCore (11601 - 11601.4.4) <815CFF7F-3839-3FDE-9B82-79253BFB3624> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x7fff8f35b000 -     0x7fff8f38bff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <C34F0ECF-AABA-3FBC-980F-B4809C9B2DD1> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fff8f38c000 -     0x7fff8f3b0fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <58FAFE0C-A2D8-3746-AC8F-BF553A7CDED7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff8f5be000 -     0x7fff8f5c6ffb  libsystem_dnssd.dylib (625.20.4) <945B5FB1-DA91-3D45-A961-A8FAD53C1E7E> /usr/lib/system/libsystem_dnssd.dylib
          0x7fff8f626000 -     0x7fff8f681ff7  libTIFF.dylib (1442) <FC2ADE78-3710-31E7-9CE7-44CD61F4B8DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fff8f682000 -     0x7fff8f683fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fff8f684000 -     0x7fff8f68cfff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
          0x7fff8f68d000 -     0x7fff8f68fff7  libquarantine.dylib (80) <163CF63A-7455-3D1F-AE57-8C4475A9204C> /usr/lib/system/libquarantine.dylib
          0x7fff8f7f0000 -     0x7fff8f85aff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <6A535459-6A8A-3D60-986B-EE7ED833A9C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fff8f85b000 -     0x7fff8f86dfff  libsasl2.2.dylib (209) <02BF4226-23E9-34EC-A727-CF0E205395F8> /usr/lib/libsasl2.2.dylib
          0x7fff8f86e000 -     0x7fff8fce4fff  com.apple.CoreFoundation (6.9 - 1256.14) <768A7FB7-9143-3148-8591-7C6ED3162D35> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff8fce5000 -     0x7fff8fd72fff  libsystem_c.dylib (1082.20.4) <EAB38A6C-8671-3B13-B500-90EC1B912063> /usr/lib/system/libsystem_c.dylib
          0x7fff8fd73000 -     0x7fff8fd79fff  com.apple.XPCService (2.0 - 1) <9A305622-14E1-3D9A-BE47-6524419BA58D> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fff8fd7a000 -     0x7fff8fdf0ff7  com.apple.MMCS (1.3 - 351) <13D01D37-66F0-30BB-AA7E-D1D348F738E3> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
          0x7fff8fdf1000 -     0x7fff8fe1afff  libsystem_info.dylib (477.20.1) <6513635B-4ADE-3B45-BF63-ED7AC565B0C9> /usr/lib/system/libsystem_info.dylib
          0x7fff8fe2a000 -     0x7fff8fe33ff3  libsystem_notify.dylib (150.20.3) <243FADE1-255A-3B78-8033-F336CD64B817> /usr/lib/system/libsystem_notify.dylib
          0x7fff906c5000 -     0x7fff906c7fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
          0x7fff906cb000 -     0x7fff9075afff  com.apple.CorePDF (4.0 - 4) <6147B89F-46D8-38B2-A7D0-C5AABCE35BC6> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff9077d000 -     0x7fff90a13fff  libmecabra.dylib (696.4) <0A1574F0-3222-3856-A1C6-D8BE20DC4C48> /usr/lib/libmecabra.dylib
          0x7fff90a18000 -     0x7fff90a1aff7  libRadiance.dylib (1442) <9E9084DC-C0DF-30DF-BD6B-7AED3799A129> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fff90a1b000 -     0x7fff90a6eff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
          0x7fff90afe000 -     0x7fff90b09fff  libGPUSupportMercury.dylib (12.0.40.6) <6061FB76-565E-3E11-B659-50827DFB0BDE> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fff90b0a000 -     0x7fff90b12fff  com.apple.AppleSRP (5.0 - 1) <25775E90-1DBB-3BFA-B4B4-F8F262B9EC1F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
          0x7fff90b23000 -     0x7fff90f94ff3  com.apple.GeoServices (1.0 - 1151.2.13.9) <52A8FBB6-267C-3371-A516-264572B5800F> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
          0x7fff90f95000 -     0x7fff90fc1fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <FDCA9F2D-E06A-3DEC-8E1A-7535BAE68B62> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
          0x7fff90fc2000 -     0x7fff91025fff  libAVFAudio.dylib (161.2) <C42EF0ED-56B2-387F-B188-C42FB8A1B7AB> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
          0x7fff91026000 -     0x7fff910ddff7  com.apple.CoreDuet (1.0 - 1) <20BDA287-415A-385E-BCB5-934D165BDAA4> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
          0x7fff912a5000 -     0x7fff9194bffb  com.apple.JavaScriptCore (11601 - 11601.4.2) <33235884-914C-3A2B-AD91-142E5AB8899F> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff9194c000 -     0x7fff9194fffb  libScreenReader.dylib (425.102) <BDC46586-4925-38F2-85D3-BD23DB6E6D43> /usr/lib/libScreenReader.dylib
          0x7fff91c04000 -     0x7fff91c72ff7  com.apple.ApplicationServices.ATS (377 - 394.3) <0DDD3503-3D74-3CCA-BD25-7F19B03C2579> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff91c85000 -     0x7fff91cfcfe7  libcorecrypto.dylib (335.20.1) <C6BD205F-4ECE-37EE-BCAB-A76F39CDCFFA> /usr/lib/system/libcorecrypto.dylib
          0x7fff91cfd000 -     0x7fff91d08fff  libkxld.dylib (3248.30.4) <BAA3DDEC-AD81-3C29-AECC-59E4AD114D3C> /usr/lib/system/libkxld.dylib
          0x7fff921e5000 -     0x7fff921e5fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff921e6000 -     0x7fff92476ff7  com.apple.RawCamera.bundle (6.18 - 828) <CB7F6CCD-3753-3147-816A-B613F500AE33> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff92477000 -     0x7fff9259cff7  com.apple.LaunchServices (728.6 - 728.6) <204CD7A1-D99C-3655-82D7-E8E89F9C666B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff9259d000 -     0x7fff925e2ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <72156BE7-0804-3F90-9AF9-14C4739430C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
          0x7fff925e6000 -     0x7fff925f9fff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
          0x7fff92671000 -     0x7fff938dcffb  com.apple.CoreGraphics (1.600.0 - 948) <A5BCCC6D-D931-360D-BF45-02F5ED4E1773> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fff938dd000 -     0x7fff938e6fff  com.apple.icloud.FindMyDevice (1.0 - 1) <BB049D2D-9789-39E8-A09D-D300E7AA94D2> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
          0x7fff9390f000 -     0x7fff939fefff  libxml2.2.dylib (29.2) <F70308DF-313F-334F-8F0E-82E79821583D> /usr/lib/libxml2.2.dylib
          0x7fff939ff000 -     0x7fff93a31fff  libTrueTypeScaler.dylib (158.4) <4AEF2CB9-407D-3FEB-B0BD-4DB162EB9519> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff93a32000 -     0x7fff93abafff  com.apple.CoreSymbolication (3.1 - 58048.1) <6436E5E0-B05C-36D6-942A-47026DD2D874> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff93b5c000 -     0x7fff93d69ff7  com.apple.CoreImage (11.2.0 - 366.2.7) <344F1067-5F52-3626-8F6C-2B678DEB80A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
          0x7fff93d6d000 -     0x7fff93dafff7  com.apple.Metal (55.2.8 - 55.2.8) <D4D7AC6F-7B31-3D94-B4B1-587EC2856CDB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
          0x7fff93db0000 -     0x7fff93de1fff  com.apple.GSS (4.0 - 2.0) <25DECD44-0905-3E53-9480-DE7BEB84DB83> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff93de2000 -     0x7fff93f6eff7  libGLProgrammability.dylib (12.0.40.6) <60C68BA6-D375-39D5-9ADD-B394FB760A86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff93fd2000 -     0x7fff93fefff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <2B459E1F-0563-30B2-A04D-CF1793426B66> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
          0x7fff94073000 -     0x7fff9407cff7  com.apple.DisplayServicesFW (3.0 - 378) <E459962E-90C6-36CE-BA30-BC9E29E6C14A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff9407d000 -     0x7fff94094ff7  libsystem_asl.dylib (322.30.1) <9B500E4E-E462-321E-828E-5524DC984C1B> /usr/lib/system/libsystem_asl.dylib
          0x7fff9410b000 -     0x7fff941a0fff  com.apple.ink.framework (10.9 - 214) <6B573126-A6E9-357F-B36A-AA5BDC0BEAF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff941a1000 -     0x7fff944deff3  com.apple.WebKit (11601 - 11601.4.4) <F35B60CF-8F10-3FC3-9E01-F7C887070EA2> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x7fff944df000 -     0x7fff944e1ff7  libsystem_configuration.dylib (802.20.7) <5FD79070-36CC-3D02-BEA7-BB5D2AE97D5D> /usr/lib/system/libsystem_configuration.dylib
          0x7fff944e2000 -     0x7fff944e7fff  com.apple.TCC (1.0 - 1) <C53628CA-0C75-34B6-AE6E-8BCF8A3ED099> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fff9453f000 -     0x7fff94550ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
          0x7fff945d6000 -     0x7fff945d6fff  com.apple.ApplicationServices (48 - 48) <DD9C4070-C0FC-3984-BCED-72E6E99838FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff94639000 -     0x7fff94673fff  com.apple.QD (3.12 - 302) <3F36A108-C557-353A-A3F7-80DDCB82BB37> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff9490f000 -     0x7fff94914fff  com.apple.MediaAccessibility (1.0 - 79) <CCF71DC1-BB6A-3227-BD1B-AFD172592A63> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fff94915000 -     0x7fff94989ff3  com.apple.securityfoundation (6.0 - 55126) <11644DA4-F1CF-3FB1-86A0-0DA8E8C27148> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff9498a000 -     0x7fff94996ff7  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <E507D438-517D-32AE-8609-02ACD2F0D692> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff94997000 -     0x7fff9499afff  com.apple.Mangrove (1.0 - 1) <7919AD18-0EDE-3408-A6AC-A9121B8D857F> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fff9499b000 -     0x7fff949a6fff  com.apple.DirectoryService.Framework (10.11 - 194) <159606E0-F3AF-36B0-9744-4BFE1DA3EC74> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff949a7000 -     0x7fff949aaffb  libdyld.dylib (360.19) <AA629043-C6F6-32FE-8007-E3478E99ACA7> /usr/lib/system/libdyld.dylib
          0x7fff94bc0000 -     0x7fff94bcbfff  libGL.dylib (12.0.40.6) <2A13E40A-BFA1-34FD-925A-C7023FEF254C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff94d18000 -     0x7fff94d26ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
          0x7fff94d89000 -     0x7fff94f34ffb  GLEngine (12.0.40.6) <D55FDA69-AE2C-3AA1-9565-309C13C1C5C2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
          0x7fff94f35000 -     0x7fff94f56fff  com.apple.Sharing (442.9.1 - 442.9.1) <672DE6DF-98E0-30A4-BA25-44BDE188D0BE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fff94fcb000 -     0x7fff94fcbfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <E0D5C411-052F-3B71-9562-C1098FB2F86D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff95000000 -     0x7fff95011ff7  libsystem_trace.dylib (201.10.3) <B485369F-E3A1-319E-998C-89AAF606079E> /usr/lib/system/libsystem_trace.dylib
          0x7fff96074000 -     0x7fff9609dff7  libxslt.1.dylib (14.1) <AE86E275-499F-3D4F-8433-142186D383CB> /usr/lib/libxslt.1.dylib
          0x7fff9609e000 -     0x7fff960bcfff  libsystem_kernel.dylib (3248.30.4) <9CEB6C3B-1CAF-3C32-A9FD-93BC72CBCEA1> /usr/lib/system/libsystem_kernel.dylib
          0x7fff960bd000 -     0x7fff96202fff  com.apple.QTKit (7.7.3 - 2943) <6DD72D38-9449-3289-904E-B6E148993AA5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff971bd000 -     0x7fff971f5fff  com.apple.RemoteViewServices (2.0 - 99) <596153FD-3CB9-3FED-9D63-1B73B01AC6DB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fff971f6000 -     0x7fff9720ffff  com.apple.openscripting (1.7.1 - 169.1) <F6532253-9EC5-3FF3-AA16-8AE58531B1D1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff973a1000 -     0x7fff973bdfff  com.apple.GenerationalStorage (2.0 - 239) <EE667C63-3ADF-34D3-A8A7-316B66C7E290> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff973be000 -     0x7fff974baff7  libFontParser.dylib (158.4) <BF7F82EB-7820-364A-865E-442F42BFDFA4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff974bb000 -     0x7fff97548dd7  com.apple.AppleJPEG (1.0 - 1) <9F0E8564-FCC4-33BE-9C6A-2BA926A33F6F> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
          0x7fff9754d000 -     0x7fff9759dff7  com.apple.Symbolication (1.4 - 58044) <2EC9F04A-4370-39C8-8549-FC6411D87463> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fff9759e000 -     0x7fff978f2ff7  com.apple.Foundation (6.9 - 1256.1) <66106CC9-9D97-3846-88D8-4BF6BB508296> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff9795e000 -     0x7fff97962fff  com.apple.CommonPanels (1.2.6 - 96) <61E9D84F-435A-3C7B-A065-047B80775777> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff97963000 -     0x7fff97966ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <2B3F04CE-3C7D-3F51-99F3-C7847D1E4277> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff979a4000 -     0x7fff979abff7  libcompiler_rt.dylib (62) <D3C4AB40-23B4-3BC6-8C38-5B8758D14E80> /usr/lib/system/libcompiler_rt.dylib
          0x7fff979ac000 -     0x7fff979c7fff  com.apple.aps.framework (4.0 - 4.0) <894B1FD6-6EBE-302B-947B-D5813DABEDF0> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
          0x7fff97a05000 -     0x7fff97aa9fff  com.apple.Bluetooth (4.4.3 - 4.4.3f4) <B5F46DA5-EAE8-3F79-864D-1423C61C0A69> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
          0x7fff97aaa000 -     0x7fff97ad1fff  com.apple.shortcut (2.16 - 93) <D9DD2F6A-4AC7-38BD-A3B6-A9682EFCCE2E> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff97ad2000 -     0x7fff97afdffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
          0x7fff97b67000 -     0x7fff97bb3ff7  com.apple.corelocation (1486.17 - 1615.38) <5AE891F7-ED25-3C6C-A8DD-5D702FB87DC7> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
          0x7fff97bb4000 -     0x7fff97bb4ff7  liblaunch.dylib (756.20.4) <EDF719D6-D2BB-38DD-8C94-4272BEFDA2CD> /usr/lib/system/liblaunch.dylib
          0x7fff97bb5000 -     0x7fff97c01fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <449D8AB5-7891-32D0-9DC5-C90FE10DC0BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff97c02000 -     0x7fff97c0eff7  com.apple.OpenDirectory (10.11 - 194) <5409AC27-3B83-3F35-8EB5-51228B4604AE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff97cc6000 -     0x7fff97ce2ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
          0x7fff97ce3000 -     0x7fff97df5fef  libvDSP.dylib (563.4) <C069B6A3-D7CD-3B72-918C-15514066A2F3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff97df6000 -     0x7fff97e1fffb  libRIP.A.dylib (948) <96E8F983-A8BA-3B0F-9035-E09642A63F6E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff97ebb000 -     0x7fff97ec9fff  com.apple.ToneLibrary (1.0 - 1) <E92CE7C6-43CB-3312-9B1F-77353FE2C5DD> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
          0x7fff97eca000 -     0x7fff97ecaff7  libkeymgr.dylib (28) <09397E01-6066-3179-A50C-2CE666FDA929> /usr/lib/system/libkeymgr.dylib
          0x7fff97ecb000 -     0x7fff97f1bfff  libcups.2.dylib (435) <28A05475-9DBF-35EA-B218-3432B69EA18B> /usr/lib/libcups.2.dylib
          0x7fff97f2c000 -     0x7fff97fe5ff7  libvMisc.dylib (563.4) <3114F9E9-2B0D-3371-93A1-04BB55CE8DBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff97fe6000 -     0x7fff97ff9fff  com.apple.CoreBluetooth (1.0 - 1) <BF5F87E3-6AAA-3B1F-9979-7A03D77937C8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
          0x7fff98091000 -     0x7fff980b5fff  com.apple.MultitouchSupport.framework (304.10 - 304.10) <1E0206D9-34AD-3810-8ED0-29DC450D1485> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff980b6000 -     0x7fff980fbff3  libFontRegistry.dylib (155.1) <593CC743-3785-3CC5-A229-D3846C51E054> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff98104000 -     0x7fff9846f657  libobjc.A.dylib (680) <58CB8CFC-7DBD-3A53-BD72-A42FF799B21E> /usr/lib/libobjc.A.dylib
          0x7fff985db000 -     0x7fff985dffff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
          0x7fff985e0000 -     0x7fff986fdfff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
          0x7fff98dcd000 -     0x7fff99148ffb  com.apple.VideoToolbox (1.0 - 1731.15.33) <33AED54A-87AE-330F-BAAD-FB8389C3E686> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff99396000 -     0x7fff99603fff  com.apple.imageKit (2.6 - 932) <6738F065-3D55-3165-8D3E-33AA18D6E3EA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff99604000 -     0x7fff996a4ff7  com.apple.Metadata (10.7.0 - 972.16) <3E42A570-BE32-396D-96E1-01B4A778D991> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff997de000 -     0x7fff999a7ff7  com.apple.ImageIO.framework (3.3.0 - 1442) <2C8AF87E-080E-3FD8-824D-332B43DF4B61> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fff999cf000 -     0x7fff99ab6ff7  libcrypto.0.9.8.dylib (59) <ED1C2A26-8FFC-30FF-8726-FF952EF94ADF> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff99ab7000 -     0x7fff99b62fff  com.apple.PDFKit (3.1 - 3.1) <F6796D8B-3BE1-3D09-B6D4-15016CDE14D9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff99b75000 -     0x7fff99dc1ff7  com.apple.AddressBook.framework (9.0 - 1679.4) <B18B0933-04A3-3092-9B33-C9C91AF59E00> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
          0x7fff99eed000 -     0x7fff99ef0ff7  com.apple.help (1.3.3 - 46) <62056D9B-A87C-3E4D-B4E2-7E1CDB74CE68> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff9a344000 -     0x7fff9a42afef  unorm8_bgra.dylib (2.6.4.1) <F2A325FF-D55F-3091-88E2-5EBF3648274A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
          0x7fff9a42b000 -     0x7fff9a454fff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
          0x7fff9a455000 -     0x7fff9a48cff7  com.apple.LDAPFramework (2.4.28 - 194.5) <79D981F2-F70C-3E47-B124-DC0C90D45563> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff9a4b6000 -     0x7fff9a4bdff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
          0x7fff9a4be000 -     0x7fff9a744ff7  com.apple.CFNetwork (760.2.6 - 760.2.6) <653B1552-C1EC-36A5-85D0-9FC3ED3CCF72> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fff9a745000 -     0x7fff9a775ff7  libsandbox.1.dylib (460.30.1) <AD0156FC-EF07-3689-9403-586517AE7037> /usr/lib/libsandbox.1.dylib
          0x7fff9a779000 -     0x7fff9a7daff7  libsystem_network.dylib (583.20.10) <865FE79A-A22D-3733-A14F-FC7B37F3AECD> /usr/lib/system/libsystem_network.dylib
          0x7fff9a7db000 -     0x7fff9a7dbfff  libOpenScriptingUtil.dylib (169.1) <03BEF6F0-07CD-3EDC-9D11-32202C1857B6> /usr/lib/libOpenScriptingUtil.dylib
          0x7fff9a7ec000 -     0x7fff9a7f7ff7  libcommonCrypto.dylib (60075.20.1) <766BC3F5-41F3-3315-BABC-72718A98EA92> /usr/lib/system/libcommonCrypto.dylib
          0x7fff9a7f8000 -     0x7fff9a84afff  com.apple.CloudDocs (1.0 - 383.5) <BBE4C32D-75E6-3EDD-A787-625BDD66DA20> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
          0x7fff9a865000 -     0x7fff9a894ffb  libsystem_m.dylib (3105) <26655445-CA97-321E-B221-801CB378D1AA> /usr/lib/system/libsystem_m.dylib
          0x7fff9a895000 -     0x7fff9a897ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
          0x7fff9a8eb000 -     0x7fff9a8f3fff  libcopyfile.dylib (127) <F5133269-0B22-388C-A57C-079667B6291E> /usr/lib/system/libcopyfile.dylib
          0x7fff9a8f4000 -     0x7fff9a9e6ff7  libJP2.dylib (1442) <3B374049-CCA4-3B4D-9517-583F2BF6B77D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fff9aa3e000 -     0x7fff9aa43ff3  libunwind.dylib (35.3) <124E0F05-2350-3774-A32C-7F5BF38EDE73> /usr/lib/system/libunwind.dylib
          0x7fff9aa44000 -     0x7fff9aa4efff  com.apple.NetAuth (6.0 - 6.0) <19E44307-6F9F-3DEC-8C1A-4685BC252A35> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fff9aa4f000 -     0x7fff9abaaffb  com.apple.WebKitLegacy (11601 - 11601.4.4) <5CC2787B-FDD4-3025-BD63-4021F97787A8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
          0x7fff9ac6c000 -     0x7fff9ad5eff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
          0x7fff9ad62000 -     0x7fff9afe2ff3  com.apple.security (7.0 - 57337.20.44) <290E0078-464E-30EE-8288-8B29A875FFE3> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff9afe3000 -     0x7fff9afe3fff  com.apple.Carbon (154 - 157) <34263101-328D-3FE4-B212-14BD3CFF6965> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff9b040000 -     0x7fff9b0cfff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
          0x7fff9b0d0000 -     0x7fff9b0f5ff7  libPng.dylib (1442) <E8391CE4-9B83-3895-A406-D987FC826D4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fff9b30c000 -     0x7fff9b32efff  com.apple.IconServices (68.1 - 68.1) <3ECAA762-1193-3D76-A25F-7680DB3A957E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fff9b336000 -     0x7fff9b35dfff  com.apple.ProtectedCloudStorage (1.0 - 1) <F9E1BDE2-16AF-34B5-B7FE-127D511BDC9E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
          0x7fff9b3fc000 -     0x7fff9b40afff  com.apple.IntlPreferences (2.0 - 192) <CACF49DE-A307-3066-B168-B47DFC531B97> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
          0x7fff9b40b000 -     0x7fff9b416ff7  libChineseTokenizer.dylib (16) <998637AB-DC37-3A7C-A85C-F10FD98CAAD7> /usr/lib/libChineseTokenizer.dylib
          0x7fff9b4ef000 -     0x7fff9b5c8fff  com.apple.CoreMedia (1.0 - 1731.15.33) <6109D83B-4E0B-3DE2-9856-9FD80EA51CE0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff9b5c9000 -     0x7fff9b5d1fff  libsystem_networkextension.dylib (385.20.6) <DC8A102A-BF02-31A4-8914-65C34DF6B592> /usr/lib/system/libsystem_networkextension.dylib
          0x7fff9b5d2000 -     0x7fff9b7dfffb  libicucore.A.dylib (551.41) <CFFD7342-A7D6-323A-AC14-B9EECF6EFFED> /usr/lib/libicucore.A.dylib
          0x7fff9b815000 -     0x7fff9b839ff7  libJPEG.dylib (1442) <0F9069AB-D830-37DD-8813-B635D1ECB3E4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fff9b83a000 -     0x7fff9b8aefff  com.apple.framework.IOKit (2.0.2 - 1179.20.6) <D92E537D-F96D-39E1-B9AC-9A18943AFCC7> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff9b8af000 -     0x7fff9b8b2fff  libCoreVMClient.dylib (119.5) <CD7DE25C-D7AD-3ECD-BEEC-F57992A4A08E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff9b8b3000 -     0x7fff9b905fff  com.apple.ImageCaptureCore (7.0 - 7.0) <68537DDB-383F-3D4D-8125-789053333B13> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff9b906000 -     0x7fff9b975fff  com.apple.SearchKit (1.4.0 - 1.4.0) <CA50106F-F45A-36AC-AD2B-C3B19F5DD52F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff9b976000 -     0x7fff9b9a7ff7  libtidy.A.dylib (15.17) <03EF1071-8B43-3B41-9879-118FA27F89C5> /usr/lib/libtidy.A.dylib
          0x7fff9ba20000 -     0x7fff9ba21fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
          0x7fff9ba83000 -     0x7fff9ba89ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <FA5CB89A-2BFE-38CC-B1A3-E48792CD898C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff9bac3000 -     0x7fff9bad1fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
          0x7fff9bad2000 -     0x7fff9bae7ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
          0x7fff9bae8000 -     0x7fff9bb11fff  libxpc.dylib (756.20.4) <61AB4610-9304-354C-9E9B-D57198AE9866> /usr/lib/system/libxpc.dylib
          0x7fff9c139000 -     0x7fff9c187ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
          0x7fff9c18a000 -     0x7fff9c18afff  libmetal_timestamp.dylib (600.0.43.5) <4BA5B935-F932-3863-9B31-EF0A7DEAF15C> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
          0x7fff9c18b000 -     0x7fff9c18ffff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
          0x7fff9c190000 -     0x7fff9c29eff3  com.apple.desktopservices (1.10 - 1.10) <0BAED9FA-EFA5-3DA0-8715-043FD2400B77> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff9c2a8000 -     0x7fff9c2b4fff  com.apple.HelpData (2.1.4 - 90) <3A533F58-9C3B-3341-A8F8-084C96BDB70D> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff9c2b5000 -     0x7fff9c2d4ff7  com.apple.framework.Apple80211 (11.0 - 1110.33) <EC583C00-9073-39C3-B613-96D5BA0FDD32> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fff9c2d5000 -     0x7fff9c2dafff  com.apple.DiskArbitration (2.7 - 2.7) <B7FAE647-156A-30C8-BA8B-69D188D02602> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff9c2e0000 -     0x7fff9c2e2fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
          0x7fff9c2e3000 -     0x7fff9c30afff  com.apple.ChunkingLibrary (167 - 167) <508861C9-F5E6-343B-8DD0-D71DFE49ECFD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fff9c341000 -     0x7fff9c351fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
          0x7fff9c352000 -     0x7fff9c40cfff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <C4EC1EA7-E2AA-30F7-83CC-79171CDD50AA> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
          0x7fff9c42b000 -     0x7fff9c492fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <BEC7B27E-8CE8-3DAB-BFDF-6C240C6A4B12> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fff9c493000 -     0x7fff9c4adff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
          0x7fff9c4ae000 -     0x7fff9c4c5fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 40
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 142452
          thread_create: 0
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=550.6M resident=0K(0%) swapped_out_or_unallocated=550.6M(100%)
      Writable regions: Total=2.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.1G(100%)
                                      VIRTUAL   REGION
      REGION TYPE                        SIZE    COUNT (non-coalesced)
      ATS (font support)                32.0M        8
      ATS (font support) (reserved)        4K        2         reserved VM address space (unallocated)
      Accelerate.framework               256K        3
      Activity Tracing                  2048K        2
      CG backing stores                 13.9M       12
      CG image                           440K       14
      CG shared images                   592K       18
      CoreAnimation                      628K       26
      CoreUI image data                 1984K       25
      CoreUI image file                  192K        4
      Dispatch continuations            48.0M        2
      Foundation                          24K        3
      IOKit                             7940K        2
      Image IO                           308K       16
      Kernel Alloc Once                    8K        3
      MALLOC                             1.3G      218
      MALLOC guard page                   48K       11
      MALLOC_LARGE (reserved)           40.1M        2         reserved VM address space (unallocated)
      Memory Tag 240                    42.6M      102
      Memory Tag 242                      12K        2
      OpenCL                               8K        2
      OpenGL GLSL                        256K        4
      Process Corpse Info               2048K        2
      STACK GUARD                       56.3M       69
      Stack                             59.4M       73
      Stack Guard                        204K       18
      VM_ALLOCATE                        4.4G       58
      VM_ALLOCATE (reserved)           149.6M        4         reserved VM address space (unallocated)
      __DATA                            47.5M      397
      __GLSLBUILTINS                    2588K        2
      __IMAGE                            528K        2
      __LINKEDIT                       173.1M       90
      __TEXT                           377.4M      369
      __UNICODE                          552K        2
      mapped file                      170.4M      105
      shared memory                     16.4M       11
      TOTAL                              6.8G     1647
      TOTAL, minus reserved VM space     6.7G     1647
      Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 16 GB, SMC 1.39f11
      Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
      Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 4, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      Memory Module: DIMM 8, 2 GB, DDR3 ECC, 1333 MHz, 0x0198, 0x393936353433322D3032372E4130304C4620
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
      Bluetooth: Version 4.4.3f4 16616, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Ethernet 2, Ethernet, en1
      PCI Card: ATI Radeon HD 5770, Display Controller, Slot-1
      Serial ATA Device: HL-DT-ST BD-RE  WH14NS40
      Serial ATA Device: Samsung SSD 840 EVO 500GB, 500.11 GB
      Serial ATA Device: Hitachi HDS721010CLA332, 1 TB
      Serial ATA Device: WDC WD15EADS-00P8B0, 1.5 TB
      Serial ATA Device: WDC WD1001FALS-41Y6A1, 1 TB
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: BRCM2046 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: USB 2.0 Bus
      USB Device: D3 Station
      USB Device: USB 2.0 Hub
      USB Device: AppleTV
      USB Device: Mobius
      USB Device: Composite Device
      USB Device: Android
      USB Device: DYMO LabelWriter 400
      USB Device: Microsoft® LifeCam Cinema(TM)
      USB Device: WinTV
      USB Device: USB2.0 Hub
      USB Device: AFTM
      USB Device: iPhone
      USB Device: Das Keyboard Model S
      USB Device: Hub
      USB Device: USB Receiver
      FireWire Device: built-in_hub, Up to 800 Mb/sec
      Thunderbolt Bus:
