14 Replies Latest reply on Jun 19, 2016 12:37 AM by Roland Rick
    Hdr does not work
    19peter72
      Hdr not working
        • 1. Re: Hdr does not work
          dj_paige Level 9
          Are there any details you can provide?
          • 2. Re: Hdr does not work
            Roland Rick Level 1
            I have three bracket pictures (handheld) and try to merge them.
            I am still on test version of Lr 2015.CC.
            This is one point of a few Go or No Go purchase items on my checklist.
            I really appreciate any help!
            • 3. Re: Hdr does not work
              Roland Rick Level 1
              PS: Dito Panorama. Also no function.
              • 4. Re: Hdr does not work
                99jon Adobe Community Professional & MVP
                Does HDR work if you select only the two bracketed shots e.g. ignore the standard exposure and select each one with plus and minus EV?
                • 5. Re: Hdr does not work
                  Roland Rick Level 1
                  Hi 99jon
                  With standard exposure ignored as suggested: Lr also doing nothing
                  • 6. Re: Hdr does not work
                    ssprengel Adobe Community Professional & MVP
                    And do Help / System Info and check to see what actual version of LR CC you're running.   The current version is LR CC 2015.6:
                    Secondly, if you could upload a couple of your HDR shots to www.dropbox.com or similar, then others could try to them to make sure they're not corrupted, somehow.
                    • 7. Re: Hdr does not work
                      Roland Rick Level 1
                      Please have here the sysinfo, next ist Dropbox upload (takes a few minutes, slow Internet here):
                      Version von Lightroom: CC 2015.6 [ 1078672 ]
                      Lizenz: Testversion
                      Betriebssystem: Mac OS 10
                      Version: 10.11 [5]
                      Anwendungsarchitektur: x64
                      Anzahl logischer Prozessoren: 8
                      Prozessorgeschwindigkeit: 2.3 GHz
                      Integrierter Speicher: 16'384.0 MB
                      Für Lightroom verfügbarer phys. Speicher: 16'384.0 MB
                      Von Lightroom verwendeter phys. Speicher: 3'990.0 MB (24.3%)
                      Von Lightroom verwendeter virtueller Speicher: 5'509.6 MB
                      Cache-Speichergröße: 4'539.3 MB
                      Maximale Anzahl Threads, die Camera Raw verwendet: 8
                      Camera Raw SIMD-Optimierung: SSE2,AVX,AVX2
                      Monitore/Anzeigegeräte: 1) 2880x1800
                      Informationen zum Grafikprozessor:
                      NVIDIA GeForce GT 750M OpenGL Engine
                      Check OpenGL support: Passed
                      Vendor: NVIDIA Corporation
                      Version: 4.1 NVIDIA-10.10.10 310.42.25f01
                      Renderer: NVIDIA GeForce GT 750M OpenGL Engine
                      LanguageVersion: 4.10
                      Anwendungsordner: /Applications/Adobe Lightroom
                      Bibliothekspfad: /Users/roland/Pictures/Lightroom/Lightroom Catalog.lrcat
                      Einstellungen-Ordner: /Users/roland/Library/Application Support/Adobe/Lightroom
                      Installierte Zusatzmodule:
                      1) Aperture/iPhoto-Import-Zusatzmodul
                      2) Canon Tether-Zusatzmodul
                      3) Facebook
                      4) Flickr
                      5) HDR Efex Pro 2
                      6) Leica Tether-Zusatzmodul
                      7) Nikon Tether-Zusatzmodul
                      8) SmugMug
                      Config.lua-Flags: None
                      AudioDeviceIOBlockSize: 512
                      AudioDeviceName: Ausgang (integriert)
                      AudioDeviceNumberOfChannels: 2
                      AudioDeviceSampleRate: 44100
                      Build: LR5x102
                      CoreImage: true
                      GL_ACCUM_ALPHA_BITS: 0
                      GL_ACCUM_BLUE_BITS: 0
                      GL_ACCUM_GREEN_BITS: 0
                      GL_ACCUM_RED_BITS: 0
                      GL_ALPHA_BITS: 8
                      GL_BLUE_BITS: 8
                      GL_DEPTH_BITS: 24
                      GL_GREEN_BITS: 8
                      GL_MAX_3D_TEXTURE_SIZE: 2048
                      GL_MAX_TEXTURE_SIZE: 16384
                      GL_MAX_TEXTURE_UNITS: 8
                      GL_MAX_VIEWPORT_DIMS: 16384,16384
                      GL_RED_BITS: 8
                      GL_RENDERER: NVIDIA GeForce GT 750M OpenGL Engine
                      GL_SHADING_LANGUAGE_VERSION: 1.20
                      GL_STENCIL_BITS: 8
                      GL_VENDOR: NVIDIA Corporation
                      GL_VERSION: 2.1 NVIDIA-10.10.10 310.42.25f01
                      OGLEnabled: true
                      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
                      Cheers, Roland
                      • 8. Re: Hdr does not work
                        Roland Rick Level 1
                        The first two are up, next two to come soon:
                        Dropbox - Adobe
                        If access to folder does not work, please let me knpw, thanks. You may for this of course send a PN
                        • 9. Re: Hdr does not work
                          Roland Rick Level 1
                          OK, DSC_3864.NEF and DSC_3865.NEF from Dropbox I could HDR merge (without the +/- 0 exposure from the bracket).
                          • 10. Re: Hdr does not work
                            I tested with two NEFs and it worked OK on my Windows 7 machine with the same version of LR.
                            Here is the preview Window and below the merged HDR image next to the original thumbnails.
                            • 11. Re: Hdr does not work
                              Both sets work for me:
                              Do things work if you restart LR or restart your computer or turn the GPU off or on in LR Prefs Performance depending on whether it is or isn't, now?
                              • 12. Re: Hdr does not work
                                The brighter of the two in each set you've supplied have enough headroom in the highlights that you can see cloud detail without going to the trouble of making an HDR, where besides the settings you can see, I also applied a Dehaze of +50:
                                And you can get much more cloud structure out of either +1 EV image using HDR Efex Pro 2 that is part of Google's now free Nik Collection:  Google Nik Collection
                                • 13. Re: Hdr does not work
                                  Roland Rick Level 1
                                  Many thanks for all of this hints.
                                  Believe it or not, this must have been a "Murphy's Law" case. Since my complaint - I am sure I booted once in between - HDR works.
                                  Because I had the same issue with panorama, I will check this also and keep you updated.
                                  • 14. Re: Hdr does not work
                                    Roland Rick Level 1
                                    Specially thanks for the hints avoiding the HDR tasks! You're my man! (Thumbs up missing in graphical emoticons list here in forum editor ).
