Any ideas why the SpinnerList would no longer work in AIR 20? It works fine when I revert back to AIR 16, which is the version I was using. My SpinnerList no longer displays any texts, and also does not scroll, although the values do seem to change even though it seems that nothing is happening visually. My spinner code looks like this:
<s:SpinnerListContainer>
<s:SpinnerList id="genderSpinner" fontFamily="Myriad Pro Bold Condensed 2" fontWeight="normal" fontSize="16" width="170" height="125" labelField="name" selectedIndex="{preLoadedSelectedIndex}">
<s:ArrayList>
<fx:Object name="Male" genderNode="male"/>
<fx:Object name="Female" genderNode="female"/>
</s:ArrayList>
</s:SpinnerList>
</s:SpinnerListContainer>
Any thoughts?
Alright, so I feel like I'm on a roll today and found the culprit for this issue too. It's related to this other issue I had here AIR 20 Display issue . Whenever I do cacheAsBitmap = false, then everything displays correctly. The trick to doing this is use an itemRenderer for the spinner:
<s:SpinnerList id="genderSpinner" fontFamily="Myriad Pro Bold Condensed 2" itemRenderer="renderers.SpinnerListItemRenderer" fontWeight="normal" fontSize="16" width="170" height="125" labelField="name" selectedIndex="{preLoadedSelectedIndex}">
<s:ArrayList>
</s:ArrayList>
</s:SpinnerList>
Then, in your custom Item Renderer, use the spark.components.SpinnerListItemRenderer, and simply add this to your own implementation:
public function SpinnerListItemRenderer()
super();
this.cacheAsBitmap = false;
switch (applicationDPI)
case DPIClassification.DPI_640:
minHeight = 40;
break;
case DPIClassification.DPI_480:
minHeight = 30;
break;
case DPIClassification.DPI_320:
minHeight = 20;
break;
case DPIClassification.DPI_240:
minHeight = 15;
break;
case DPIClassification.DPI_120:
minHeight = 8;
break;
default: // default PPI160
minHeight = 10;
break;
And voila! Adobe, I sure hope you are reading this, lets get cacheAsBitmap working on AIR 20, as it does drastically improve performance on mobile!
