30 Replies Latest reply on Mar 9, 2016 8:48 AM by matthewdee
    CC 2015 CMYK VS RGB PRINTING QUESTIONS
    matthewdee Level 1
      I have been having color issues from printing documents for Ingram Spark. I need to be POSITIVE that it is NOT a something  I'm overlooking in InDesign. I have gotten TWO physical proofs back and see that there is a major issue with both. The file contains a master page which is RED and should be in CMYK the exact numbers are 22 -100- 92- 9
      So just to make sure I open the master .indd file to the master page containing the color spread. Then I look at the FILL box.
      If I DOUBLE CLICK THE FILL BOX the color picker comes up and its in RGB
      but if I click the ARROW next to the fill box the SWATCH OPTIONS box appears and according to that the color is CMYK as I can see the correct color in the dropdown ( I named the color )
      Now if I go to the TOOL AREA and click the FILL box and THAT TOO brings up the color picker and it shows the color is in RGB.
      I need the color to be in CMYK so can someone explain how I do this?
      Hhow do I set the pdf to be CMYK?
      Also very important, when I save as a pdf Ingram Spark says
      Save As
      Adobe PDF PRESET
      pdf/x 1A 2001
      I Did This but what about the following?
      GENERAL
      COMPATIBILITY
      OPTIONS
      EXPORT LAYERS
      COMPRESSSION SETTINGS ( I NEVER TOUCHED)
      OUTPUT PAGE ( NEVER ADJUSTED ANYTHING WHAT SHOULD THOSE SETTINGS BE?)
      ADVANCED / OPI WHAT SETTING?
      AS INGRAM DOES NOT MENTION ANY OF THAT IN THEIR MANUAL
