2 Replies Latest reply on Mar 3, 2009 4:27 PM by Newsgroup_User
    protected files
    Level 7
      Here's one I've never seen...
      I have an unprotected Director project in a folder called SOURCE. Within
      that folder I have a stub prjector and a folder called main. Within main is
      main.dir and a casts folder that contains many casts. I copied the complete
      SOURCE folder and reanamed it as LOCKED. Then I protected main.dir and the
      cast files within the LOCKED folder structure.
      When I launch the .exe file within the LOCKED folder, it's opening the
      main.dir file that's nested in the SOURCE folder.
      Any idea why this is happening? The stub goes to (the moviePath &
      "main\main"
      I'm using a PC with XP in D9
      Craig
        • 1. Re: protected files
          Level 7
          Just to further clarify
          folder 1
          source\main\main.dir
          source\main\casts\<many .cst files>
          folder 2
          locked\projector.exe
          locked\main\main.dxr
          locked\main\casts\<main .cxt files>
          launching the projector in folder 2 opens main.dir in folder 1
          There are no searchpaths defined.
          Craig
          "WOMP" <forums@wordofmo.com> wrote in message
          news:gokgi6$97a$1@forums.macromedia.com...
          > is main.dir and a casts folder that contains many casts. I copied the
          > complete SOURCE folder and reanamed it as LOCKED. Then I protected
          > main.dir and the cast files within the LOCKED folder structure.
          > "main\main"
          > Craig
          • 2. Re: protected files
            Level 7
            Instead of just protecing main.dir each time I made a change to it, I
            protected all the cast files as well.
            This seemed to correct the problem. It's bazaar. I don't understand this
            but I found a solution.
            I'd still apprectiate any thoughts you might have on this.
            Craig
            > "main\main"
            > Craig
