2 Replies Latest reply on Feb 24, 2016 12:59 PM by 12345abcdefghi
    Mac OS is 64 bit, the newest JVMs are all 64bit only, yet I must use 32 bit JVM? How?
    12345abcdefghi Level 1
      I am publishing my app to ios using Adobe Animate and it pushes the app to the device then quits with no error and a stack overflow exception. No remedy is given. I thought I'd try remote debugging the application through the terminal using fdb and I get this error:
      Error: This Java instance does not support a 32-bit JVM.
      Please install the desired version
      This fellow has exactly the same problem and it was never fixed?
      http://stackoverflow.com/questions/22152916/flash-cs-5-5-professional-requires-32-bit-jvm- when-publishing-for-ios
      What should I do?
