1 Reply Latest reply on Feb 24, 2016 9:31 PM by CarlosCanto
    script that acces a xml(jdf) file
    rutgers camden Level 1
      I currently have a working script and am trying to refine it to be as automated as possible. Currently you have to add some info into prompt boxes to be placed into the active document. The info is all in a JDF file which I believe is similar if not the same as an XML file. The JDF info varies per job and was wondering if there is a way the script can retrieve the info per job. So that in the script will pull all the info and there will be no prompt boxes required. I want the script to just be ran and it does all the work.
