6 Replies Latest reply on Feb 25, 2016 7:12 AM by tpk1982
    Constant Value in Prompt box
    tpk1982 Level 4
      Is it possible to retain the values in prompt box once i entered? I meant it remain the value if i run the script again?
      var myWidth=prompt("PLEASE ENTER YOUR TEXT FRAME WIDTH VALUE (IN POINTS)","")
      For example if i enter 10, next time the default value should be 10.
      Not sure we can use const instead of variable (var)?
      Regards,
      Karthi
        • 1. Re: Constant Value in Prompt box
          TᴀW Adobe Community Professional & MVP
          Prompt() takes 3 arguments:
          a = 10;
          prompt("hello", a, "Script Name");
          First, the message, then the default value, and finally the window name (I think this is Windows-only).
          HTH,
          Ariel
          • 2. Re: Constant Value in Prompt box
            tpk1982 Level 4
            Hi Ariel,
            Thanks for your reply.  I asked this question for my script which converting selected text to table. For this i need to enter the table width. For a book, the values will not be changed. So if i give the first time then it have to take the previous value automatically.
            My coding:
            app.activeDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.POINTS;
            app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.POINTS;
            if(myWidth!=null)
            myDoc=app.selection[0];
            app.findTextPreferences = null;    app.changeTextPreferences = null;
            app.selection[0].ruleAbove=false
            app.selection[0].ruleBelow=false
            app.selection[0].convertToTable("\t","\t",1) ;
            app.selection[0].spaceBefore = "0pt";
            app.selection[0].paragraphs[0].tables[0].cells.everyItem().width = (myWidth);
            app.findGrepPreferences = null;    app.changeGrepPreferences = null;
            Is this possible?
            Regards,
            Karthi
            • 3. Re: Constant Value in Prompt box
              Just save the value as a document label:
              myDoc.insertLabel("KarthiWidth", String(myWidth));
              and then extract it when you want to use it:
              myWidth = Number(myDoc.extractLabel("KarthiWidth"));
              • 4. Re: Constant Value in Prompt box
                tpk1982 Level 4
                Hi ,
                Sorry to ask the spoon feeding question. This is the first time i am going to use Script label. Is it the way the below coding will work?
                myDoc=app.activeDocument;
                if(myWidth!=null)
                Karthi
                • 5. Re: Constant Value in Prompt box
                  Well, not quite. Before you display the prompt, you want to extract the label. So move line 08 to before 04, and change 04 to something like:
                  myWidth = prompt("PLease enter etc....", myWidth)
                  and then it should work. Obviously, test it first.
                  Ariel
                  • 6. Re: Constant Value in Prompt box
                    tpk1982 Level 4
                    Hi Ariel,
                    Thank a ton. It is working like a charm.
                    Regards,
                    Karthi
