0 Replies Latest reply on Feb 25, 2016 6:54 AM by robinh2668454
    Help with flowed form in static pdf
    robinh2668454 Level 1
      Help!  I have developed a form that has a flowed format so that the information can be expanded as needed.  The document is required to be 508 compliant so I'm being told that in order to do that along with everything else, we have to export it to a PDF Static format so that tags are a part of the document.  Unfortunately, when I save the document as a PDF Static document, the flow no longer works.  HELP!  Do I have to manually add tags to a regular XML form and if so, is there a way to do that easily?
