0 Replies Latest reply on Feb 25, 2016 11:00 AM by jgray76303135
    A way to overwrite files when a newer version is added to Acrobat for IOS, locally.
    jgray76303135
      Hello,
      When adding files to Acrobat for IOS locally if I have a file existing with the name "Map" and then add a new file with the "Map" all it does is for the new "Map" file is rename it as "Map(1)". I would like it if there was an option so that when a new file with the same name is added to the same folder it would prompt the user to either "overwrite the existing file with new one, leave the existing one alone and don't add new one to folder, or suffix the name with(1)", this would be very similar to what Windows does when that you try to put a file with the same name into same folder, and makes you choose one of the above options and doesn't allow for duplicate file names.
