2 Replies Latest reply on Feb 26, 2016 8:57 AM by rosebudd
    Help needed to convert ActionScript 3 to javascript for HTML5
    stevegershen
      I am looking for some help converting actionscript 3 code to javascript for a HTML5 platform.  I am a flash developer by trade but I am unfamiliar on how to "translate AS code to js.  I had recently downloaded Animate CC thinking it take the existing .fla file and republishes it out to a html5 format.  Well I was wrong.  All my code that I used in flash is giving me hundreds of errors & I don't even no where to begin. the issue that I have is:  All my flash documents that I have created over the years now have to be converted to html5.  Where do I go, who can help? is there a easy way to do this? is there an online converter..  I need help!! thank you.  Below is an exsisting actionscript code that I need to convert:  Sorry for the copy and past of the script.
      actionscript code below
      stop();
      import flash.utils.Timer;
      // this is where the string of numbers comes in (rootLoader.parameters)
      var generatedNums:String = MovieClip(parent.parent).WinningNumbers;
      // creates an array out of generated numbers
      var chosenNums:Array = generatedNums.split("-");
      // convert text to numbers
      var n=chosenNums.length;
      while (n--) {
        chosenNums[n]=Number(chosenNums[n])
      // call funtion to remove 0 from list of numbers
      function remove(list:Array,callback:Function):Array {
          for(var i:int = list.length - 1; i >= 0; i--) {
              if(!callback(list[i])) {
                  list.splice(i,1);
          return list;
      //remove 0 from list of numbers
      function removeCallback(item:Number):Boolean {
          return item >= 1;
      remove(chosenNums,removeCallback);
      // keeps track of which element of the array to use to create balls
      // (first then second then third)
      var chosenNumsIndex:uint = 0;
      // creates array of coordinates of numbers on the board.
      var kNum:Array = new Array();
      var bottomArray:Array = new Array("", "", "", "", "", "", "", "", "", "","", "","", "","", "","", "","", "","");
      // kNum[0] is a dummy because there's no 0 on the board.
      kNum[0] = {x:0, y:0};
      //array of movieclips
      var mcArray:Array = new Array();
      mcArray.push(n1, n2, n3, n4, n5, n6, n7, n8, n9, n10, n11, n12, n13, n14, n15, n16, n17, n18, n19, n20, n21, n22, n23, n24, n25, n26, n27, n28, n29, n30, n31, n32, n33, n34, n35, n36, n37, n38, n39, n40, n41, n42, n43, n44, n45, n46, n47, n48, n49, n50, n51, n52, n53, n54, n55, n56, n57, n58, n59, n60, n61, n62, n63, n64, n65, n66, n67, n68, n69, n70, n71, n72, n73, n74, n75, n76, n77, n78, n79, n80);
      // creates timer that runs every 3 seconds.  Number of times it runs
      // is determined by the length of chosenNums array (which is the number
      // of numbers chosen)
      var timer:Timer = new Timer(3000, chosenNums.length);
      // timer is listening for itself to trigger, calls chuckBall()
      timer.addEventListener(TimerEvent.TIMER, chuckBall);
      timer.addEventListener(TimerEvent.TIMER_COMPLETE, ballChuckingComplete);
      // chuckBall generates coins
      function chuckBall(event:TimerEvent):void
        // generates new Coin - Coin is the name of MovieClip in Library
        // remember to export for Actionscript
        var c1:Coin = new Coin();
        // coin is placed at appropriate x and y coords
        c1.x = kNum[chosenNums[chosenNumsIndex]].x;
        c1.y = kNum[chosenNums[chosenNumsIndex]].y;
        // addChild tells main timeline to display coin once it's generated.
        this.addChild(c1);
        trace(chosenNums[chosenNumsIndex])
        // pull appropriate movieclip out of array and play to darken.
        mcArray[chosenNums[chosenNumsIndex] - 1].play();
          // fill in bottom numbers
        // increments chosenNumsIndex so the next time chuckBall runs
        // it pulls the next element of the chosenNums array.
        //chosenNumsIndex ++;
      bottomArray[chosenNumsIndex - 1] = chosenNums[chosenNumsIndex- 1];
      trace("bottomArray value " +bottomArray[chosenNumsIndex]);
      firstWinningNumB.text = bottomArray[0];
      twoWinningNumB.text = bottomArray[1];
      threeWinningNumB.text = bottomArray[2];
      fourWinningNumB.text = bottomArray[3];
      fiveWinningNumB.text = bottomArray[4];
      sixWinningNumB.text = bottomArray[5];
      sevenWinningNumB.text = bottomArray[6];
      eightWinningNumB.text = bottomArray[7];
      nineWinningNumB.text = bottomArray[8];
      tenWinningNumB.text = bottomArray[9];
      elevenWinningNumB.text = bottomArray[10];
      twelveWinningNumB.text = bottomArray[11];
      thirteenWinningNumB.text = bottomArray[12];
      fourteenWinningNumB.text = bottomArray[13];
      fifteenWinningNumB.text = bottomArray[14];
      sixteenWinningNumB.text = bottomArray[15];
      seventeenWinningNumB.text = bottomArray[16];
      eighteenWinningNumB.text = bottomArray[17];
      nineteenWinningNumB.text = bottomArray[18];
      //twentyWinningNumB.text = bottomArray[19];
      var lastNumber:Timer = new Timer(60000, 1);
      lastNumber.addEventListener(TimerEvent.TIMER, lastNumDone);
      lastNumber.start();
        chosenNumsIndex ++;
      function ballChuckingComplete(event:TimerEvent):void
        //trace("ballchuckingcomplete is working");
        var thirtySeconds:Timer = new Timer(15000, 1);
        thirtySeconds.addEventListener(TimerEvent.TIMER, thirtyDone);
        thirtySeconds.start();
      function thirtyDone(event:TimerEvent):void
        trace("thirty seconds up");
        //stop();
        gotoAndStop(2);
      function lastNumDone(event:TimerEvent):void
        trace("last number done");
        twentyWinningNumB.text = chosenNums[19];
      // manually starts the timer.
      timer.start();
