• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem passing argument to CFCOMPONENT.
New Here ,
Feb 26, 2016 Feb 26, 2016
N00b here making slow headway turning spaghetti code into more suitable code.
I am tinkering with a very simple CFINVOKE of a component. On the page is this:
<cfinvoke
  component="Products"
    method="get_active_products"
    returnvariable="p"
    specificProduct="BA100">
</cfinvoke>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Component Play</title>
</head>
<body>
<p>Hi.</p>
<cfdump var="#p#">
</body>
</html>
And in Product.cfc is this:
<cfcomponent displayname="Active Products CFC" hint="Gets all active catalog products">
<!--- This function gets all the active products and their data from the DB --->
<cffunction name="get_active_products" hint="Gets active products in the database" returntype="query">
<!--- identify arguments --->
<cfargument name="specificProduct" type="string" required="no">
<!--- if we get a value, add it to the query --->
<cfif IsDefined(arguments.specificProduct)>
    <cfset whereClause="AND prod_code = " + specificProduct>
    <cfelse>
<!--- and if we don't, just make it blank --->
    <cfset whereClause="">
  </cfif>
<!--- now query for active products... --->
  <cfquery name="get_em" datasource="#application.datasource#">
        select * from tblProducts
        WHERE prod_status != '4' and prod_status != '8' and prod_status != '11'
        #whereClause#
    </cfquery>
<!--- and return the dataset --->
  <cfreturn get_em>
</cffunction>
</cfcomponent>
HOWEVEVER... It never seems to see arguments.specificProduct as having a value, thus always just returns all products. I've read a lot about CFINVOKE, CFCOMPONENT and all the ways to reference a variable... and tried them all! This is so simple. What's amiss?
Thanks.
Views
323
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Feb 27, 2016 Feb 27, 2016
LATEST
1)  Do you happen to have 2 similar CFCs named, respectively, Products and Product? You wrote:
<cfinvoke component="Products"  ...>
2) Arguments.specificProduct is defined (except where the caller passes no argument). So testing for its existence seems partly redundant.
In any case, the line <cfif IsDefined(arguments.specificProduct)> may instead get Coldfusion to test for the existence of a variable named BA100. You could therefore improve the code as follows
<cfargument name="specificProduct" type="string" required="no" default="">
<cfif arguments.specificProduct is not "">
    <cfset whereClause="AND prod_code = " & arguments.specificProduct>
<cfelse>
</cfif>
Votes
Translate
Translate
Report
Report
Resources
Documentation
