13 Replies Latest reply on Feb 28, 2016 6:53 PM by OzSanta2
    addAnnot problem with Acrobat DC on Mac
    OzSanta2
      G'day
      I'm having awful problems trying to get the following JavaScript to work on my mac, running El Capitan.
      Using an old 'Add Watermark' Java script, the free barcode font Code 128 draws as the font Arial. So I'm trying to use an Annotation, with no success after two days trying.
      I get an error that the Java Script does not understand the 'do script' message.
      Any guidance, please.
      Regards
      Santa
      set theNewString to ((character id 209) & "this is a test" & (character id 211) as text)
      # values are Text, Font, Font Size, Start Page, End Page, Text type?, Horizontal Alignment, Vertical Offset, Horizontal Offset, Vertical Height, Rotation, Current Page
      set theResult1 to my Add_WaterMarkText(theNewString, "Code 128", 48, 1, 1, 1, 0, 3, 10, 0, 0, 1)
      # This handler uses Java Script
      on Add_WaterMarkText(cText, cFont, nFontSize, nS, nE, nTA, nHorizontalAlignment, nVerticalAlignment, nHorizontalValue, nVerticalValue, nR, currentPage)
        set Params to ""
        set Params to Params & "cPage:" & currentPage - 1 & ", " & return
        set Params to Params & "cType:Text, " & return
        set Params to Params & "cContents:" & cText & ", " & return
        set Params to Params & "cTextFont:" & cFont & ", " & return
        set Params to Params & "cTextSize:40, " & return
        set Params to Params & "cpoint:[300, 100], " & return
        set Params to Params & "cWidth:0, " & return
        set Params to Params & "cAlignment:0, " & return
        tell application "Adobe Acrobat"
        activate
        tell document 1
        do script "this.addAnnot({" & Params & "});"
        end tell
        end tell
      end Add_WaterMarkText
        • 1. Re: addAnnot problem with Acrobat DC on Mac
          OzSanta2 Level 1
          I'm really up the proverbial creek without a paddle.
          I've tried modifying the script to the following, and  have no idea if a 'c' is necessary before each item, as in my first attempt. All I know is that the clipboard contains exactly the script in the form it's supposed to be in, as far as I can tell, the script is NOT crashing, and nothings happening, no text boxes are being drawn. Do I need some different code to draw a text box rather than an Annotation?.
          Please, any advice?
            activate
            set p to 1
            tell document 1
            tell page 1
            set cbox to {}
            if cbox = {} then set cbox to crop box
            if cbox = {} then set cbox to bounds
            if cbox = {} then set cbox to media box
            if cbox = {} then set cbox to art box
            if cbox = {} then set cbox to trim box
            if cbox = {} then set cbox to bleed box
            set p to 4
            set pageTop to (item 2 of cbox) + 36
            set p to 5
            set item 2 of cbox to pageTop
            set p to 6
            set pageBottom to (item 4 of cbox)
            set p to 7
            set item 4 of cbox to pageBottom
            set p to 8
            set bounds to cbox
            set p to 9
            set media box to cbox
            set p to 10
            set crop box to cbox
            set p to 11
            set trim box to cbox
            set p to 12
            set bleed box to cbox
            set p to 13
            set art box to cbox
            set p to 14
            set p to 15
            set theResult1 to my Add_WaterMarkText(theNewString, "Times", 16, 1, 1, 1, 0, 3, 10, 0, 0, 1)
            try
            do script theResult1
            on error errmsg
            display dialog errmsg
            end try
            set theResult1 to my Add_WaterMarkText(theNewString, "MRV Code128bXSA", 16, 1, 1, 1, 0, 3, 10, 0, 0, 1)
            try
            on error errmsg
            end try
            end tell
            end tell
          end tell
            # set theType to "Text" as text
            set Params to "page:" & currentPage - 1 & ", " & return
            set Params to Params & "type:\"" & "Text" & "\", " & return
            set Params to Params & "contents:\"" & cText & "\", " & return
            set Params to Params & "textFont:\"" & cFont & "\", " & return
            set Params to Params & "textSize:" & nFontSize & ", " & return
            set Params to Params & "rect:[1, 1, 300, 100], " & return
            set Params to Params & "width:0, " & return
            set Params to Params & "alignment:0, " & return
            set Params to Params & "hidden:false, " & return
            set Params to Params & "textColor:color.black," & return
            set Params to Params & "opacity:1," & return
            set javaScript to "this.addAnnot({" & return & Params & "});"
            set the clipboard to javaScript
            return javaScript
          The ClipBoard...
          this.addAnnot({
          page:0,
          type:"Text",
          contents:"Ñthis is a testÓ",
          textFont:"MRV Code128bXSA",
          textSize:16,
          width:0,
          alignment:0,
          hidden:false,
          opacity:1,
          • 2. Re: addAnnot problem with Acrobat DC on Mac
            If you're trying to add a barcode that can be expressed using a font, use a text field instead of an annotation or watermark.
            • 3. Re: addAnnot problem with Acrobat DC on Mac
              I'm sure you understand this but to avoid confusing people, what you posted isn't a JavaScript, it's an AppleScript, run from the Finder. It creates a single line that contains JavaScript. The first example tries to use do script to run it in Acrobat.
              YOu ask whether the c is needed in cPage etc. Check the JavaScript API reference for the correct names, but a c like this is Not unusual. Lrt's simplify to eliminate AppleScript issues. You build a command. does it work if you paste into the JavaScript console?
              • 4. Re: addAnnot problem with Acrobat DC on Mac
                OzSanta2 Level 1
                Thank you both.
                I  finally got the posted script to run, only to find it created a 'dialog balloon' icon, that when clicked on, revealed the text in Arial format. So I've decided to try the text box approach.
                The script I've come up with fails with the same error as before, doesn't understand the 'do script' message.
                I've pasted the Clipboard into the debugger, and added 'var f ' in front, and the error I eventually get is that it needs a Doc set, which I don't know how to do, despite researching 'Doc'. I'm presuming that means the script should be OK, but why don't it work? I'm hopeless at JavaScript, so any advice is greatly appreciated.
                I would also like  to make sure I'm using the correct font name, by following this procedure below, but can't work out how to name a text box 'Text1'. Any help on this as well, please? I've tried all sorts of things, but no explanation tells me how to name a text box in Acrobat Pro DC! Is it possible to address the text field by a number?
                Thanks in advance,
                Santa
                To find the PDSysFont font name of a font:
                1.Create a text field in a PDF document. Using the UI, set the text font for this field to the desired font.
                2.Open the JavaScript Debugger Console and execute the script
                      this.getField("Text1").textFont
                The above code assumes the name of the field is Text1.
                3.The string returned to the console is the font name needed to programmatically set the text font.
                  activate
                  set p to 1
                  tell document 1
                  tell page 1
                  set cbox to {}
                  set p to 4
                  set p to 5
                  set p to 6
                  set p to 7
                  set p to 8
                  set bounds to cbox
                  set p to 9
                  set p to 10
                  set p to 11
                  set p to 12
                  set p to 13
                  set art box to cbox
                  set p to 14
                  set p to 15
                  set theResult1 to my Add_WaterMarkText(theNewString, "MRVCode128bXSA", 16, 1, 1, 1, 0, 3, 10, 0, 0, 1)
                  try
                  on error errmsg
                  end try
                  end tell
                  end tell
                end tell
                  # set Params to Params & "type:\"" & "Text" & "\"," & return
                  set Params to Params & "richText:true," & return
                  set Params to Params & "value:\"" & cText & "\"," & return
                  set Params to Params & "textFont:\"" & cFont & "\"," & return
                  set Params to Params & "textSize:" & nFontSize & "," & return
                  set Params to Params & "rect:[100, 472, 272, 400]," & return
                  set Params to Params & "alignment:\"" & "Left" & "\"," & return
                  set Params to Params & "UserName:\"" & "Text1" & "\"," & return
                  set Params to Params & "multiline:false," & return
                  set Params to Params & "lineWidth:0," & return
                  # set Params to Params & "display:display.visible," & return
                  set javaScript to "this.addField({" & Params & "});"
                  return javaScript
                The Cipboard...
                this.addField({page:0,
                richText:true,
                value:"Ñthis is a testÓ",
                textFont:"MRV Code128bXSA regular",
                textSize:16,
                alignment:"Left",
                UserName:"Text1",
                multiline:false,
                lineWidth:0,
                • 5. Re: addAnnot problem with Acrobat DC on Mac
                  This is not how you use the addField method. Please read its documentation carefully before using it.
                  You must specify 4 parameters, and 4 parameters only. The method will return a Field object (if successful) and then you'll be able to set the rest of the properties as you wish.
                  The field name must be a string. If can be "12" or "Text1" or whatever. I would recommend keeping it simple. Call it "Barcode1" or something like that.
                  The correct name for the font is hard to come by. Follow the instructions you posted to do it correctly. Any other name is not going to work.
                  Also, you have to remember that JS is case-sensitive, so the property "UserName" is not going to work. It's "userName".
                  And one more thing: If you specify richText to be true then you must provide a an array of spans to set the value, using the richValue property. I don't think this is necessary in your case. Keep it simple!
                  • 6. Re: addAnnot problem with Acrobat DC on Mac
                    I assume you have a document open. What is the exact wording of the error? Please, never summarise errors, only copy/paste. And include the exact command you paste. There is no scope for guessing!
                    • 7. Re: addAnnot problem with Acrobat DC on Mac
                      OzSanta2 Level 1
                      Thank you both once again. sorry about the tardiness of my reply, by we in Oz had to sleep.
                      Try67, I modified my script, but still get an error 'Can't understand script message', and a debug error (below)
                      Test Screen Name, here's the result of my Debug. I don't know what the missing ';' really wants? I've tried putting a ';' & return in front, and now the debugger does not throw an error, but it also doesn't work. The 'run' button stays red
                      var f = this.addField("Text1","Ñthis is a testÓ", [0, 1298, 144, 1262], 0);
                      f.richText:true;
                      f.textSize:16;
                      f.alignment:"Left";
                      f.multiline:false;
                      f.lineWidth:0;
                      f.display:display.visible;
                      f.textColor:color.black;
                      SyntaxError: missing ; before statement
                      1:
                      1:
                      My Code...
                        activate
                        set p to 1
                        tell document 1
                        tell page 1
                        set cbox to {}
                        set p to 4
                        set pageTop to (item 2 of cbox) + 36 as integer
                        set p to 5
                        set p to 6
                        set p to 7
                        set p to 8
                        set bounds to cbox
                        set p to 9
                        set p to 10
                        set p to 11
                        set p to 12
                        set p to 13
                        set art box to cbox
                        set p to 14
                        set p to 15
                        set theResult1 to my Add_TextBoxText(theNewString, "MRVCode128bXSA", 16, 1, 1, 1, 0, pageTop, 144, 36, 0, 1)
                        try
                        on error errmsg
                        end try
                        end tell
                        end tell
                      end tell
                      on Add_TextBoxText(cText, cFont, nFontSize, nS, nE, nTA, nHorizontalAlignment, nVerticalAlignment, nHorizontalValue, nVerticalValue, nR, currentPage)
                        set Params to "var f = this.addField(\"" & "Text1" & "\",\"" & cText & "\", [" & nHorizontalAlignment & ", " & nVerticalAlignment & ", " & nHorizontalValue & ", " & nVerticalAlignment - nVerticalValue & "], " & currentPage - 1 & ");" & return
                        set Params to Params & "f.richText:true;" & return
                        # set Params to Params & "f.textFont:font.\"" & cFont & "\";" & return
                        set Params to Params & "f.textSize:" & nFontSize & ";" & return
                        set Params to Params & "f.alignment:\"" & "Left" & "\";" & return
                        set Params to Params & "f.multiline:false;" & return
                        set Params to Params & "f.lineWidth:0;" & return
                        set Params to Params & "f.display:display.visible;" & return
                        set Params to Params & "f.textColor:color.black;" & return
                        set javaScript to Params
                        return javaScript
                      end Add_TextBoxText
                      Added this to stop debugger throwing an error, but does not do anything now.
                      set Params to ";" & return
                        set Params to Params & "var f = this.addField(\"" & "Text1" & "\",\"" & cText & "\", [" & nHorizontalAlignment & ", " & nVerticalAlignment & ", " & nHorizontalValue & ", " & nVerticalAlignment - nVerticalValue & "], " & currentPage - 1 & ");" & return
                      • 8. Re: addAnnot problem with Acrobat DC on Mac
                        Replace all colons with equals signs (=).
                        Also, double-check the order of the parameters of addField.
                        • 9. Re: addAnnot problem with Acrobat DC on Mac
                          OzSanta2 Level 1
                          Oops, I realised I had left in the 'rickText' line. Now removed, and a textFont added. Debugger no longer errors, but errors, and 'do script' still throws a 'don't understand' error.
                          The Debugger (I've tried reducing the 1802, & 1766 to well within the page size, but still get the same error.
                          var f = this.addField("Text1","Ñthis is a testÓ", [0, 1802, 144, 1766], 0);
                          RangeError: Invalid argument value.
                          Doc.addField:0:
                          Try67, I'll re-script the colons, but my problems start before those, with the first line.
                          Even with all the 'f.' statements commented out, I still get an error.  How on earth do I format the first line to be recognised, please?
                          Adobe Acrobat got an error: "var f = this.addField(\"Text1\",\"Ñthis is a testÓ\", [0, 974, 144, 938], 0);
                          " doesn’t understand the “do script” message.
                          var f = this.addField("Text1","Ñthis is a testÓ", [0, 1622, 144, 1586], 0);
                          tellapplication "Adobe Acrobat"
                            activate
                            set p to 1
                            tell document 1
                            tell page 1
                            set cbox to {}
                            set p to 4
                            set p to 5
                            set p to 6
                            set p to 7
                            set p to 8
                            set bounds to cbox
                            set p to 9
                            set p to 10
                            set p to 11
                            set p to 12
                            set p to 13
                            set art box to cbox
                            set p to 14
                            set p to 15
                            try
                            on error errmsg
                            end try
                            end tell
                            end tell
                          end tell
                            set Params to ""
                            return javaScript
                          end Add_TextBoxText
                          • 10. Re: addAnnot problem with Acrobat DC on Mac
                            carefully check your addField parameters against the documentation; both the type and order are important. Or is the problem that you haven't found the documentation?
                            • 11. Re: addAnnot problem with Acrobat DC on Mac
                              OzSanta2 Level 1
                              G'day Test Screen Name. No, I haven't found any direct documentation of setting fields, only this  addField scripting - Adobe Acrobat Windows and the Acrobat DC SDK Documentation, where I can't find how to set the script for a field.
                              Any pointers, please?
                              Sorry to be a nuisance.
                              Regards
                              Santa
                              • 12. Re: addAnnot problem with Acrobat DC on Mac
                                OzSanta2 Level 1
                                I feel stupid. On re-checking my only link to an example, I realised I had transposed the page number and rect. Fixed it, and ran just the first line, with everything else commented out, and it ran with no error, but also no box drawn. Inserted the Clipboard into the Debugger, and got this...
                                var f = this.addField("Text1", "Ñthis is a testÓ", 0, [1, 1144, 144, 1108]);
                                TypeError: f is null
                                The error I get with then uncommenting just one line is...
                                I've reset every colon to '=', but still the error. Any answers, please?
                                • 13. Re: addAnnot problem with Acrobat DC on Mac
                                  OzSanta2 Level 1
                                  A big 'THANK YOU' to you both. With modifications pointed out by both of you, my script now works, and it uses the free barcode font available from The code 128. (The french site).
                                  Regards
                                  Santa
                                    activate
                                    set p to 1
                                    tell document 1
                                    tell page 1
                                    set cbox to {}
                                    set p to 4
                                    set p to 5
                                    set p to 6
                                    set p to 7
                                    set p to 8
                                    set bounds to cbox
                                    set p to 9
                                    set p to 10
                                    set p to 11
                                    set p to 12
                                    set p to 13
                                    set art box to cbox
                                    set p to 14
                                    set p to 15
                                    set theResult1 to my Add_TextBoxText(theNewString, "Code128", 28, 1, 1, 1, 1, pageTop, 144, 36, 0, 1)
                                    try
                                    on error errmsg
                                    end try
                                    end tell
                                    end tell
                                  end tell
                                    set Params to ""
                                    set Params to Params & "var f = this.addField(\"" & "Text1" & "\", " & "\"" & "text" & "\", " & currentPage - 1 & ", [" & nHorizontalAlignment & ", " & nVerticalAlignment - 10 & ", " & nHorizontalValue & ", " & nVerticalAlignment - nVerticalValue - 10 & "]" & ");" & return
                                    set Params to Params & "f.value = \"" & cText & "\";" & return
                                    set Params to Params & "f.userName = \"" & "Text1" & "\";" & return
                                    set Params to Params & "f.textSize = " & nFontSize & ";" & return
                                    set Params to Params & "f.textFont =  \"" & cFont & "\";" & return
                                    set Params to Params & "f.alignment = \"" & "left" & "\";" & return
                                    set Params to Params & "f.multiline = false;" & return
                                    set Params to Params & "f.lineWidth = 0;" & return
                                    set Params to Params & "f.display = display.visible;" & return
                                    set Params to Params & "f.textColor = color.black;" & return
                                    return javaScript
                                  end Add_TextBoxText
