3 Replies Latest reply on Feb 28, 2016 1:29 PM by try67
    Trying to create tally form
    jsimon050
      I'm trying to create a form to track a token economy in Acrobat Pro DC. The amounts will be in whole number increments. I thought that I'd be able to assign a values to Button form fields, have them clicked, and have the corresponding value maintain a running total in a Text field. If this is possible, my skills are insufficient. Instead, I'm using Checkbox fields, assigning values to them, and using the Value is the sum function under to calculate tab. The limitation of this method, however, is that it changes the sum as I uncheck a box. I need this to not happen and I suspect that I'll need some javascript either in the Checkbox field, the Textbox field, or both. Thanks.
