2 Replies Latest reply on Mar 12, 2016 4:42 PM by johnl34897798
    setChildIndex is being overridden by embedded SWF
    johnl34897798
      Hello all I am trying to embed a SWF file into my project and place some navigation buttons over top of the SWF. The SWF is a 360 panoramic photo and in the past this has worked just fine, but now it seems the SWF is overriding my action script and pushing itself to the top layer over my navigation buttons. Below is my action script. Any help would be appreciated.
      //Sets the layer of display for the items below
      setChildIndex(cockpitInstructions_mc,numChildren -1);
      setChildIndex(cockpitVideo_mc,numChildren -2);
      setChildIndex(cockpitVideo2_mc,numChildren -3);
      setChildIndex(CockpitHeader_mc,numChildren -4);
      setChildIndex(homeButton1_mc,numChildren -5);
      setChildIndex(infoButton1_mc,numChildren -6);
      //Sets the movie clips below invisible
      cockpitVideo_mc.visible = false;
      cockpitVideo_mc.stop();
      cockpitVideo2_mc.visible = false;
      cockpitVideo2_mc.stop();
      //Embeds the pano .swf file
      import flash.net.FileReference;
      var requestVariable = new URLRequest("test-01.swf");
      var loaderVariable:Loader = new Loader();
      var booleanVariable:Boolean = false;
      loaderVariable.load(requestVariable);
      addChild(loaderVariable);
      setChildIndex(loaderVariable,numChildren -7);
      //Button to navigate back to the home movie
      homeButton1_mc.addEventListener(MouseEvent.CLICK, onhomeButton1Click);
      function onhomeButton1Click(e:MouseEvent):void
      removeChild(homeButton1_mc);
      removeChild(CockpitHeader_mc);
      loaderVariable.unloadAndStop();
      gotoAndPlay(1);
      //Button to play the info movie clip
      infoButton1_mc.addEventListener(MouseEvent.CLICK, oninfoButton1Click);
      function oninfoButton1Click(e:MouseEvent):void
      cockpitVideo_mc.visible = true;
      cockpitVideo_mc.play();
      //Button to play second half of the info movie clip
      cockpitVideo_mc.addEventListener(MouseEvent.CLICK, oncockpitVideoClick);
      function oncockpitVideoClick(e:MouseEvent):void
      cockpitVideo2_mc.visible = true;
      cockpitVideo2_mc.play();
      //Removes movie clip from stage when clicked
      cockpitVideo2_mc.addEventListener(MouseEvent.CLICK, oncockpitVideo2Click);
      function oncockpitVideo2Click(e:MouseEvent):void
      // Timer to remove instruction movie clip
      var minuteTimer:Timer = new Timer(6500, 1);
      minuteTimer.addEventListener(TimerEvent.TIMER_COMPLETE, onTimerComplete);
      minuteTimer.start();
      function onTimerComplete(event:TimerEvent):void
      removeChild(cockpitInstructions_mc);
        • 1. Re: setChildIndex is being overridden by embedded SWF
          Colin Holgate MVP & Adobe Community Professional
          You have so many setchildindex lines going on that it could be confusing. If you want to set the layering of some items, so that the top seven items are on top of everything else, and in a particular order, you could use addChild(). That puts the object to the front, if you did that for the top seven items they would be on top, and in the right order.
          For these lines:
          you could use addChildAt() instead, and have the loaderVariable at the correct level right away.
          • 2. Re: setChildIndex is being overridden by embedded SWF
            johnl34897798 Level 1
            It turns out that there was something within the external SWFs that were overriding the layer numbering. Experimented with different 360 pano software and found that Garden Gnome Pano is the only one that worked. Didn't have to change the setChildIndex lines.
