13 Replies Latest reply on Mar 2, 2016 8:07 AM by donm26210672
    MPEG-2 TS file input error
    donm26210672
      I have Premeier Elements 13 running on Windows 7.
      I have imported MPEG-2 TS Video but I just get 'Media Pending' on the monitor. At the bottom in the Events Window there is the error message:- A low-level exception occurred in: ImporterFastMPEG (Importer)
      According to the spec for Elements 13 it should be able to import MPEG-2 TS video files.
        • 1. Re: MPEG-2 TS file input error
          What model of camcorder is your video coming from and what format and resolution is it?
          If your MPEG is not from a camcorder, where did it come from? What resolution is it?
          Have you ensured you have the latest version of Quicktime, per the program's requirements?
          How long is your video file?
          Windows 7 does not install all updates automatically. Manually go to Windows Update and install the non-critical updates that don't install automatically.
          • 2. Re: MPEG-2 TS file input error
            donm26210672 Level 1
            The MPEG is from a programme recorded on my PVR.
            I don't know the resolution but the frame width is 544 and the height is 576 if that means anything. I recorded it in Standard Definition.
            I can't see Quicktime in my list of programs but I do have Quicktime movies (.MOV) in the system.
            The video file is 39 mins long.
            I have installed all the non-critical Windows Updates.
            • 3. Re: MPEG-2 TS file input error
              You'll need to crack open a sample of that MPEG then to see what's inside.
              Open one of your MPEGs in G Spot or, better, Media Info (free downloads) and post the resolution, frame rate and audio and video codecs listed. Media Info may also list the media writer that was used.
              Personal video recorder software can use some very unconventional resolutions, frame rate and codecs (Happauge is notorious for being problematic) and it's possible you've got a file Premiere Elements simply can't digest.
              • 4. Re: MPEG-2 TS file input error
                PVR means personal video recorder and records tv to hdd instead of dvd.
                Mpeg-ts is not meant to be edited, it is meant to be watched on the tv.
                • 5. Re: MPEG-2 TS file input error
                  This in the information I have extracted regarding the file. Hope you can find what you want there.
                  Video
                  Menu ID                                  : 25792 (0x64C0)
                  Format                                   : MPEG Video
                  Format version                           : Version 2
                  Format profile                           : Main@Main
                  Format settings, BVOP                    : Yes
                  Format settings, Matrix                  : Custom
                  Format settings, GOP                     : Variable
                  Format settings, picture structure       : Frame
                  Codec ID                                 : 2
                  Duration                                 : 39mn 46s
                  Bit rate mode                            : Variable
                  Bit rate                                 : 2 144 Kbps
                  Maximum bit rate                         : 15.0 Mbps
                  Width                                    : 544 pixels
                  Height                                   : 576 pixels
                  Display aspect ratio                     : 4:3
                  Active Format Description                : Full frame 16:9 image
                  Frame rate                               : 25.000 fps
                  Color space                              : YUV
                  Chroma subsampling                       : 4:2:0
                  Bit depth                                : 8 bits
                  Scan type                                : Interlaced
                  Scan order                               : Top Field First
                  Compression mode                         : Lossy
                  Bits/(Pixel*Frame)                       : 0.274
                  Stream size                              : 610 MiB (90%)
                  Audio
                  Format                                   : MPEG Audio
                  Format version                           : Version 1
                  Format profile                           : Layer 2
                  Mode                                     : Joint stereo
                  Codec ID                                 : 3
                  Duration                                 : 39mn 46s
                  Bit rate mode                            : Constant
                  Bit rate                                 : 128 Kbps
                  Channel(s)                               : 2 channels
                  Sampling rate                            : 48.0 KHz
                  Delay relative to video                  : -848ms
                  Stream size                              : 36.4 MiB (5%)
                  Language                                 : English
                  Text
                  Format                                   : DVB Subtitle
                  Codec ID                                 : 6
                  Duration                                 : 39mn 44s
                  Delay relative to video                  : 4s 172ms
                  Language                                 : English
                  • 6. Re: MPEG-2 TS file input error
                    Thanks for the information but I thought MPEG-2 TS files were suitable for input.
                    • 7. Re: MPEG-2 TS file input error
                      Mpeg is but not mpeg2_TS.
                      • 8. Re: MPEG-2 TS file input error
                        There are so much flavours.
                        • 9. Re: MPEG-2 TS file input error
                          Aside from the non-standard pixel aspect ratio of .85 and the non-standard resolution of 544x576 (rather than the standard PAL resolution of 720x576), I don't see anything that would cause the program to reject the file outright. The program will likely have trouble editing this video, but it shouldn't just choke.
                          This is certainly not the best program for editing this video. However, I don't see anything in this report that would indicate a terminal issue.
                          Have you considered editing this video in Windows MovieMaker rather than Premiere Elements? MovieMaker isn't nearly as powerful, but it can handle a wider range of video formats.
                          • 10. Re: MPEG-2 TS file input error
                            Last resort:
                            convert mpeg to mp4 with HandBrake  and reimport
                            See if that will make a difference
                            • 11. Re: MPEG-2 TS file input error
                              Thanks for your help and advice. I'll try Windows Movie Maker but I think the best route for me would be to convert the file into one that's acceptable to Premier Elements.
                              • 12. Re: MPEG-2 TS file input error
                                Thanks for the advice. I'll try what you have suggested and convert the file.
                                • 13. Re: MPEG-2 TS file input error
                                  I've converted the file to mp4 and it worked fine. Thanks.
